I follow commend flow:
pip3 install numpy torch-1.3.0-cp36-cp36m-linux_aarch64.whl
Install failed with information:
Collecting numpy
Using cached https://files.pythonhosted.org/packages/40/de/0ea5092b8bfd2e3aa6fdbb2e499a9f9adf810992884d414defc1573dca3f/numpy-1.18.1.zip
Processing ./torch-1.3.0-cp36-cp36m-linux_aarch64.whl
Building wheels for collected packages: numpy
Running setup.py bdist_wheel for numpy ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0xuwkh30/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpe_g4dwdupip-wheel- --python-tag cp36:
Running from numpy source directory.
Cythonizing sources
Processing numpy/random/_bounded_integers.pxd.in
Processing numpy/random/_generator.pyx
File "/tmp/pip-build-0xuwkh30/numpy/tools/cythonize.py", line 61, in process_pyx
from Cython.Compiler.Version import version as cython_version
ModuleNotFoundError: No module named 'Cython'
During handling of the above exception, another exception occurred:
File "/tmp/pip-build-0xuwkh30/numpy/tools/cythonize.py", line 238, in <module>
main()
File "/tmp/pip-build-0xuwkh30/numpy/tools/cythonize.py", line 234, in main
find_process_files(root_dir)
File "/tmp/pip-build-0xuwkh30/numpy/tools/cythonize.py", line 225, in find_process_files
process(root_dir, fromfile, tofile, function, hash_db)
File "/tmp/pip-build-0xuwkh30/numpy/tools/cythonize.py", line 191, in process
processor_function(fromfile, tofile)
File "/tmp/pip-build-0xuwkh30/numpy/tools/cythonize.py", line 66, in process_pyx
raise OSError('Cython needs to be installed in Python as a module')
OSError: Cython needs to be installed in Python as a module
File "<string>", line 1, in <module>
File "/tmp/pip-build-0xuwkh30/numpy/setup.py", line 488, in <module>
setup_package()
File "/tmp/pip-build-0xuwkh30/numpy/setup.py", line 469, in setup_package
generate_cython()
File "/tmp/pip-build-0xuwkh30/numpy/setup.py", line 275, in generate_cython
raise RuntimeError("Running cythonize failed!")
RuntimeError: Running cythonize failed!
Failed building wheel for numpy
Running setup.py clean for numpy
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0xuwkh30/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
Failed cleaning build dir for numpy
Failed to build numpy
Installing collected packages: numpy, torch
Running setup.py install for numpy ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0xuwkh30/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-ijydcqk6-record/install-record.txt --single-version-externally-managed --compile --user --prefix=:
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install numpy` (last NumPy release on PyPi)
Cythonizing sources
numpy/random/_bounded_integers.pxd.in has not changed
main()
setup_package()
generate_cython()
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0xuwkh30/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-ijydcqk6-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-0xuwkh30/numpy/
how to solve?
