I am following this link https://github.com/andrewadare/jetson-tx2-pytorch to install Pytorch on my TX1
I got error describe below. Please let me know how to fix this. I don’t have much experience with Linux and I am trying to follow fast AI class.
Thanks in advance.
I installed cmake 3.13.4
I installed python 3.7 (including Python2.7/Python3/Python3.5/Python3.7)
I am trying to install openCV 3.1.0 for Python 3.7 following the section OpenCV in the first link which reference to this link https://www.pyimagesearch.com/2016/10/24/ubuntu-16-04-how-to-install-opencv/
but I got below error:
Note: I ssh into TX1 from another PC
ubuntu@tegra-ubuntu:/mnt/data/Software/opencv-3.1.0/build$ sudo cmake -D ENABLE_PRECOMPILED_HEADERS=OFF \ -D WITH_OPENCL=OFF \ -D WITH_CUDA=OFF \ -D WITH_CUFFT=OFF \ -D WITH_CUBLAS=OFF \ -D CMAKE_BUILD_TYPE=RELEASE \ -D CMAKE_INSTALL_PREFIX=/usr/local/bin \ -D INSTALL_PYTHON_EXAMPLES=OFF \ -D javascript:void(0);INSTALL_C_EXAMPLES=OFF \ -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-3.1.0/modules \ -D PYTHON_EXECUTABLE= /usr/bin/pyhon3.7 \ -D BUILD_EXAMPLES=OFF ..
CMake Deprecation Warning at CMakeLists.txt:72 (cmake_policy):
The OLD behavior for policy CMP0022 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
CMake Deprecation Warning at CMakeLists.txt:77 (cmake_policy):
The OLD behavior for policy CMP0026 will be removed from a future version
of CMake.
CMake Deprecation Warning at CMakeLists.txt:82 (cmake_policy):
The OLD behavior for policy CMP0042 will be removed from a future version
of CMake.
-- Detected version of GNU GCC: 54 (504)
-- Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found suitable version "1.2.8", minimum required is "1.2.3")
-- Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found version "1.2.8")
-- Checking for module 'libdc1394-2'
-- No package 'libdc1394-2' found
-- Checking for module 'libdc1394'
-- No package 'libdc1394' found
-- Looking for linux/videodev.h
-- Looking for linux/videodev.h - not found
-- Looking for linux/videodev2.h
-- Looking for linux/videodev2.h - found
-- Looking for sys/videoio.h
-- Looking for sys/videoio.h - not found
-- Checking for module 'libavresample'
-- No package 'libavresample' found
-- Looking for libavformat/avformat.h
-- Looking for libavformat/avformat.h - found
-- Looking for ffmpeg/avformat.h
-- Looking for ffmpeg/avformat.h - not found
-- Checking for module 'libgphoto2'
-- No package 'libgphoto2' found
-- CUDA detected: 9.0
-- CUDA NVCC target flags: -gencode;arch=compute_53,code=sm_53
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- To enable PlantUML support, set PLANTUML_JAR environment variable or pass -DPLANTUML_JAR=<filepath> option to cmake
-- Could NOT find PythonInterp: Found unsuitable version "1.4", but required is at least "2.7" (found /home/ubuntu/.virtualenvs/cv/bin/pyhon)
-- Could NOT find PythonInterp: Found unsuitable version "1.4", but required is at least "2.6" (found /home/ubuntu/.virtualenvs/cv/bin/pyhon)
-- Could NOT find PythonInterp: Found unsuitable version "1.4", but required is at least "3.4" (found /home/ubuntu/.virtualenvs/cv/bin/pyhon)
-- Could NOT find PythonInterp: Found unsuitable version "1.4", but required is at least "3.2" (found /home/ubuntu/.virtualenvs/cv/bin/pyhon)
-- Could NOT find JNI (missing: JAVA_AWT_LIBRARY JAVA_JVM_LIBRARY JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH2 JAVA_AWT_INCLUDE_PATH)
-- Could NOT find Matlab (missing: MATLAB_MEX_SCRIPT MATLAB_INCLUDE_DIRS MATLAB_ROOT_DIR MATLAB_LIBRARIES MATLAB_LIBRARY_DIRS MATLAB_MEXEXT MATLAB_ARCH MATLAB_BIN)
-- VTK is not found. Please set -DVTK_DIR in CMake to VTK build directory, or to VTK install subdirectory with VTKConfig.cmake file
-- Caffe: NO
-- Protobuf: YES
-- Glog: NO
-- Could NOT find HDF5 (missing: HDF5_LIBRARIES HDF5_INCLUDE_DIRS) (found version "")
-- Module opencv_sfm disabled because the following dependencies are not found: Glog/Gflags
-- Tesseract: NO
CMake Warning at /usr/local/share/cmake-3.13/Modules/FindProtobuf.cmake:495 (message):
Protobuf compiler version doesn't match library version 2.6.1
Call Stack (most recent call first):
/mnt/data/Software/opencv_contrib-3.1.0/modules/dnn/cmake/OpenCVFindLibProtobuf.cmake:4 (find_package)
/mnt/data/Software/opencv_contrib-3.1.0/modules/dnn/CMakeLists.txt:17 (include)
-- Build libprotobuf from sources:
-- The protocol buffer compiler not found
-- Tesseract: NO
-- General configuration for OpenCV 3.1.0 =====================================
-- Version control: unknown
-- Platform:
-- Host: Linux 4.4.38-tegra aarch64
-- CMake: 3.13.4
-- CMake generator: Unix Makefiles
-- CMake build tool: /usr/bin/make
-- Configuration: RELEASE
-- C/C++:
-- Built as dynamic libs?: YES
-- C++ Compiler: /usr/bin/c++ (ver 5.4.0)
-- C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wno-narrowing -Wno-delete-non-virtual-dtor -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
-- C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wno-narrowing -Wno-delete-non-virtual-dtor -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
-- C Compiler: /usr/bin/cc
-- C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wno-narrowing -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
-- C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wno-narrowing -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
-- Linker flags (Release):
-- Linker flags (Debug):
-- Precompiled headers: NO
-- Extra dependencies: /usr/lib/aarch64-linux-gnu/libpng.so /usr/lib/aarch64-linux-gnu/libz.so /usr/lib/aarch64-linux-gnu/libtiff.so /usr/lib/aarch64-linux-gnu/libjasper.so /usr/lib/aarch64-linux-gnu/libjpeg.so gtk-3 gdk-3 pangocairo-1.0 pango-1.0 atk-1.0 cairo-gobject cairo gdk_pixbuf-2.0 gio-2.0 gthread-2.0 gstvideo-1.0 gstapp-1.0 gstbase-1.0 gstriff-1.0 gstpbutils-1.0 gstreamer-1.0 gobject-2.0 glib-2.0 v4l1 v4l2 avcodec-ffmpeg avformat-ffmpeg avutil-ffmpeg swscale-ffmpeg dl m pthread rt cudart nppc CUDA_nppi_LIBRARY-NOTFOUND npps cufft -L/usr/local/cuda/lib64
-- 3rdparty dependencies: libwebp IlmImf libprotobuf
-- OpenCV modules:
-- To be built: cudev core cudaarithm flann imgproc ml reg surface_matching video cudabgsegm cudafilters cudaimgproc cudawarping dnn fuzzy imgcodecs photo shape videoio cudacodec highgui objdetect plot ts xobjdetect xphoto bgsegm bioinspired dpm face features2d line_descriptor saliency text calib3d ccalib cudafeatures2d cudalegacy cudaobjdetect cudaoptflow cudastereo datasets rgbd stereo structured_light superres tracking videostab xfeatures2d ximgproc aruco optflow stitching
-- Disabled: world contrib_world
-- Disabled by dependency: -
-- Unavailable: java python2 python3 viz cvv hdf matlab sfm
-- GUI:
-- QT: NO
-- GTK+ 3.x: YES (ver 3.18.9)
-- GThread : YES (ver 2.48.2)
-- GtkGlExt: NO
-- OpenGL support: NO
-- VTK support: NO
-- Media I/O:
-- ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.8)
-- JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver )
-- WEBP: build (ver 0.3.1)
-- PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.2.54)
-- TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 - 4.0.6)
-- JPEG 2000: /usr/lib/aarch64-linux-gnu/libjasper.so (ver 1.900.1)
-- OpenEXR: build (ver 1.7.1)
-- GDAL: NO
-- Video I/O:
-- DC1394 1.x: NO
-- DC1394 2.x: NO
-- FFMPEG: YES
-- codec: YES (ver 56.60.100)
-- format: YES (ver 56.40.101)
-- util: YES (ver 54.31.100)
-- swscale: YES (ver 3.1.101)
-- resample: NO
-- gentoo-style: YES
-- GStreamer:
-- base: YES (ver 1.8.3)
-- video: YES (ver 1.8.3)
-- app: YES (ver 1.8.3)
-- riff: YES (ver 1.8.3)
-- pbutils: YES (ver 1.8.3)
-- OpenNI: NO
-- OpenNI PrimeSensor Modules: NO
-- OpenNI2: NO
-- PvAPI: NO
-- GigEVisionSDK: NO
-- UniCap: NO
-- UniCap ucil: NO
-- V4L/V4L2: Using libv4l1 (ver 1.10.0) / libv4l2 (ver 1.10.0)
-- XIMEA: NO
-- Xine: NO
-- gPhoto2: NO
-- Parallel framework: pthreads
-- Other third-party libraries:
-- Use IPP: NO
-- Use VA: NO
-- Use Intel VA-API/OpenCL: NO
-- Use Eigen: YES (ver 3.2.92)
-- Use Cuda: YES (ver 9.0)
-- Use OpenCL: YES
-- Use custom HAL: NO
-- NVIDIA CUDA
-- Use CUFFT: YES
-- Use CUBLAS: NO
-- USE NVCUVID: NO
-- NVIDIA GPU arch: 53
-- NVIDIA PTX archs:
-- Use fast math: NO
-- OpenCL:
-- Version: dynamic
-- Include path: /mnt/data/Software/opencv-3.1.0/3rdparty/include/opencl/1.2
-- Use AMDFFT: NO
-- Use AMDBLAS: NO
-- Python 2:
-- Interpreter: NO
-- Python 3:
-- Interpreter: NO
-- Python (for build): NO
-- Java:
-- ant: NO
-- JNI: NO
-- Java wrappers: NO
-- Java tests: NO
-- Matlab: Matlab not found or implicitly disabled
-- Documentation:
-- Doxygen: NO
-- PlantUML: NO
-- Tests and samples:
-- Tests: YES
-- Performance tests: YES
-- C/C++ Examples: YES
-- Install path: /usr/local
-- cvconfig.h is in: /mnt/data/Software/opencv-3.1.0/build
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUDA_nppi_LIBRARY (ADVANCED)
linked by target "opencv_cudev" in directory /mnt/data/Software/opencv-3.1.0/modules/cudev
linked by target "opencv_test_cudev" in directory /mnt/data/Software/opencv-3.1.0/modules/cudev/test
linked by target "opencv_core" in directory /mnt/data/Software/opencv-3.1.0/modules/core
linked by target "opencv_test_core" in directory /mnt/data/Software/opencv-3.1.0/modules/core
linked by target "opencv_perf_core" in directory /mnt/data/Software/opencv-3.1.0/modules/core
linked by target "opencv_test_cudaarithm" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaarithm
linked by target "opencv_perf_cudaarithm" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaarithm
linked by target "opencv_cudaarithm" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaarithm
linked by target "opencv_test_flann" in directory /mnt/data/Software/opencv-3.1.0/modules/flann
linked by target "opencv_flann" in directory /mnt/data/Software/opencv-3.1.0/modules/flann
linked by target "opencv_test_imgproc" in directory /mnt/data/Software/opencv-3.1.0/modules/imgproc
linked by target "opencv_perf_imgproc" in directory /mnt/data/Software/opencv-3.1.0/modules/imgproc
linked by target "opencv_imgproc" in directory /mnt/data/Software/opencv-3.1.0/modules/imgproc
linked by target "opencv_test_ml" in directory /mnt/data/Software/opencv-3.1.0/modules/ml
linked by target "opencv_ml" in directory /mnt/data/Software/opencv-3.1.0/modules/ml
linked by target "opencv_perf_reg" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/reg
linked by target "opencv_test_reg" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/reg
linked by target "opencv_reg" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/reg
linked by target "opencv_surface_matching" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/surface_matching
linked by target "opencv_test_video" in directory /mnt/data/Software/opencv-3.1.0/modules/video
linked by target "opencv_video" in directory /mnt/data/Software/opencv-3.1.0/modules/video
linked by target "opencv_perf_video" in directory /mnt/data/Software/opencv-3.1.0/modules/video
linked by target "opencv_perf_cudabgsegm" in directory /mnt/data/Software/opencv-3.1.0/modules/cudabgsegm
linked by target "opencv_test_cudabgsegm" in directory /mnt/data/Software/opencv-3.1.0/modules/cudabgsegm
linked by target "opencv_cudabgsegm" in directory /mnt/data/Software/opencv-3.1.0/modules/cudabgsegm
linked by target "opencv_perf_cudafilters" in directory /mnt/data/Software/opencv-3.1.0/modules/cudafilters
linked by target "opencv_test_cudafilters" in directory /mnt/data/Software/opencv-3.1.0/modules/cudafilters
linked by target "opencv_cudafilters" in directory /mnt/data/Software/opencv-3.1.0/modules/cudafilters
linked by target "opencv_test_cudaimgproc" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaimgproc
linked by target "opencv_cudaimgproc" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaimgproc
linked by target "opencv_perf_cudaimgproc" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaimgproc
linked by target "opencv_perf_cudawarping" in directory /mnt/data/Software/opencv-3.1.0/modules/cudawarping
linked by target "opencv_test_cudawarping" in directory /mnt/data/Software/opencv-3.1.0/modules/cudawarping
linked by target "opencv_cudawarping" in directory /mnt/data/Software/opencv-3.1.0/modules/cudawarping
linked by target "opencv_test_dnn" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/dnn
linked by target "opencv_dnn" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/dnn
linked by target "opencv_fuzzy" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/fuzzy
linked by target "opencv_test_fuzzy" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/fuzzy
linked by target "opencv_perf_imgcodecs" in directory /mnt/data/Software/opencv-3.1.0/modules/imgcodecs
linked by target "opencv_imgcodecs" in directory /mnt/data/Software/opencv-3.1.0/modules/imgcodecs
linked by target "opencv_test_imgcodecs" in directory /mnt/data/Software/opencv-3.1.0/modules/imgcodecs
linked by target "opencv_perf_photo" in directory /mnt/data/Software/opencv-3.1.0/modules/photo
linked by target "opencv_test_photo" in directory /mnt/data/Software/opencv-3.1.0/modules/photo
linked by target "opencv_photo" in directory /mnt/data/Software/opencv-3.1.0/modules/photo
linked by target "opencv_test_shape" in directory /mnt/data/Software/opencv-3.1.0/modules/shape
linked by target "opencv_shape" in directory /mnt/data/Software/opencv-3.1.0/modules/shape
linked by target "opencv_perf_videoio" in directory /mnt/data/Software/opencv-3.1.0/modules/videoio
linked by target "opencv_test_videoio" in directory /mnt/data/Software/opencv-3.1.0/modules/videoio
linked by target "opencv_videoio" in directory /mnt/data/Software/opencv-3.1.0/modules/videoio
linked by target "opencv_test_cudacodec" in directory /mnt/data/Software/opencv-3.1.0/modules/cudacodec
linked by target "opencv_perf_cudacodec" in directory /mnt/data/Software/opencv-3.1.0/modules/cudacodec
linked by target "opencv_cudacodec" in directory /mnt/data/Software/opencv-3.1.0/modules/cudacodec
linked by target "opencv_test_highgui" in directory /mnt/data/Software/opencv-3.1.0/modules/highgui
linked by target "opencv_highgui" in directory /mnt/data/Software/opencv-3.1.0/modules/highgui
linked by target "opencv_perf_objdetect" in directory /mnt/data/Software/opencv-3.1.0/modules/objdetect
linked by target "opencv_test_objdetect" in directory /mnt/data/Software/opencv-3.1.0/modules/objdetect
linked by target "opencv_objdetect" in directory /mnt/data/Software/opencv-3.1.0/modules/objdetect
linked by target "opencv_plot" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/plot
linked by target "opencv_ts" in directory /mnt/data/Software/opencv-3.1.0/modules/ts
linked by target "opencv_xobjdetect" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/xobjdetect
linked by target "opencv_perf_xphoto" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/xphoto
linked by target "opencv_test_xphoto" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/xphoto
linked by target "opencv_xphoto" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/xphoto
linked by target "opencv_bgsegm" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/bgsegm
linked by target "opencv_test_bgsegm" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/bgsegm
linked by target "opencv_perf_bioinspired" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/bioinspired
linked by target "opencv_test_bioinspired" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/bioinspired
linked by target "opencv_bioinspired" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/bioinspired
linked by target "opencv_dpm" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/dpm
linked by target "opencv_face" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/face
linked by target "opencv_perf_features2d" in directory /mnt/data/Software/opencv-3.1.0/modules/features2d
linked by target "opencv_test_features2d" in directory /mnt/data/Software/opencv-3.1.0/modules/features2d
linked by target "opencv_features2d" in directory /mnt/data/Software/opencv-3.1.0/modules/features2d
linked by target "opencv_perf_line_descriptor" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/line_descriptor
linked by target "opencv_test_line_descriptor" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/line_descriptor
linked by target "opencv_line_descriptor" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/line_descriptor
linked by target "opencv_saliency" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/saliency
linked by target "opencv_text" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/text
linked by target "opencv_calib3d" in directory /mnt/data/Software/opencv-3.1.0/modules/calib3d
linked by target "opencv_perf_calib3d" in directory /mnt/data/Software/opencv-3.1.0/modules/calib3d
linked by target "opencv_test_calib3d" in directory /mnt/data/Software/opencv-3.1.0/modules/calib3d
linked by target "opencv_ccalib" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/ccalib
linked by target "opencv_test_cudafeatures2d" in directory /mnt/data/Software/opencv-3.1.0/modules/cudafeatures2d
linked by target "opencv_cudafeatures2d" in directory /mnt/data/Software/opencv-3.1.0/modules/cudafeatures2d
linked by target "opencv_perf_cudafeatures2d" in directory /mnt/data/Software/opencv-3.1.0/modules/cudafeatures2d
linked by target "opencv_perf_cudalegacy" in directory /mnt/data/Software/opencv-3.1.0/modules/cudalegacy
linked by target "opencv_test_cudalegacy" in directory /mnt/data/Software/opencv-3.1.0/modules/cudalegacy
linked by target "opencv_cudalegacy" in directory /mnt/data/Software/opencv-3.1.0/modules/cudalegacy
linked by target "opencv_perf_cudaobjdetect" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaobjdetect
linked by target "opencv_test_cudaobjdetect" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaobjdetect
linked by target "opencv_cudaobjdetect" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaobjdetect
linked by target "opencv_perf_cudaoptflow" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaoptflow
linked by target "opencv_cudaoptflow" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaoptflow
linked by target "opencv_test_cudaoptflow" in directory /mnt/data/Software/opencv-3.1.0/modules/cudaoptflow
linked by target "opencv_test_cudastereo" in directory /mnt/data/Software/opencv-3.1.0/modules/cudastereo
linked by target "opencv_perf_cudastereo" in directory /mnt/data/Software/opencv-3.1.0/modules/cudastereo
linked by target "opencv_cudastereo" in directory /mnt/data/Software/opencv-3.1.0/modules/cudastereo
linked by target "opencv_datasets" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/datasets
linked by target "opencv_test_rgbd" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/rgbd
linked by target "opencv_rgbd" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/rgbd
linked by target "opencv_perf_stereo" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/stereo
linked by target "opencv_stereo" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/stereo
linked by target "opencv_test_stereo" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/stereo
linked by target "opencv_test_structured_light" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/structured_light
linked by target "opencv_structured_light" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/structured_light
linked by target "opencv_perf_superres" in directory /mnt/data/Software/opencv-3.1.0/modules/superres
linked by target "opencv_superres" in directory /mnt/data/Software/opencv-3.1.0/modules/superres
linked by target "opencv_test_superres" in directory /mnt/data/Software/opencv-3.1.0/modules/superres
linked by target "opencv_perf_tracking" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/tracking
linked by target "opencv_test_tracking" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/tracking
linked by target "opencv_tracking" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/tracking
linked by target "opencv_videostab" in directory /mnt/data/Software/opencv-3.1.0/modules/videostab
linked by target "opencv_perf_xfeatures2d" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/xfeatures2d
linked by target "opencv_test_xfeatures2d" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/xfeatures2d
linked by target "opencv_xfeatures2d" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/xfeatures2d
linked by target "opencv_perf_ximgproc" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/ximgproc
linked by target "opencv_test_ximgproc" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/ximgproc
linked by target "opencv_ximgproc" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/ximgproc
linked by target "opencv_test_aruco" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/aruco
linked by target "opencv_aruco" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/aruco
linked by target "opencv_test_optflow" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/optflow
linked by target "opencv_optflow" in directory /mnt/data/Software/opencv_contrib-3.1.0/modules/optflow
linked by target "opencv_perf_stitching" in directory /mnt/data/Software/opencv-3.1.0/modules/stitching
linked by target "opencv_test_stitching" in directory /mnt/data/Software/opencv-3.1.0/modules/stitching
linked by target "opencv_stitching" in directory /mnt/data/Software/opencv-3.1.0/modules/stitching
linked by target "opencv_traincascade" in directory /mnt/data/Software/opencv-3.1.0/apps/traincascade
linked by target "opencv_createsamples" in directory /mnt/data/Software/opencv-3.1.0/apps/createsamples
linked by target "opencv_annotation" in directory /mnt/data/Software/opencv-3.1.0/apps/annotation
linked by target "cpp-tutorial-pnp_detection" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_watershed" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_tvl1_optical_flow" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_LATCH_match" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_cloning_gui" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_decolor" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_objectDetection2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_objectDetection" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_non_linear_svms" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_introduction_to_svm" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_introduction_to_pca" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_introduction_windows_vs" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_AKAZE_match" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_mat_mask_operations" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_interoperability_with_OpenCV_1" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_file_input_output" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_discrete_fourier_transform" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Drawing_2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_camera_calibration" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_cornerSubPix_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_hull_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_generalContours_demo1" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_findContours_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_cloning_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_imageSegmentation" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_filter2D_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_logistic_regression" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_mask_tmpl" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_edge" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_stereo_calib" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "cpp-tutorial-pnp_registration" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_lsd_lines" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_minarea" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_intelperc_capture" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_detect_blob" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_imagelist_creator" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_planar_tracking" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Morphology_1" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_display_image" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_kalman" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_image_sequence" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_CannyDetector_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Laplace_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_hdr_imaging" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_polar_transforms" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_image" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_houghlines" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_kmeans" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_houghcircles" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_filestorage" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_ffilldemo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_mat_the_basic_image_container" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_lkdemo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_pointPolygonTest_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_fback" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_stitching_detailed" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_fitellipse" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_facedetect" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Smoothing" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_connected_components" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_cloning_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_letter_recog" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_moments_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_dbt_face_detection" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_camshiftdemo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_pca" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_bg_sub" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_stitching" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_autofocus" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_contours2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_HoughLines_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_detect_mser" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_phase_corr" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_cornerHarris_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_compareHist_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_facial_features" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_starter_video" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_convexhull" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_dft" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_calibration" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_inpaint" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_generalContours_demo2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_create_mask" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_npr_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Morphology_3" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_starter_imagelist" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_cornerDetector_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_select3dobj" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_bgfg_segm" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_tree_engine" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_grabcut" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_video-write" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_delaunay2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Geometric_Transforms_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_laplace" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_calcBackProject_Demo1" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Drawing_1" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_example" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_distrans" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_image_alignment" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_EqualizeHist_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_videostab" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_video-input-psnr-ssim" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_matchmethod_orb_akaze_brisk" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_npr_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_morphology2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_gpu-basics-similarity" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_opencv_version" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_how_to_scan_images" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_openni_capture" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_BasicLinearTransformsTrackbar" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_demhist" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_train_HOG" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_points_classifier" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_3calibration" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_segment_objects" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_shape_example" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_SBM_Sample" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_squares" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_stereo_match" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_goodFeaturesToTrack_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_BasicLinearTransforms" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_copyMakeBorder_demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_cloning_gui" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_AddingImagesTrackbar" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_gdal-image" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_calcBackProject_Demo2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_em" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_calcHist_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_cout_mat" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_AddingImages" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Morphology_2" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_smiledetect" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Remap_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Pyramids" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Threshold" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_HoughCircle_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_MatchTemplate_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_drawing" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "tutorial_Sobel_Demo" in directory /mnt/data/Software/opencv-3.1.0/samples/cpp
linked by target "example_gpu_hog" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_generalized_hough" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_houghlines" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_optical_flow" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_alpha_comp" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_bgfg_segm" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_morphology" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_surf_keypoint_matcher" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_video_reader" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_farneback_optical_flow" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_performance" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_stereo_multi" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_opticalflow_nvidia_api" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_driver_api_multi" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_cascadeclassifier_nvidia_api" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_pyrlk_optical_flow" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_stereo_match" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_driver_api_stereo_multi" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_cascadeclassifier" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_super_resolution" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_multi" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_gpu_video_writer" in directory /mnt/data/Software/opencv-3.1.0/samples/gpu
linked by target "example_tapi_hog" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
linked by target "example_tapi_camshift" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
linked by target "example_tapi_bgfg_segm" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
linked by target "example_tapi_squares" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
linked by target "example_tapi_pyrlk_optical_flow" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
linked by target "example_tapi_tvl1_optical_flow" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
linked by target "example_tapi_clahe" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
linked by target "example_tapi_ufacedetect" in directory /mnt/data/Software/opencv-3.1.0/samples/tapi
-- Configuring incomplete, errors occurred!
See also "/mnt/data/Software/opencv-3.1.0/build/CMakeFiles/CMakeOutput.log".
See also "/mnt/data/Software/opencv-3.1.0/build/CMakeFiles/CMakeError.log".
