PyNvVideoCodec convert decoded frame from NV12 to RGB format on GPU
New to vide encode decoding. Using PyNvVideoCodec for decoding. Looking for ways to convert the decode frame to RGB UINT8 image.
nv_dmx = nvc.CreateDemuxer(filename="codylexi.mp4")
nv_dec = nvc.CreateDecoder(gpuid=0,
                           codec=nv_dmx.GetNvCodecId(),
                           cudacontext=0,
                           cudastream=0,
                           usedevicememory=True)
decoded_frame_size = 0
raw_frame = None
height =  nv_dmx.Height()
width = nv_dmx.Width()
y_size = width * height
uv_size = width * height // 2
seq_triggered = False
# printing out FPS and pixel format of the stream for convenience
print("FPS = ", nv_dmx.FrameRate())
for packet in nv_dmx:
    # Decode returns a list of packets, range of this list is from [0, size of (decode picture buffer)]
    # size of (decode picture buffer) depends on GPU, fur Turing series its 8
    for decoded_frame in nv_dec.Decode(packet):
        # 'decoded_frame' contains list of views implementing cuda array interface
        # for nv12, it would contain 2 views for each plane and two planes would be contiguous
        if not seq_triggered:
            print(decoded_frame.format)
            decoded_frame_size = nv_dec.GetFrameSize()
            raw_frame = np.ndarray(shape=decoded_frame_size, dtype=np.uint8)
            seq_triggered = True
        decoded_frame = decoded_frame.nvcv_image()
