the question seems non related to Jetson, as the latter only supports arch64 processor instruction set. For x86_64 x86_64 computer should be used. However there are multiple ways to build caffe & pytorch for x86_64, mostly they could be from sources from their github repositories. Moreover for Jetson, in order to deploy Torch you could use pre-built packages that you can find in the very beginning of the forum thread. For caffe for Jetson, there is a reference Caffe installation on Xavier - #2 by AastaLLL
Andrey1984
442
Related topics
| Pytorch support | 30 | 5481 | August 21, 2019 | |
| Cant install Pytorch on JetsonNano P3450 | 20 | 2996 | August 16, 2023 | |
| Torchvision will not import into Python after jetson-inference build of PyTorch | 14 | 2272 | July 11, 2020 | |
| Install Pytorch with cuda on Jetson Orin nano Devloper Kit | 12 | 4759 | July 8, 2024 | |
| PyTorch Install problem (Solved) | 34 | 32924 | May 6, 2021 | |
| Pytorch and Torchvision problem on Jetson Nano | 6 | 1703 | November 19, 2023 | |
| pytorch & torchvision installation issue | 16 | 15740 | September 1, 2020 | |
| Cannot install PyTorch on jetson nano for python 3.9 | 10 | 4569 | August 4, 2023 | |
| Running PyTorch on Jetson TX2 | 9 | 1619 | February 27, 2024 | |
| Issues Installing pytorch through jetson inference install script | 6 | 1499 | October 2, 2023 |
