Python Bindings for DeepStream not working with RTSP stream
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version8.0.1.6
deepstream_test_3.py runs well with mp4 files but when I provide RTSP URI it gives an authentication error. Even though same URI works with Deepstream-app if I run it with sample config files. Same URI also works with OpenCV.
I have also tried this but doesn’t work:
@techguyz any solutions?
Please check if it works in gst-launch-1.0:
$ gst-launch-1.0 uridecodebin uri='rtsp://_IP_ADDRESS_' ! nvoverlaysink
And you may add ' 'before and after the URI for a try.
Yes, using this command RTSP stream works fine.
Screenshot of terminal attached.
Note: I have tried other RTSP links with this python file, they work fine.
This problem occurs when I use a Dahua IMOU IP camera. But this camera’s stream works well with DeepStream-app and GST-lanch so it should work here too.
There’s deepstream-test3 in C. Could you give it a try? Would like to confirm it is not specific to python.
Same problem.
Looks like the URI is not read correctly. In the Now Playing print, it should be:
rtsp://......?channel=1&subtype=0,
But it shows only
rtsp://......?channel=1,
It should be because & is interpreted as running in background. Please replace & with \& and check if the URI is correctly read.
Worked, thanks
