I am receiving this error in a very weird way, whenever I use batch_size = 10 in the below code I receive this error and for all other batch sizes, it works fine.
output = np.zeros((batch_size,512),dtype=np.float32,order="C")
print("number of bytes in output array : ",output.nbytes)
# print("output type : ",type(output))
# print(output.shape)
d_input = cuda.mem_alloc(im_batch.nbytes)
d_output = cuda.mem_alloc(output.nbytes)
bindings = [int(d_input), int(d_output)]
# copy input to device, run inference, copy output to host
cuda.memcpy_htod_async(d_input,im_batch)
self.context.execute_v2(bindings=bindings)
# cuda.Context.synchronize()
cuda.memcpy_dtoh_async(output,d_output)
error message :
pycuda._driver.LogicError: cuMemcpyDtoHAsync failed: an illegal memory access was encountered
PyCUDA WARNING: a clean-up operation failed (dead context maybe?)
cuMemFree failed: an illegal memory access was encountered
[05/17/2023-15:58:38] [TRT] [E] 1: [defaultAllocator.cpp::deallocate::42] Error Code 1: Cuda Runtime (CUDA-capable device(s) is/are busy or unavailable)
[05/17/2023-15:58:38] [TRT] [E] 1: [cudaResources.cpp::~ScopedCudaStream::47] Error Code 1: Cuda Runtime (CUDA-capable device(s) is/are busy or unavailable)
[05/17/2023-15:58:38] [TRT] [E] 1: [cudaResources.cpp::~ScopedCudaEvent::24] Error Code 1: Cuda Runtime (CUDA-capable device(s) is/are busy or unavailable)
This error appears whenever I set batch_size = 10. Please can you help me identify the cause of this behavior?
