Thank you
I think I need to reflash the device
Thanks for this piece of code! Really appreciated. But my concern is about building it in a docker image. For now it seems almost impossible since MAGMA depends on cublas and it is not available in Nvidiaās l4t-base image. Also Nvidia donāt share cuda binaries for arm64 installation.
@dusty_nv do you see a solution?
Thanks a lot!
Hi @ruelj2, I see cublas in the l4t-base image:
$ sudo docker run -it --rm --runtime nvidia --network host nvcr.io/nvidia/l4t-base:r32.4.2
# ls -ll /usr/lib/aarch64-linux-gnu/libcublas*
lrwxrwxrwx 1 root root 15 Jun 19 14:38 /usr/lib/aarch64-linux-gnu/libcublas.so -> libcublas.so.10
lrwxrwxrwx 1 root root 22 Jun 19 14:38 /usr/lib/aarch64-linux-gnu/libcublas.so.10 -> libcublas.so.10.2.2.89
-rw-r--r-- 1 root root 80530928 Oct 29 2019 /usr/lib/aarch64-linux-gnu/libcublas.so.10.2.2.89
lrwxrwxrwx 1 root root 17 Jun 19 14:38 /usr/lib/aarch64-linux-gnu/libcublasLt.so -> libcublasLt.so.10
lrwxrwxrwx 1 root root 24 Jun 19 14:38 /usr/lib/aarch64-linux-gnu/libcublasLt.so.10 -> libcublasLt.so.10.2.2.89
-rw-r--r-- 1 root root 33235064 Oct 29 2019 /usr/lib/aarch64-linux-gnu/libcublasLt.so.10.2.2.89
Are you running it with --runtime nvidia
? To use it during docker build
operations, you should set the default-runtime to nvidia: https://github.com/dusty-nv/jetson-containers#docker-default-runtime
Thank you very much for this precious information. Although the --runtime nvidia
is not possible to specifiy during build stage, it is possible to ābuild my app within the container manually and commit the resulting imageā using docker run -it --rm --runtime nvidia
- ref.
To get the nvidia runtime during build stage, you can set the default-runtime to nvidia in your docker daemon configuration, as shown here: https://github.com/dusty-nv/jetson-containers#docker-default-runtime
@dusty_nv
I am having difficulty installing Pytorch with the following error:
Python 3.6.9 (default, Apr 18 2020, 01:56:04)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
File "<stdin>", line 1, in <module>
File "/home/derek/.local/lib/python3.6/site-packages/torch/__init__.py", line 81, in <module>
from torch._C import *
ImportError: libcudart.so.10.0: cannot open shared object file: No such file or directory
I realize that some people had the same error above so I installed it using the following commands but still the same error persists.
wget https://nvidia.box.com/shared/static/c3d7vm4gcs9m728j6o5vjay2jdedqb55.whl
sudo apt-get install python3-pip libopenblas-base libopenmpi-dev
pip3 install Cython
pip3 install numpy torch-1.4.0-cp36-cp36m-linux_aarch64.whl
I used a SD card to flash image.
Ubuntu 18.04
CUDA Version 10.2.89
Not sure what Jetpack version but SD card image was downloaded today from https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#write on a Mac host.
Canāt install pytorch on jetson xavier nx. The same problem occurs.
import error: from torch._C import *
I notice that PyTorch has been updated to 1.5.1, if the PyTorch version of the Jetson Nano has been updated? If updated, can you give me a linkļ¼Thanks ^_^
Installing PyTorch v1.5.0 can solve this problem, because the cuda version in the new image is 10.2.
In the past I havenāt build the *.1 minor releases because of time/support constraints, but I will pick up PyTorch 1.6 when itās released. You can try building 1.5.1 from source though.
Hi @mura.ryo03302, which version of PyTorch did you install and which link did you use to download the wheel?
I installed pytorch1.4 for JetPack 4.4 DP
Python 3.6 - torch-1.4.0-cp36-cp36m-linux_aarch64.whl
Hmm. Does it have any other error text, or does it only say import error: from torch._C import *
Also, you are trying to import this from a python3
environment, correct?
If you run the following command from a terminal, does it show any broken links or libraries it canāt find?
$ ldd ~/.local/lib/python3.6/site-packages/torch/_C.cpython-36m-aarch64-linux-gnu.so
linux-vdso.so.1 (0x0000007f83729000)
libtorch_python.so => /home/nvidia/.local/lib/python3.6/site-packages/torch/./lib/libtorch_python.so (0x0000007f82983000)
libshm.so => /home/nvidia/.local/lib/python3.6/site-packages/torch/./lib/libshm.so (0x0000007f82969000)
libnvToolsExt.so.1 => /usr/local/cuda-10.2/lib64/libnvToolsExt.so.1 (0x0000007f82950000)
libtorch.so => /home/nvidia/.local/lib/python3.6/site-packages/torch/./lib/libtorch.so (0x0000007f58c5f000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000007f58c0d000)
libc10_cuda.so => /home/nvidia/.local/lib/python3.6/site-packages/torch/./lib/libc10_cuda.so (0x0000007f58bd0000)
libc10.so => /home/nvidia/.local/lib/python3.6/site-packages/torch/./lib/libc10.so (0x0000007f58b7b000)
libcudart.so.10.2 => /usr/local/cuda-10.2/lib64/libcudart.so.10.2 (0x0000007f58b07000)
libmpi_cxx.so.20 => /usr/lib/aarch64-linux-gnu/libmpi_cxx.so.20 (0x0000007f58adc000)
libmpi.so.20 => /usr/lib/aarch64-linux-gnu/libmpi.so.20 (0x0000007f589eb000)
libstdc++.so.6 => /usr/lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000007f58858000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000007f58834000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000007f586db000)
/lib/ld-linux-aarch64.so.1 (0x0000007f836fe000)
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000007f586c4000)
libcufft.so.10 => /usr/local/cuda-10.2/lib64/libcufft.so.10 (0x0000007f4c631000)
libcurand.so.10 => /usr/local/cuda-10.2/lib64/libcurand.so.10 (0x0000007f48519000)
libcublas.so.10 => /usr/lib/aarch64-linux-gnu/libcublas.so.10 (0x0000007f4383b000)
libcudnn.so.8 => /usr/lib/aarch64-linux-gnu/libcudnn.so.8 (0x0000007f43805000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000007f4374b000)
libgomp.so.1 => /usr/lib/aarch64-linux-gnu/libgomp.so.1 (0x0000007f4370e000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000007f436f9000)
libnuma.so.1 => /usr/lib/aarch64-linux-gnu/libnuma.so.1 (0x0000007f436db000)
libopenblas.so.0 => /usr/lib/aarch64-linux-gnu/libopenblas.so.0 (0x0000007f43013000)
libcusparse.so.10 => /usr/local/cuda-10.2/lib64/libcusparse.so.10 (0x0000007f3a960000)
libopen-rte.so.20 => /usr/lib/aarch64-linux-gnu/libopen-rte.so.20 (0x0000007f3a8ce000)
libopen-pal.so.20 => /usr/lib/aarch64-linux-gnu/libopen-pal.so.20 (0x0000007f3a81c000)
libhwloc.so.5 => /usr/lib/aarch64-linux-gnu/libhwloc.so.5 (0x0000007f3a7d8000)
libcublasLt.so.10 => /usr/lib/aarch64-linux-gnu/libcublasLt.so.10 (0x0000007f38812000)
libgfortran.so.4 => /usr/lib/aarch64-linux-gnu/libgfortran.so.4 (0x0000007f3870e000)
libutil.so.1 => /lib/aarch64-linux-gnu/libutil.so.1 (0x0000007f386fb000)
libltdl.so.7 => /usr/lib/aarch64-linux-gnu/libltdl.so.7 (0x0000007f386e2000)
Thanks! It worked
The errors and their execution environments are as follows
xavier@xavier-desktop:~$ nvcc -V
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_21:14:42_PDT_2019
Cuda compilation tools, release 10.2, V10.2.89
xavier@xavier-desktop:~$ python3
>>> import torch
File "/home/xavier/.local/lib/python3.6/site-packages/torch/__init__.py", line 81, in <module>
ImportError: libmpi_cxx.so.20: cannot open shared object file: No such file or directory
command and found that some links are broken. Please let me know how to solve this problem.
avier@xavier-desktop:~$ ldd ~/.local/lib/python3.6/site-packages/torch/_C.cpython-36m-aarch64-linux-gnu.so
linux-vdso.so.1 (0x0000007f943b2000)
libgtk3-nocsd.so.0 => /usr/lib/aarch64-linux-gnu/libgtk3-nocsd.so.0 (0x0000007f94335000)
libtorch_python.so => /home/xavier/.local/lib/python3.6/site-packages/torch/lib/libtorch_python.so (0x0000007f935cc000)
libdl.so.2 => /lib/aarch64-linux-gnu/libdl.so.2 (0x0000007f935b7000)
libpthread.so.0 => /lib/aarch64-linux-gnu/libpthread.so.0 (0x0000007f9358b000)
libc.so.6 => /lib/aarch64-linux-gnu/libc.so.6 (0x0000007f93432000)
/lib/ld-linux-aarch64.so.1 (0x0000007f94387000)
libshm.so => /home/xavier/.local/lib/python3.6/site-packages/torch/lib/libshm.so (0x0000007f93418000)
libnvToolsExt.so.1 => /usr/local/cuda/lib64/libnvToolsExt.so.1 (0x0000007f933ff000)
libtorch.so => /home/xavier/.local/lib/python3.6/site-packages/torch/lib/libtorch.so (0x0000007f6970e000)
libc10_cuda.so => /home/xavier/.local/lib/python3.6/site-packages/torch/lib/libc10_cuda.so (0x0000007f696d1000)
libc10.so => /home/xavier/.local/lib/python3.6/site-packages/torch/lib/libc10.so (0x0000007f6967c000)
libcudart.so.10.2 => /usr/local/cuda/lib64/libcudart.so.10.2 (0x0000007f69608000)
libmpi_cxx.so.20 => not found
libmpi.so.20 => not found
libstdc++.so.6 => /usr/lib/aarch64-linux-gnu/libstdc++.so.6 (0x0000007f69474000)
libgcc_s.so.1 => /lib/aarch64-linux-gnu/libgcc_s.so.1 (0x0000007f69450000)
librt.so.1 => /lib/aarch64-linux-gnu/librt.so.1 (0x0000007f69439000)
libcufft.so.10 => /usr/local/cuda/lib64/libcufft.so.10 (0x0000007f5d3a6000)
libcurand.so.10 => /usr/local/cuda/lib64/libcurand.so.10 (0x0000007f5928e000)
libcublas.so.10 => /usr/lib/aarch64-linux-gnu/libcublas.so.10 (0x0000007f545b0000)
libcudnn.so.8 => /usr/lib/aarch64-linux-gnu/libcudnn.so.8 (0x0000007f5457a000)
libm.so.6 => /lib/aarch64-linux-gnu/libm.so.6 (0x0000007f544c0000)
libgomp.so.1 => /usr/lib/aarch64-linux-gnu/libgomp.so.1 (0x0000007f54483000)
libnuma.so.1 => /usr/lib/aarch64-linux-gnu/libnuma.so.1 (0x0000007f54465000)
libopenblas.so.0 => /usr/lib/aarch64-linux-gnu/libopenblas.so.0 (0x0000007f53d9d000)
libcusparse.so.10 => /usr/local/cuda/lib64/libcusparse.so.10 (0x0000007f4b6ea000)
libcublasLt.so.10 => /usr/lib/aarch64-linux-gnu/libcublasLt.so.10 (0x0000007f49724000)
libgfortran.so.4 => /usr/lib/aarch64-linux-gnu/libgfortran.so.4 (0x0000007f49621000)
you may try searching the file;
find ~ -name libmpi*
otherwise
sudo apt install mlocate
sudo updatedb
locate libmpi
If the library is not presented in the system - then it will need to be installed; otherwise paths will need to be adjusted. e.g. somewhat like
export LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/openmpi/lib:$LIBRARY_PATH
reference ImportError: libmpi_cxx.so.1:, the setup of LD_LIBRARY_PATH after install openmpi-bin (Ubuntu18.04) - Solved Ā· Issue #3499 Ā· microsoft/CNTK Ā· GitHub
reference mpi.h: No such file or directory Ā· Issue #32 Ā· NVIDIA/nccl-tests Ā· GitHub
Thanks Andrei, yes you should be able to install it with sudo apt-get install libopenmpi-dev
Hey everyone!
Is there a wheel of torch for python 3.7 for using on a Jetson Xavier AGX ?
Hi @themozel, I build the wheels for Python 3.6. However some others on this thread have been able to build PyTorch from source for Python 3.7. I think you need to run sudo apt-get install python3.7-dev
first.
Thanks Andrey1984, dusty_nv.
All resolved.
The problem was that there was no library, so I solved it by installing libopenmpi-dev.
