I am trying to build the local environment for testing yolo11 with TensorRT on my jetson orin nano with jetpack 5.1.4 @ ubuntu20.04
According to the guide , torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl , torchvision v0.16.2 was installed. But I have to downgrade the setuptools==69.5.1 from 75.x.x, otherwise the command python3 setup.py install --user can not be ran. If I use setuptools==75.x.x, I will met:
xliu@ubuntu:~/torchvision$ /usr/bin/python3 setup.py install --user
setup.py:10: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
from pkg_resources import DistributionNotFound, get_distribution, parse_version
Building wheel torchvision-0.16.2+c6f3977
Compiling extensions with following flags:
FORCE_CUDA: False
FORCE_MPS: False
DEBUG: False
TORCHVISION_USE_PNG: True
TORCHVISION_USE_JPEG: True
TORCHVISION_USE_NVJPEG: True
TORCHVISION_USE_FFMPEG: True
TORCHVISION_USE_VIDEO_CODEC: True
NVCC_FLAGS:
Compiling with debug mode OFF
Found PNG library
Building torchvision with PNG image support
libpng version: 1.6.37
libpng include path: /usr/include/libpng16
Running build on conda-build: False
Running build on conda: False
Building torchvision with JPEG image support
libjpeg include path: None
libjpeg lib path: None
Building torchvision without NVJPEG image support
Building torchvision with ffmpeg support
ffmpeg version: b"ffmpeg version n4.2.7-24-gd796def2ea-1ubuntu0.1 Copyright (c) 2000-2022 the FFmpeg developers\nbuilt with gcc 9 (Ubuntu 9.4.0-1ubuntu1~20.04.2)\nconfiguration: --prefix=/usr --enable-nvv4l2dec --enable-libv4l2 --enable-shared --extra-libs='-L/usr/lib/aarch64-linux-gnu/tegra -lv4l2 -lnvbufsurface -lnvbufsurftransform' --extra-cflags=-I/usr/src/jetson_multimedia_api/include/ --extra-version=1ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared\nlibavutil 56. 31.100 / 56. 31.100\nlibavcodec 58. 54.100 / 58. 54.100\nlibavformat 58. 29.100 / 58. 29.100\nlibavdevice 58. 8.100 / 58. 8.100\nlibavfilter 7. 57.100 / 7. 57.100\nlibavresample 4. 0. 0 / 4. 0. 0\nlibswscale 5. 5.100 / 5. 5.100\nlibswresample 3. 5.100 / 3. 5.100\nlibpostproc 55. 5.100 / 55. 5.100\n"
ffmpeg include path: ['/usr/include', '/usr/include/aarch64-linux-gnu']
ffmpeg library_dir: ['/usr/lib', '/usr/lib/aarch64-linux-gnu']
Building torchvision without video codec support
running install
/home/xliu/.local/lib/python3.8/site-packages/setuptools/_distutils/cmd.py:66: SetuptoolsDeprecationWarning: setup.py install is deprecated.
Please avoid running `setup.py directly.
Instead, use pypa/build, pypa/installer or other
standards-based tools.
See https://blog.ganssle.io/articles/2021/10/setup-py-deprecated.html for details.
self.initialize_options()
File "setup.py", line 542, in <module>
setup(
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/__init__.py", line 117, in setup
return distutils.core.setup(**attrs)
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_distutils/core.py", line 183, in setup
return run_commands(dist)
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_distutils/core.py", line 199, in run_commands
dist.run_commands()
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_distutils/dist.py", line 954, in run_commands
self.run_command(cmd)
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/dist.py", line 999, in run_command
super().run_command(command)
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_distutils/dist.py", line 972, in run_command
cmd_obj.ensure_finalized()
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_distutils/cmd.py", line 111, in ensure_finalized
self.finalize_options()
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/command/install.py", line 67, in finalize_options
super().finalize_options()
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_distutils/command/install.py", line 408, in finalize_options
'dist_fullname': self.distribution.get_fullname(),
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_core_metadata.py", line 267, in get_fullname
return _distribution_fullname(self.get_name(), self.get_version())
File "/home/xliu/.local/lib/python3.8/site-packages/setuptools/_core_metadata.py", line 285, in _distribution_fullname
canonicalize_version(version, strip_trailing_zero=False),
TypeError: canonicalize_version() got an unexpected keyword argument 'strip_trailing_zero'
After switching setuptools to 69.5.1, the torchvision can be installed successfully:
torch 2.1.0a0+41361538.nv23.6 /home/xliu/.local/lib/python3.8/site-packages pip
torchvision 0.16.2 /home/xliu/.local/lib/python3.8/site-packages/torchvision-0.16.2-py3.8-linux-aarch64.egg
However, the torchvision will post errors:
$ python3 -c "import torch; print(torch.__version__)"
$ python3 -c "import torchvision; print(torchvision.__version__)"
/usr/local/lib/python3.8/dist-packages/torchvision/io/image.py:13: UserWarning: Failed to load image Python extension: '/usr/local/lib/python3.8/dist-packages/torchvision/image.so: undefined symbol: _ZN5torch3jit17parseSchemaOrNameERKSsb'If you don't plan on using image functionality from `torchvision.io`, you can ignore this warning. Otherwise, there might be something wrong with your environment. Did you have `libjpeg` or `libpng` installed before building `torchvision` from source?
warn(
0.16.2+c6f3977
But the required pack like libjpeg and libpng have already been installed in advance.
The same thing happen to other torchvision v0.16.x as well. Any successful experience sharing will be appreciated!
