Python Deepstream Tracking Object Time in Frame
Hi, I would like to extract the time that the tracked object is in frame. Currently I am using the Deepstream_test_3 and Deepstream_test_2 for pulling and tracking object via the rtsp stream from an IP Camera. Would anyone be able to recommend the approach?
# tiler_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
def tiler_src_pad_buffer_probe(pad,info,u_data):
    frame_number=0
    num_rects=0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.glist_get_nvds_frame_meta()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
            frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
        except StopIteration:
            break
        print("Frame Number is ", frame_meta.frame_num)
        print("Source id is ", frame_meta.source_id)
        print("Batch id is ", frame_meta.batch_id)
        print("Source Frame Width ", frame_meta.source_frame_width)
        print("Source Frame Height ", frame_meta.source_frame_height)
        print("Num object meta ", frame_meta.num_obj_meta)
        frame_number=frame_meta.frame_num
        l_obj=frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        obj_counter = {
        PGIE_CLASS_ID_VEHICLE:0,
        PGIE_CLASS_ID_PERSON:0,
        PGIE_CLASS_ID_BICYCLE:0,
        PGIE_CLASS_ID_ROADSIGN:0
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta=pyds.glist_get_nvds_object_meta(l_obj.data)
                break
            obj_counter[obj_meta.class_id] += 1
            try:
                l_obj=l_obj.next
                break
        display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
        display_meta.num_labels = 1
        py_nvosd_text_params = display_meta.text_params[0]
        py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE], obj_counter[PGIE_CLASS_ID_PERSON])
        py_nvosd_text_params.x_offset = 10;
        py_nvosd_text_params.y_offset = 12;
        py_nvosd_text_params.font_params.font_name = "Serif"
        py_nvosd_text_params.font_params.font_size = 10
        py_nvosd_text_params.font_params.font_color.red = 1.0
        py_nvosd_text_params.font_params.font_color.green = 1.0
        py_nvosd_text_params.font_params.font_color.blue = 1.0
        py_nvosd_text_params.font_params.font_color.alpha = 1.0
        py_nvosd_text_params.set_bg_clr = 1
        py_nvosd_text_params.text_bg_clr.red = 0.0
        py_nvosd_text_params.text_bg_clr.green = 0.0
        py_nvosd_text_params.text_bg_clr.blue = 0.0
        py_nvosd_text_params.text_bg_clr.alpha = 1.0
        #print("Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",vehicle_count,"Person_count=",person)
        pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
        print("Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",obj_counter[PGIE_CLASS_ID_VEHICLE],"Person_count=",obj_counter[PGIE_CLASS_ID_PERSON])
        # Get frame rate through this probe
        fps_streams["stream{0}".format(frame_meta.pad_index)].get_fps()
        try:
            l_frame=l_frame.next
            break
    return Gst.PadProbeReturn.OK
I’m think it will have to extract with this probe, but I don’t know what meta data to call/how to display the time elapsed from the original frame the object was detected.
Can you get “frame_meta->ntp_timestamp” ?
I’m declaring the variable along with others:
ntp_timestamp = frame_meta.ntp_timestamp
        obj_counter = {
then printing it out in console, but it always is zero.
print(ntp_timestamp, "Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",obj_counter[PGIE_CLASS_ID_VEHICLE],"Person_count=",obj_counter[PGIE_CLASS_ID_PERSON])
  1. Where should I be declaring the variable?
  2. Can we track the object age through _NvMOTTrackedObj?
  3. How do we edit the tracking labels on the osdpad? Like instead of only the infered class label, but would be like “Person 7seconds”
In the probe function user can start the timer/counter for given tracking object and continue to increment it as long as the same object is seen.
To display - the user needs to iterate over object metadata and update “display_text”. For this user needs to first backup the existing “display_text”, then free it and update the “display_text” with the string that user wants
