Jetson TK1 and opencv 3.2.0
Hello guys,
I’m trying to build opencv 3.2.0 with CUDA 6.5 on Jetson TK1. However I always failed on compiling. Would you like to share me some instructions on building opencv 3.2.0 on Jetson TK1?
Another question is about JetPack 3.0. I noticed that the JetPack 3.0 will be released on 14th March. It has got the latest CUDA 8.0 on it. I want to know does the JetPack 3.0 supports Jetson TK1? If so I think I will try to build opencv 3.2.0 on the latest JetPack.
Regards,
Dawen
Have a look to [url]http://docs.opencv.org/3.2.0/d6/d15/tutorial_building_tegra_cuda.html[/url]
There are instructions for building on TK1.
Hi Honey_Patouceul. Thank you for your replying.
I was following this instructions, but I failed on make. Have you succeed on building?
What are the error messages when it fails ?
Have you set LD_LIBRARY_PATH such as :
export LD_LIBRARY_PATH=/usr/local/cuda/lib
Hi, Below are the main error part I got from make.
CMake Error at cuda_compile_generated_pyrlk.cu.o.cmake:264 (message):
Error generating file
/home/shelton/src/opencv-3.2.0/build/modules/world/CMakeFiles/cuda_compile.dir/__/cudaoptflow/src/cuda/./cuda_compile_generated_pyrlk.cu.o
modules/world/CMakeFiles/opencv_world.dir/build.make:28909: recipe for target 'modules/world/CMakeFiles/cuda_compile.dir//cudaoptflow/src/cuda/cuda_compile_generated_pyrlk.cu.o’ failed
make[2]: *** [modules/world/CMakeFiles/cuda_compile.dir/
/cudaoptflow/src/cuda/cuda_compile_generated_pyrlk.cu.o] Error 1
CMakeFiles/Makefile2:1289: recipe for target ‘modules/world/CMakeFiles/opencv_world.dir/all’ failed
make[1]: *** [modules/world/CMakeFiles/opencv_world.dir/all] Error 2
Makefile:160: recipe for target ‘all’ failed
make: *** [all] Error 2
I have just built it now for being sure. My TK1 has L4T R21.5.
Note: I use a build folder build/TK1 parallel to source tree opencv-3.2.0, so my build is not inside my src tree :
+- opencv-3.2.0    #source tree
+- build
   +- TK1          #build for TK1
I assume you’ve cuda-6.5 installed. These are the basic steps I’ve used:
  1. Install required or optional packages :
sudo apt-get install \
    libglew-dev \
    libtiff5-dev \
    zlib1g-dev \
    libjpeg-dev \
    libpng12-dev \
    libjasper-dev \
    libavcodec-dev \
    libavformat-dev \
    libavutil-dev \
    libpostproc-dev \
    libswscale-dev \
    libeigen3-dev \
    libtbb-dev \
    libgtk2.0-dev \
    pkg-config \
    libatlas3-base \
    libblas3 \
    python-dev \
    python-numpy \
    python-py \
    python-pytest
Should install everything without error.
  1. Configure
cmake \
    -DCMAKE_BUILD_TYPE=Release \
    -DCMAKE_INSTALL_PREFIX=/usr/local/opencv-3.2.0 \
    -DCMAKE_CXX_FLAGS=-Wa,-mimplicit-it=thumb \
    -DBUILD_PNG=OFF \
    -DBUILD_TIFF=OFF \
    -DBUILD_TBB=OFF \
    -DBUILD_JPEG=OFF \
    -DBUILD_JASPER=OFF \
    -DBUILD_ZLIB=OFF \
    -DBUILD_EXAMPLES=ON \
    -DBUILD_opencv_java=OFF \
    -DBUILD_opencv_python2=ON \
    -DBUILD_opencv_python3=OFF \
    -DENABLE_NEON=ON \
    -DWITH_OPENCL=OFF \
    -DWITH_OPENMP=OFF \
    -DWITH_FFMPEG=ON \
    -DWITH_GSTREAMER=OFF \
    -DWITH_GSTREAMER_0_10=OFF \
    -DWITH_CUDA=ON \
    -DWITH_GTK=ON \
    -DWITH_VTK=OFF \
    -DWITH_TBB=ON \
    -DWITH_1394=OFF \
    -DWITH_OPENEXR=OFF \
    -DCUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-6.5 \
    -DCUDA_ARCH_BIN=3.2 \
    -DCUDA_ARCH_PTX=""  \
    -DCUDA_FAST_MATH=ON \
    -DINSTALL_C_EXAMPLES=ON \
    -DINSTALL_TESTS=OFF \
    -DOPENCV_TEST_DATA_PATH=../../../testdata/opencv_extra/testdata \
    ../../opencv-3.2.0
should configure without error. Here is my output:
-- The CXX compiler identification is GNU 4.8.4
-- The C compiler identification is GNU 4.8.4
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detected version of GNU GCC: 48 (408)
-- Performing Test HAVE_CXX_FSIGNED_CHAR
-- Performing Test HAVE_CXX_FSIGNED_CHAR - Success
-- Performing Test HAVE_C_FSIGNED_CHAR
-- Performing Test HAVE_C_FSIGNED_CHAR - Success
-- Performing Test HAVE_CXX_W
-- Performing Test HAVE_CXX_W - Success
-- Performing Test HAVE_C_W
-- Performing Test HAVE_C_W - Success
-- Performing Test HAVE_CXX_WALL
-- Performing Test HAVE_CXX_WALL - Success
-- Performing Test HAVE_C_WALL
-- Performing Test HAVE_C_WALL - Success
-- Performing Test HAVE_CXX_WERROR_RETURN_TYPE
-- Performing Test HAVE_CXX_WERROR_RETURN_TYPE - Success
-- Performing Test HAVE_C_WERROR_RETURN_TYPE
-- Performing Test HAVE_C_WERROR_RETURN_TYPE - Success
-- Performing Test HAVE_CXX_WERROR_NON_VIRTUAL_DTOR
-- Performing Test HAVE_CXX_WERROR_NON_VIRTUAL_DTOR - Success
-- Performing Test HAVE_C_WERROR_NON_VIRTUAL_DTOR
-- Performing Test HAVE_C_WERROR_NON_VIRTUAL_DTOR - Success
-- Performing Test HAVE_CXX_WERROR_ADDRESS
-- Performing Test HAVE_CXX_WERROR_ADDRESS - Success
-- Performing Test HAVE_C_WERROR_ADDRESS
-- Performing Test HAVE_C_WERROR_ADDRESS - Success
-- Performing Test HAVE_CXX_WERROR_SEQUENCE_POINT
-- Performing Test HAVE_CXX_WERROR_SEQUENCE_POINT - Success
-- Performing Test HAVE_C_WERROR_SEQUENCE_POINT
-- Performing Test HAVE_C_WERROR_SEQUENCE_POINT - Success
-- Performing Test HAVE_CXX_WFORMAT
-- Performing Test HAVE_CXX_WFORMAT - Success
-- Performing Test HAVE_C_WFORMAT
-- Performing Test HAVE_C_WFORMAT - Success
-- Performing Test HAVE_CXX_WERROR_FORMAT_SECURITY
-- Performing Test HAVE_CXX_WERROR_FORMAT_SECURITY - Success
-- Performing Test HAVE_C_WERROR_FORMAT_SECURITY
-- Performing Test HAVE_C_WERROR_FORMAT_SECURITY - Success
-- Performing Test HAVE_CXX_WMISSING_DECLARATIONS
-- Performing Test HAVE_CXX_WMISSING_DECLARATIONS - Success
-- Performing Test HAVE_C_WMISSING_DECLARATIONS
-- Performing Test HAVE_C_WMISSING_DECLARATIONS - Success
-- Performing Test HAVE_CXX_WMISSING_PROTOTYPES
-- Performing Test HAVE_CXX_WMISSING_PROTOTYPES - Failed
-- Performing Test HAVE_C_WMISSING_PROTOTYPES
-- Performing Test HAVE_C_WMISSING_PROTOTYPES - Success
-- Performing Test HAVE_CXX_WSTRICT_PROTOTYPES
-- Performing Test HAVE_CXX_WSTRICT_PROTOTYPES - Failed
-- Performing Test HAVE_C_WSTRICT_PROTOTYPES
-- Performing Test HAVE_C_WSTRICT_PROTOTYPES - Success
-- Performing Test HAVE_CXX_WUNDEF
-- Performing Test HAVE_CXX_WUNDEF - Success
-- Performing Test HAVE_C_WUNDEF
-- Performing Test HAVE_C_WUNDEF - Success
-- Performing Test HAVE_CXX_WINIT_SELF
-- Performing Test HAVE_CXX_WINIT_SELF - Success
-- Performing Test HAVE_C_WINIT_SELF
-- Performing Test HAVE_C_WINIT_SELF - Success
-- Performing Test HAVE_CXX_WPOINTER_ARITH
-- Performing Test HAVE_CXX_WPOINTER_ARITH - Success
-- Performing Test HAVE_C_WPOINTER_ARITH
-- Performing Test HAVE_C_WPOINTER_ARITH - Success
-- Performing Test HAVE_CXX_WSHADOW
-- Performing Test HAVE_CXX_WSHADOW - Success
-- Performing Test HAVE_C_WSHADOW
-- Performing Test HAVE_C_WSHADOW - Success
-- Performing Test HAVE_CXX_WSIGN_PROMO
-- Performing Test HAVE_CXX_WSIGN_PROMO - Success
-- Performing Test HAVE_C_WSIGN_PROMO
-- Performing Test HAVE_C_WSIGN_PROMO - Failed
-- Performing Test HAVE_CXX_WNO_NARROWING
-- Performing Test HAVE_CXX_WNO_NARROWING - Success
-- Performing Test HAVE_C_WNO_NARROWING
-- Performing Test HAVE_C_WNO_NARROWING - Success
-- Performing Test HAVE_CXX_WNO_DELETE_NON_VIRTUAL_DTOR
-- Performing Test HAVE_CXX_WNO_DELETE_NON_VIRTUAL_DTOR - Success
-- Performing Test HAVE_C_WNO_DELETE_NON_VIRTUAL_DTOR
-- Performing Test HAVE_C_WNO_DELETE_NON_VIRTUAL_DTOR - Failed
-- Performing Test HAVE_CXX_WNO_UNNAMED_TYPE_TEMPLATE_ARGS
-- Performing Test HAVE_CXX_WNO_UNNAMED_TYPE_TEMPLATE_ARGS - Failed
-- Performing Test HAVE_C_WNO_UNNAMED_TYPE_TEMPLATE_ARGS
-- Performing Test HAVE_C_WNO_UNNAMED_TYPE_TEMPLATE_ARGS - Failed
-- Performing Test HAVE_CXX_WNO_COMMENT
-- Performing Test HAVE_CXX_WNO_COMMENT - Success
-- Performing Test HAVE_C_WNO_COMMENT
-- Performing Test HAVE_C_WNO_COMMENT - Success
-- Performing Test HAVE_CXX_FDIAGNOSTICS_SHOW_OPTION
-- Performing Test HAVE_CXX_FDIAGNOSTICS_SHOW_OPTION - Success
-- Performing Test HAVE_C_FDIAGNOSTICS_SHOW_OPTION
-- Performing Test HAVE_C_FDIAGNOSTICS_SHOW_OPTION - Success
-- Performing Test HAVE_CXX_PTHREAD
-- Performing Test HAVE_CXX_PTHREAD - Success
-- Performing Test HAVE_C_PTHREAD
-- Performing Test HAVE_C_PTHREAD - Success
-- Performing Test HAVE_CXX_FOMIT_FRAME_POINTER
-- Performing Test HAVE_CXX_FOMIT_FRAME_POINTER - Success
-- Performing Test HAVE_C_FOMIT_FRAME_POINTER
-- Performing Test HAVE_C_FOMIT_FRAME_POINTER - Success
-- Performing Test HAVE_CXX_MFP16_FORMAT_IEEE
-- Performing Test HAVE_CXX_MFP16_FORMAT_IEEE - Success
-- Performing Test HAVE_C_MFP16_FORMAT_IEEE
-- Performing Test HAVE_C_MFP16_FORMAT_IEEE - Success
-- Performing Test HAVE_CXX_MFPU_NEON
-- Performing Test HAVE_CXX_MFPU_NEON - Success
-- Performing Test HAVE_C_MFPU_NEON
-- Performing Test HAVE_C_MFPU_NEON - Success
-- Performing Test HAVE_CXX_FFUNCTION_SECTIONS
-- Performing Test HAVE_CXX_FFUNCTION_SECTIONS - Success
-- Performing Test HAVE_C_FFUNCTION_SECTIONS
-- Performing Test HAVE_C_FFUNCTION_SECTIONS - Success
-- Performing Test HAVE_CXX_FVISIBILITY_HIDDEN
-- Performing Test HAVE_CXX_FVISIBILITY_HIDDEN - Success
-- Performing Test HAVE_C_FVISIBILITY_HIDDEN
-- Performing Test HAVE_C_FVISIBILITY_HIDDEN - Success
-- Performing Test HAVE_CXX_FVISIBILITY_INLINES_HIDDEN
-- Performing Test HAVE_CXX_FVISIBILITY_INLINES_HIDDEN - Success
-- Performing Test HAVE_C_FVISIBILITY_INLINES_HIDDEN
-- Performing Test HAVE_C_FVISIBILITY_INLINES_HIDDEN - Failed
-- FP16: Compiler support is available
-- Performing Test HAVE_CXX_MFPU_NEON_FP16
-- Performing Test HAVE_CXX_MFPU_NEON_FP16 - Success
-- Performing Test HAVE_C_MFPU_NEON_FP16
-- Performing Test HAVE_C_MFPU_NEON_FP16 - Success
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Using unsigned short
-- Check if the system is big endian - little endian
-- Found ZLIB: /usr/lib/arm-linux-gnueabihf/libz.so (found suitable version "1.2.8", minimum required is "1.2.3")
-- Found TIFF: /usr/lib/arm-linux-gnueabihf/libtiff.so (found version "4.0.3")
-- Found JPEG: /usr/lib/arm-linux-gnueabihf/libjpeg.so
-- Performing Test HAVE_C_WNO_UNUSED_VARIABLE
-- Performing Test HAVE_C_WNO_UNUSED_VARIABLE - Success
-- Performing Test HAVE_C_WNO_UNUSED_FUNCTION
-- Performing Test HAVE_C_WNO_UNUSED_FUNCTION - Success
-- Performing Test HAVE_C_WNO_SHADOW
-- Performing Test HAVE_C_WNO_SHADOW - Success
-- Performing Test HAVE_C_WNO_MAYBE_UNINITIALIZED
-- Performing Test HAVE_C_WNO_MAYBE_UNINITIALIZED - Success
-- Found Jasper: /usr/lib/arm-linux-gnueabihf/libjasper.so (found version "1.900.1")
-- Found ZLIB: /usr/lib/arm-linux-gnueabihf/libz.so (found version "1.2.8")
-- Found PNG: /usr/lib/arm-linux-gnueabihf/libpng.so (found version "1.2.50")
-- Looking for /usr/include/libpng/png.h
-- Looking for /usr/include/libpng/png.h - found
-- checking for module 'gtk+-3.0'
--   package 'gtk+-3.0' not found
-- checking for module 'gtk+-2.0'
--   found gtk+-2.0, version 2.24.23
-- checking for module 'gthread-2.0'
--   found gthread-2.0, version 2.40.2
-- Looking for linux/videodev.h
-- Looking for linux/videodev.h - not found
-- Looking for linux/videodev2.h
-- Looking for linux/videodev2.h - found
-- Looking for sys/videoio.h
-- Looking for sys/videoio.h - not found
-- checking for modules 'libavcodec;libavformat;libavutil;libswscale'
--   found libavcodec, version 54.35.1
--   found libavformat, version 54.20.4
--   found libavutil, version 52.3.0
--   found libswscale, version 2.1.1
-- checking for module 'libavresample'
--   package 'libavresample' not found
-- checking for module 'libgphoto2'
--   package 'libgphoto2' not found
-- Found TBB: /usr/lib/libtbb.so
-- CUDA detected: 6.5
-- CUDA NVCC target flags: -gencode;arch=compute_32,code=sm_32;-D_FORCE_INLINES
-- Could not find OpenBLAS include. Turning OpenBLAS_FOUND off
-- Could not find OpenBLAS lib. Turning OpenBLAS_FOUND off
-- Could NOT find Atlas (missing:  Atlas_CBLAS_INCLUDE_DIR Atlas_CLAPACK_INCLUDE_DIR Atlas_CBLAS_LIBRARY Atlas_BLAS_LIBRARY Atlas_LAPACK_LIBRARY)
-- Could NOT find Doxygen (missing:  DOXYGEN_EXECUTABLE)
-- Found PythonInterp: /usr/bin/python2.7 (found suitable version "2.7.6", minimum required is "2.7")
-- Found PythonLibs: /usr/lib/arm-linux-gnueabihf/libpython2.7.so (found suitable exact version "2.7.6")
-- Found PythonInterp: /usr/bin/python3.4 (found suitable version "3.4.3", minimum required is "3.4")
-- Could NOT find PythonLibs (missing:  PYTHON_LIBRARIES PYTHON_INCLUDE_DIRS) (Required is exact version "3.4.3")
  File "<string>", line 1, in <module>
ImportError: No module named 'numpy'
-- Could NOT find JNI (missing:  JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH2 JAVA_AWT_INCLUDE_PATH)
-- Could NOT find Matlab (missing:  MATLAB_MEX_SCRIPT MATLAB_INCLUDE_DIRS MATLAB_ROOT_DIR MATLAB_LIBRARIES MATLAB_LIBRARY_DIRS MATLAB_MEXEXT MATLAB_ARCH MATLAB_BIN)
-- Performing Test CXX_HAS_MFPU_NEON
-- Performing Test CXX_HAS_MFPU_NEON - Success
-- Performing Test C_HAS_MFPU_NEON
-- Performing Test C_HAS_MFPU_NEON - Success
-- Performing Test HAVE_CXX_WNO_UNDEF
-- Performing Test HAVE_CXX_WNO_UNDEF - Success
-- Performing Test HAVE_CXX_WNO_MISSING_DECLARATIONS
-- Performing Test HAVE_CXX_WNO_MISSING_DECLARATIONS - Success
-- Performing Test HAVE_CXX_WNO_SHADOW
-- Performing Test HAVE_CXX_WNO_SHADOW - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_PARAMETER
-- Performing Test HAVE_CXX_WNO_UNUSED_PARAMETER - Success
-- Performing Test HAVE_CXX_WNO_UNINITIALIZED
-- Performing Test HAVE_CXX_WNO_UNINITIALIZED - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_FUNCTION
-- Performing Test HAVE_CXX_WNO_UNUSED_FUNCTION - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_VARIABLE
-- Performing Test HAVE_CXX_WNO_UNUSED_VARIABLE - Success
-- Performing Test HAVE_CXX_WNO_ENUM_COMPARE
-- Performing Test HAVE_CXX_WNO_ENUM_COMPARE - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_BUT_SET_VARIABLE
-- Performing Test HAVE_CXX_WNO_UNUSED_BUT_SET_VARIABLE - Success
-- Performing Test HAVE_CXX_WNO_DEPRECATED_DECLARATIONS
-- Performing Test HAVE_CXX_WNO_DEPRECATED_DECLARATIONS - Success
-- Performing Test HAVE_CXX_WNO_OVERLOADED_VIRTUAL
-- Performing Test HAVE_CXX_WNO_OVERLOADED_VIRTUAL - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_PRIVATE_FIELD
-- Performing Test HAVE_CXX_WNO_UNUSED_PRIVATE_FIELD - Failed
-- General configuration for OpenCV 3.2.0 =====================================
--   Version control:               unknown
--   Platform:
--     Timestamp:                   2017-03-13T20:23:07Z
--     Host:                        Linux 3.10.40-ga7da876 armv7l
--     CMake:                       2.8.12.2
--     CMake generator:             Unix Makefiles
--     CMake build tool:            /usr/bin/make
--     Configuration:               Release
--   C/C++:
--     Built as dynamic libs?:      YES
--     C++ Compiler:                /usr/bin/c++  (ver 4.8.4)
--     C++ flags (Release):         -Wa,-mimplicit-it=thumb   -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -mfp16-format=ieee -mfpu=neon -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -mfpu=neon-fp16 -O3 -DNDEBUG  -DNDEBUG
--     C++ flags (Debug):           -Wa,-mimplicit-it=thumb   -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -mfp16-format=ieee -mfpu=neon -ffunction-sections -fvisibility=hidden -fvisibility-inlines-hidden -mfpu=neon-fp16 -g  -O0 -DDEBUG -D_DEBUG
--     C Compiler:                  /usr/bin/cc
--     C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -mfp16-format=ieee -mfpu=neon -ffunction-sections -fvisibility=hidden -mfpu=neon-fp16 -O3 -DNDEBUG  -DNDEBUG
--     C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -mfp16-format=ieee -mfpu=neon -ffunction-sections -fvisibility=hidden -mfpu=neon-fp16 -g  -O0 -DDEBUG -D_DEBUG
--     Linker flags (Release):
--     Linker flags (Debug):
--     ccache:                      NO
--     Precompiled headers:         YES
--     Extra dependencies:          /usr/lib/arm-linux-gnueabihf/libpng.so /usr/lib/arm-linux-gnueabihf/libz.so /usr/lib/arm-linux-gnueabihf/libtiff.so /usr/lib/arm-linux-gnueabihf/libjasper.so /usr/lib/arm-linux-gnueabihf/libjpeg.so gtk-x11-2.0 gdk-x11-2.0 atk-1.0 gio-2.0 pangoft2-1.0 pangocairo-1.0 gdk_pixbuf-2.0 cairo pango-1.0 fontconfig gobject-2.0 glib-2.0 freetype gthread-2.0 avcodec avformat avutil swscale dl m pthread rt tbb cudart nppc nppi npps cufft -L/usr/local/cuda-6.5/lib
--     3rdparty dependencies:       libwebp tegra_hal
--   OpenCV modules:
--     To be built:                 cudev core cudaarithm flann imgproc ml video cudabgsegm cudafilters cudaimgproc cudawarping imgcodecs photo shape videoio cudacodec highgui objdetect ts features2d calib3d cudafeatures2d cudalegacy cudaobjdetect cudaoptflow cudastereo stitching superres videostab python2
--     Disabled:                    world
--     Disabled by dependency:      -
--     Unavailable:                 java python3 viz
--   GUI:
--     QT:                          NO
--     GTK+ 2.x:                    YES (ver 2.24.23)
--     GThread :                    YES (ver 2.40.2)
--     GtkGlExt:                    NO
--     OpenGL support:              NO
--     VTK support:                 NO
--   Media I/O:
--     ZLib:                        /usr/lib/arm-linux-gnueabihf/libz.so (ver 1.2.8)
--     JPEG:                        /usr/lib/arm-linux-gnueabihf/libjpeg.so (ver )
--     WEBP:                        build (ver 0.3.1)
--     PNG:                         /usr/lib/arm-linux-gnueabihf/libpng.so (ver 1.2.50)
--     TIFF:                        /usr/lib/arm-linux-gnueabihf/libtiff.so (ver 42 - 4.0.3)
--     JPEG 2000:                   /usr/lib/arm-linux-gnueabihf/libjasper.so (ver 1.900.1)
--     OpenEXR:                     NO
--     GDAL:                        NO
--     GDCM:                        NO
--   Video I/O:
--     DC1394 1.x:                  NO
--     DC1394 2.x:                  NO
--     FFMPEG:                      YES
--       avcodec:                   YES (ver 54.35.1)
--       avformat:                  YES (ver 54.20.4)
--       avutil:                    YES (ver 52.3.0)
--       swscale:                   YES (ver 2.1.1)
--       avresample:                NO
--     GStreamer:                   NO
--     OpenNI:                      NO
--     OpenNI PrimeSensor Modules:  NO
--     OpenNI2:                     NO
--     PvAPI:                       NO
--     GigEVisionSDK:               NO
--     Aravis SDK:                  NO
--     UniCap:                      NO
--     UniCap ucil:                 NO
--     V4L/V4L2:                    NO/YES
--     XIMEA:                       NO
--     Xine:                        NO
--     gPhoto2:                     NO
--   Parallel framework:            TBB (ver 4.2 interface 7000)
--   Other third-party libraries:
--     Use IPP:                     NO
--     Use VA:                      NO
--     Use Intel VA-API/OpenCL:     NO
--     Use Lapack:                  NO
--     Use Eigen:                   YES (ver 3.2.0)
--     Use Cuda:                    YES (ver 6.5)
--     Use OpenCL:                  NO
--     Use OpenVX:                  NO
--     Use custom HAL:              YES (carotene (ver 0.0.1))
--   NVIDIA CUDA
--     Use CUFFT:                   YES
--     Use CUBLAS:                  NO
--     USE NVCUVID:                 NO
--     NVIDIA GPU arch:             32
--     NVIDIA PTX archs:
--     Use fast math:               YES
--   Python 2:
--     Interpreter:                 /usr/bin/python2.7 (ver 2.7.6)
--     Libraries:                   /usr/lib/arm-linux-gnueabihf/libpython2.7.so (ver 2.7.6)
--     numpy:                       /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.8.2)
--     packages path:               lib/python2.7/dist-packages
--   Python 3:
--     Interpreter:                 /usr/bin/python3.4 (ver 3.4.3)
--   Python (for build):            /usr/bin/python2.7
--   Java:
--     ant:                         NO
--     JNI:                         NO
--     Java wrappers:               NO
--     Java tests:                  NO
--   Matlab:                        Matlab not found or implicitly disabled
--   Documentation:
--     Doxygen:                     NO
--   Tests and samples:
--     Tests:                       YES
--     Performance tests:           YES
--     C/C++ Examples:              YES
--   Install path:                  /usr/local/opencv-3.2.0
--   cvconfig.h is in:              /media/ubuntu/Data/opencv/opencv-3.2.0/build/TK1
-- Configuring done
-- Generating done
-- Build files have been written to: /media/ubuntu/Data/opencv/opencv-3.2.0/build/TK1
  1. Compile and link the libraries:
make -j3
should compile with a few warnings but no error.
Hi I tried out your building script and it worked. Thank you so much for your help.
However I would still like to provide more info. The differences between out builds are:
  1. I used cmake-gui
  2. I enabled opencv_world.
  3. I enabled openMP.
I think it should be one of the three which opencv on Jetson doesn’t like. I will find it out later.
Thank you again for your help.
Hi I tried out your building script and it worked quite well until it went to that file.
The error I got is
Building NVCC (Device) object modules/cudaoptflow/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_pyrlk.cu.o
Killed
/home/shelton/src/opencv-3.2.0/build/TK1/modules/cudaoptflow/CMakeFiles/cuda_compile.dir/src/cuda/./cuda_compile_generated_pyrlk.cu.o
modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/build.make:462: recipe for target ‘modules/cudaoptflow/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_pyrlk.cu.o’ failed
I’m gonna get some verbose info about this error.
I notice that NVCC has been killed. One possible cause is running out of memory, as TK1 only has 2 GB of RAM.
Can you retry make without -j3, so that only one job will be used for make, and closing other applications that could use memory ?
I was building without -j3. The last building command I issued is
make --debug=v > buildlog
I got the following error:
[ 66%] Building NVCC (Device) object modules/cudaoptflow/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_pyrlk.cu.o
modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/build.make:462: recipe for target 'modules/cudaoptflow/CMakeFiles/cuda_compile.dir/src/cuda/cuda_compile_generated_pyrlk.cu.o' failed
CMakeFiles/Makefile2:9526: recipe for target 'modules/cudaoptflow/CMakeFiles/opencv_cudaoptflow.dir/all' failed
It seems that the target failed at a quite initial stage. Another information about this is, in my previous buildings, this target failed at around 10% of the whole building. All my builds run without -j failed on this file.
Do you have enough free space ?
df
I use to build on a USB disk, as the mmc is not so large.
This is a great point. I’ve tried to use SD card. Then the problem is solved.
