I am trying to save and then load a tensorrt engine in in the python API with tensorrt 4 but i get the following error: "pycuda._driver.LogicError:
“pycuda._driver.LogicError: cuMemcpyDtoHAsync failed: an illegal memory access was encountered
PyCUDA WARNING: a clean-up operation failed (dead context maybe?)
cuMemFree failed: an illegal memory access was encountered
cuStreamDestroy failed: an illegal memory access was encountered”
If I don’t load the engine it works:
plugin_factory = tensorrtplugins.PRELUPluginFactory()
# Convert caffe model to TensorRT engine
runtime = trt.infer.create_infer_runtime(G_LOGGER)
engine = trt.utils.caffe_to_trt_engine(G_LOGGER,
MODEL_PROTOTXT,
CAFFE_MODEL,
1,
1 << 20,
OUTPUT_LAYERS,
trt.infer.DataType.FLOAT,
plugin_factory)
data = np.load(os.path.join(DATA_DIR, "im_data.npy")).astype(np.float32)
context = engine.create_execution_context()
out = infer(context, data, OUTPUT_SIZE, 1)
# Destroy engine
runtime.destroy()
engine.destroy()
context.destroy()
# Destroy plugin created by factory
plugin_factory.destroyPlugin()
But if I try to save it and load it then it gives me the error:
MODEL_PROTOTXT,
CAFFE_MODEL,
1,
1 << 20,
OUTPUT_LAYERS,
plugin_factory)
trt.utils.write_engine_to_file("PReLU1.engine",engine.serialize())
engine.destroy()
engine = trt.utils.load_engine(G_LOGGER, "PReLU1.engine", plugin_factory)
# Destroy engine
runtime.destroy()
engine.destroy()
context.destroy()
