NOTE: The JetPack 4.4 production release (L4T R32.4.3) only supports PyTorch 1.6.0 or newer, due to updates in cuDNN.
Installation for Python 3.6
- PyTorch 1.6.0
wget https://nvidia.box.com/shared/static/yr6sjswn25z7oankw8zy1roow9cy5ur1.whl -O torch-1.6.0rc2-cp36-cp36m-linux_aarch64.whl
sudo apt-get install python3-pip libopenblas-base libopenmpi-dev
sudo pip3 install Cython
sudo pip3 install torch-1.6.0rc2-cp36-cp36m-linux_aarch64.whl
- Torchvision 0.6.0
sudo apt-get install libjpeg-dev zlib1g-dev
git clone --branch v0.6.0 https://github.com/pytorch/vision torchvision
cd torchvision
sudo python3 setup.py install
Test
- Pytourch
import torch print(torch.__version__) print('CUDA available: ' + str(torch.cuda.is_available())) print('cuDNN version: ' + str(torch.backends.cudnn.version())) a = torch.cuda.FloatTensor(2).zero_() print('Tensor a = ' + str(a)) b = torch.randn(2).cuda() print('Tensor b = ' + str(b)) c = a + b print('Tensor c = ' + str(c))
- Torchvision
import torchvision
print(torchvision.version)
Documentation - PyTorch for Jetson
