Description
There was an error about illegal memory access when I tried to run the tensorrt with FP16 layer input using python script with tensorrt and pycuda similar to tensorrt_samples/yolov3_onnx. I also tried to replace pycuda.gpuarray with pcyuda.driver.mem_alloc but the same error still showing
I was able to run the quantized YOLOv6 model in Triton Inference Server using this command to build the model:
trtexec --workspace=1024 --percentile=99 --streams=1 --int8 --fp16 --avgRuns=10 --onnx=best_ckpt_bs1_graph_opt.onnx --inputIOFormats=fp16:chw
I was able to run the simple copy to device memory from terminal using pycuda.gpuarray
import numpy as np
import pycuda
import pycuda.gpuarray
pycuda.driver.init()
cuda_context = pycuda.tools.make_default_context()
stream = pycuda.driver.Stream()
data = np.random.rand(1,2,3,4).astype(np.float16)
mem = pycuda.gpuarray.empty([1,2,3,4], dtype=np.float16)
mem.set(data)
mem.set_async(data, stream)
stream.synchronize()
Error codes
[TensorRT] INFO: [MemUsageChange] Init cuDNN: CPU +0, GPU +8, now: CPU 1094, GPU 6064 (MiB)
[TensorRT] VERBOSE: Total per-runner device memory is 18651648
[TensorRT] VERBOSE: Total per-runner host memory is 146608
[TensorRT] VERBOSE: Allocated activation device memory of size 8292864
[TensorRT] INFO: [MemUsageSnapshot] ExecutionContext creation end: CPU 1095 MiB, GPU 6090 MiB
Created bindings for 0: (1, 3, 640, 640) - <class 'numpy.float16'>
Created bindings for 1: (1, 1) - <class 'numpy.int32'>
Created bindings for 2: (1, 100, 4) - <class 'numpy.float32'>
Created bindings for 3: (1, 100) - <class 'numpy.float32'>
Created bindings for 4: (1, 100) - <class 'numpy.int32'>
Initialize device buffer: (1, 3, 640, 640) - <class 'numpy.float16'>
Initialize device buffer: (1, 1) - <class 'numpy.int32'>
Initialize device buffer: (1, 100, 4) - <class 'numpy.float32'>
Initialize device buffer: (1, 100) - <class 'numpy.float32'>
Initialize device buffer: (1, 100) - <class 'numpy.int32'>
Initialize host buffer: (1, 3, 640, 640) - <class 'numpy.float16'>
Initialize host buffer: (1, 1) - <class 'numpy.int32'>
Initialize host buffer: (1, 100, 4) - <class 'numpy.float32'>
Initialize host buffer: (1, 100) - <class 'numpy.float32'>
Initialize host buffer: (1, 100) - <class 'numpy.int32'>
{'images': {'byte_size': 2457600, 'dtype': <class 'numpy.float16'>, 'shape': (1, 3, 640, 640)}}
images: (1, 3, 640, 640) - float16 - 2457600
Data: (1, 3, 640, 640) - float16 - 2457600
binding array: (1, 3, 640, 640) - float16 - 2457600
[TensorRT] ERROR: 2: [pluginV2DynamicExtRunner.cpp::execute::115] Error Code 2: Internal Error (Assertion status == kSTATUS_SUCCESS failed.)
host array: (1, 1) - int32 - 4
FAILED
===================================================================== FAILURES =====================================================================
============================================================= short test summary info ==============================================================
FAILED tests/test_trt_inference.py::test_inference - pycuda._driver.LogicError: cuMemcpyDtoHAsync failed: an illegal memory access was encountered
================================================================ 1 failed in 5.29s =================================================================
[TensorRT] ERROR: 1: [hardwareContext.cpp::terminateCommonContext::141] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
[TensorRT] INTERNAL ERROR: [defaultAllocator.cpp::free::85] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
[TensorRT] WARNING: Unable to determine GPU memory usage
[TensorRT] INFO: [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +0, now: CPU 1026, GPU 0 (MiB)
[TensorRT] INTERNAL ERROR: [resources.cpp::~ScopedCudaStream::455] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
[TensorRT] INTERNAL ERROR: [resources.cpp::~ScopedCudaEvent::438] Error Code 1: Cuda Runtime (an illegal memory access was encountered)
CUDA_ERROR_ILLEGAL_ADDRESS
terminate called after throwing an instance of 'std::runtime_error'
what(): CUDA_ERROR_ILLEGAL_ADDRESS
Fatal Python error: Aborted
Current thread 0x00007f565cfd7740 (most recent call first):
<no Python frame>
Aborted (core dumped)
Environment
Docker: nvcr.io/nvidia/pytorch:21.10-py3, nvcr.io/nvidia/pytorch:22.06-py3
TensorRT Version: 8.0.3.4, 8.2.5
NVIDIA GPU: T4
NVIDIA Driver Version: 515.65.01
CUDA Version: 11.7
Operating System: Ubuntu
Relevant Files
I can’t share the full codes, but some relevant functions are similar to here:
Bindings - Using
pagelocked_emptyandpycuda.gpuarray -
Engine Builder → tensorrt_samples/yolov3_onnx
But I modify the network input dtype and formats to FP16.
for idx in range(network.num_inputs):
network.get_input(idx).allowed_formats = 1 << int(trt.TensorFormat.CHW16)
network.get_input(idx).dtype = trt.DataType.HALF
