custom built opencv 3.4.0 following nvidia advice not working
Hey so i built opencv 3.4.0 using this script:
https://github.com/AastaNV/JEP/blob/master/script/install_opencv3.4.0_TX2.sh
I Turned off CUDA for the script too because it was giving me errors.
This is the build log:
-- The CXX compiler identification is GNU 7.4.0
-- The C compiler identification is GNU 7.4.0
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Performing Test HAVE_CXX11 (check file: cmake/checks/cxx11.cpp)
-- Performing Test HAVE_CXX11 - Success
-- Found PythonInterp: /usr/bin/python2.7 (found suitable version "2.7.15", minimum required is "2.7")
-- Found PythonLibs: /usr/lib/aarch64-linux-gnu/libpython2.7.so (found suitable exact version "2.7.15+")
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.6.8", minimum required is "3.4")
-- Found PythonLibs: /usr/lib/aarch64-linux-gnu/libpython3.6m.so (found suitable exact version "3.6.8")
-- Looking for ccache - found (/usr/bin/ccache)
-- Performing Test HAVE_CXX_FSIGNED_CHAR
-- Performing Test HAVE_CXX_FSIGNED_CHAR - Success
-- Performing Test HAVE_C_FSIGNED_CHAR
-- Performing Test HAVE_C_FSIGNED_CHAR - Success
-- Performing Test HAVE_CXX_W
-- Performing Test HAVE_CXX_W - Success
-- Performing Test HAVE_C_W
-- Performing Test HAVE_C_W - Success
-- Performing Test HAVE_CXX_WALL
-- Performing Test HAVE_CXX_WALL - Success
-- Performing Test HAVE_C_WALL
-- Performing Test HAVE_C_WALL - Success
-- Performing Test HAVE_CXX_WERROR_RETURN_TYPE
-- Performing Test HAVE_CXX_WERROR_RETURN_TYPE - Success
-- Performing Test HAVE_C_WERROR_RETURN_TYPE
-- Performing Test HAVE_C_WERROR_RETURN_TYPE - Success
-- Performing Test HAVE_CXX_WERROR_NON_VIRTUAL_DTOR
-- Performing Test HAVE_CXX_WERROR_NON_VIRTUAL_DTOR - Success
-- Performing Test HAVE_C_WERROR_NON_VIRTUAL_DTOR
-- Performing Test HAVE_C_WERROR_NON_VIRTUAL_DTOR - Success
-- Performing Test HAVE_CXX_WERROR_ADDRESS
-- Performing Test HAVE_CXX_WERROR_ADDRESS - Success
-- Performing Test HAVE_C_WERROR_ADDRESS
-- Performing Test HAVE_C_WERROR_ADDRESS - Success
-- Performing Test HAVE_CXX_WERROR_SEQUENCE_POINT
-- Performing Test HAVE_CXX_WERROR_SEQUENCE_POINT - Success
-- Performing Test HAVE_C_WERROR_SEQUENCE_POINT
-- Performing Test HAVE_C_WERROR_SEQUENCE_POINT - Success
-- Performing Test HAVE_CXX_WFORMAT
-- Performing Test HAVE_CXX_WFORMAT - Success
-- Performing Test HAVE_C_WFORMAT
-- Performing Test HAVE_C_WFORMAT - Success
-- Performing Test HAVE_CXX_WERROR_FORMAT_SECURITY
-- Performing Test HAVE_CXX_WERROR_FORMAT_SECURITY - Success
-- Performing Test HAVE_C_WERROR_FORMAT_SECURITY
-- Performing Test HAVE_C_WERROR_FORMAT_SECURITY - Success
-- Performing Test HAVE_CXX_WMISSING_DECLARATIONS
-- Performing Test HAVE_CXX_WMISSING_DECLARATIONS - Success
-- Performing Test HAVE_C_WMISSING_DECLARATIONS
-- Performing Test HAVE_C_WMISSING_DECLARATIONS - Success
-- Performing Test HAVE_CXX_WMISSING_PROTOTYPES
-- Performing Test HAVE_CXX_WMISSING_PROTOTYPES - Failed
-- Performing Test HAVE_C_WMISSING_PROTOTYPES
-- Performing Test HAVE_C_WMISSING_PROTOTYPES - Success
-- Performing Test HAVE_CXX_WSTRICT_PROTOTYPES
-- Performing Test HAVE_CXX_WSTRICT_PROTOTYPES - Failed
-- Performing Test HAVE_C_WSTRICT_PROTOTYPES
-- Performing Test HAVE_C_WSTRICT_PROTOTYPES - Success
-- Performing Test HAVE_CXX_WUNDEF
-- Performing Test HAVE_CXX_WUNDEF - Success
-- Performing Test HAVE_C_WUNDEF
-- Performing Test HAVE_C_WUNDEF - Success
-- Performing Test HAVE_CXX_WINIT_SELF
-- Performing Test HAVE_CXX_WINIT_SELF - Success
-- Performing Test HAVE_C_WINIT_SELF
-- Performing Test HAVE_C_WINIT_SELF - Success
-- Performing Test HAVE_CXX_WPOINTER_ARITH
-- Performing Test HAVE_CXX_WPOINTER_ARITH - Success
-- Performing Test HAVE_C_WPOINTER_ARITH
-- Performing Test HAVE_C_WPOINTER_ARITH - Success
-- Performing Test HAVE_CXX_WSHADOW
-- Performing Test HAVE_CXX_WSHADOW - Success
-- Performing Test HAVE_C_WSHADOW
-- Performing Test HAVE_C_WSHADOW - Success
-- Performing Test HAVE_CXX_WSIGN_PROMO
-- Performing Test HAVE_CXX_WSIGN_PROMO - Success
-- Performing Test HAVE_C_WSIGN_PROMO
-- Performing Test HAVE_C_WSIGN_PROMO - Failed
-- Performing Test HAVE_CXX_WUNINITIALIZED
-- Performing Test HAVE_CXX_WUNINITIALIZED - Success
-- Performing Test HAVE_C_WUNINITIALIZED
-- Performing Test HAVE_C_WUNINITIALIZED - Success
-- Performing Test HAVE_CXX_WNO_NARROWING
-- Performing Test HAVE_CXX_WNO_NARROWING - Success
-- Performing Test HAVE_C_WNO_NARROWING
-- Performing Test HAVE_C_WNO_NARROWING - Success
-- Performing Test HAVE_CXX_WNO_DELETE_NON_VIRTUAL_DTOR
-- Performing Test HAVE_CXX_WNO_DELETE_NON_VIRTUAL_DTOR - Success
-- Performing Test HAVE_C_WNO_DELETE_NON_VIRTUAL_DTOR
-- Performing Test HAVE_C_WNO_DELETE_NON_VIRTUAL_DTOR - Failed
-- Performing Test HAVE_CXX_WNO_UNNAMED_TYPE_TEMPLATE_ARGS
-- Performing Test HAVE_CXX_WNO_UNNAMED_TYPE_TEMPLATE_ARGS - Failed
-- Performing Test HAVE_C_WNO_UNNAMED_TYPE_TEMPLATE_ARGS
-- Performing Test HAVE_C_WNO_UNNAMED_TYPE_TEMPLATE_ARGS - Failed
-- Performing Test HAVE_CXX_WNO_COMMENT
-- Performing Test HAVE_CXX_WNO_COMMENT - Success
-- Performing Test HAVE_C_WNO_COMMENT
-- Performing Test HAVE_C_WNO_COMMENT - Success
-- Performing Test HAVE_CXX_WNO_IMPLICIT_FALLTHROUGH
-- Performing Test HAVE_CXX_WNO_IMPLICIT_FALLTHROUGH - Success
-- Performing Test HAVE_C_WNO_IMPLICIT_FALLTHROUGH
-- Performing Test HAVE_C_WNO_IMPLICIT_FALLTHROUGH - Success
-- Performing Test HAVE_CXX_FDIAGNOSTICS_SHOW_OPTION
-- Performing Test HAVE_CXX_FDIAGNOSTICS_SHOW_OPTION - Success
-- Performing Test HAVE_C_FDIAGNOSTICS_SHOW_OPTION
-- Performing Test HAVE_C_FDIAGNOSTICS_SHOW_OPTION - Success
-- Performing Test HAVE_CXX_PTHREAD
-- Performing Test HAVE_CXX_PTHREAD - Success
-- Performing Test HAVE_C_PTHREAD
-- Performing Test HAVE_C_PTHREAD - Success
-- Performing Test HAVE_CXX_FOMIT_FRAME_POINTER
-- Performing Test HAVE_CXX_FOMIT_FRAME_POINTER - Success
-- Performing Test HAVE_C_FOMIT_FRAME_POINTER
-- Performing Test HAVE_C_FOMIT_FRAME_POINTER - Success
-- Performing Test HAVE_CXX_FFUNCTION_SECTIONS
-- Performing Test HAVE_CXX_FFUNCTION_SECTIONS - Success
-- Performing Test HAVE_C_FFUNCTION_SECTIONS
-- Performing Test HAVE_C_FFUNCTION_SECTIONS - Success
-- Performing Test HAVE_CXX_FDATA_SECTIONS
-- Performing Test HAVE_CXX_FDATA_SECTIONS - Success
-- Performing Test HAVE_C_FDATA_SECTIONS
-- Performing Test HAVE_C_FDATA_SECTIONS - Success
-- Performing Test HAVE_CPU_NEON_SUPPORT (check file: cmake/checks/cpu_neon.cpp)
-- Performing Test HAVE_CPU_NEON_SUPPORT - Success
-- Performing Test HAVE_CPU_FP16_SUPPORT (check file: cmake/checks/cpu_fp16.cpp)
-- Performing Test HAVE_CPU_FP16_SUPPORT - Success
-- Performing Test HAVE_CPU_BASELINE_FLAGS
-- Performing Test HAVE_CPU_BASELINE_FLAGS - Success
-- Performing Test HAVE_CXX_FVISIBILITY_HIDDEN
-- Performing Test HAVE_CXX_FVISIBILITY_HIDDEN - Success
-- Performing Test HAVE_C_FVISIBILITY_HIDDEN
-- Performing Test HAVE_C_FVISIBILITY_HIDDEN - Success
-- Performing Test HAVE_CXX_FVISIBILITY_INLINES_HIDDEN
-- Performing Test HAVE_CXX_FVISIBILITY_INLINES_HIDDEN - Success
-- Performing Test HAVE_C_FVISIBILITY_INLINES_HIDDEN
-- Performing Test HAVE_C_FVISIBILITY_INLINES_HIDDEN - Failed
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for posix_memalign
-- Looking for posix_memalign - found
-- Looking for malloc.h
-- Looking for malloc.h - found
-- Looking for memalign
-- Looking for memalign - found
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Using unsigned short
-- Check if the system is big endian - little endian
-- Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found suitable version "1.2.11", minimum required is "1.2.3")
-- Found JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so
-- Found TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (found version "4.0.9")
-- Performing Test HAVE_C_WNO_UNUSED_VARIABLE
-- Performing Test HAVE_C_WNO_UNUSED_VARIABLE - Success
-- Performing Test HAVE_C_WNO_UNUSED_FUNCTION
-- Performing Test HAVE_C_WNO_UNUSED_FUNCTION - Success
-- Performing Test HAVE_C_WNO_SHADOW
-- Performing Test HAVE_C_WNO_SHADOW - Success
-- Performing Test HAVE_C_WNO_MAYBE_UNINITIALIZED
-- Performing Test HAVE_C_WNO_MAYBE_UNINITIALIZED - Success
-- Performing Test HAVE_C_WNO_MISSING_PROTOTYPES
-- Performing Test HAVE_C_WNO_MISSING_PROTOTYPES - Success
-- Performing Test HAVE_C_WNO_MISSING_DECLARATIONS
-- Performing Test HAVE_C_WNO_MISSING_DECLARATIONS - Success
-- Could NOT find Jasper (missing: JASPER_LIBRARIES JASPER_INCLUDE_DIR)
-- Performing Test HAVE_C_WNO_IMPLICIT_FUNCTION_DECLARATION
-- Performing Test HAVE_C_WNO_IMPLICIT_FUNCTION_DECLARATION - Success
-- Performing Test HAVE_C_WNO_UNINITIALIZED
-- Performing Test HAVE_C_WNO_UNINITIALIZED - Success
-- Performing Test HAVE_C_WNO_UNUSED_BUT_SET_PARAMETER
-- Performing Test HAVE_C_WNO_UNUSED_BUT_SET_PARAMETER - Success
-- Performing Test HAVE_C_WNO_UNUSED - Success
-- Performing Test HAVE_C_WNO_SIGN_COMPARE
-- Performing Test HAVE_C_WNO_SIGN_COMPARE - Success
-- Performing Test HAVE_C_WNO_STRICT_OVERFLOW
-- Performing Test HAVE_C_WNO_STRICT_OVERFLOW - Success
-- Performing Test HAVE_C_WNO_POINTER_COMPARE
-- Performing Test HAVE_C_WNO_POINTER_COMPARE - Success
-- Performing Test HAVE_C_WNO_ABSOLUTE_VALUE
-- Performing Test HAVE_C_WNO_ABSOLUTE_VALUE - Failed
-- Performing Test HAVE_C_WNO_UNUSED_PARAMETER
-- Performing Test HAVE_C_WNO_UNUSED_PARAMETER - Success
-- Performing Test HAVE_C_WNO_STRICT_PROTOTYPES
-- Performing Test HAVE_C_WNO_STRICT_PROTOTYPES - Success
-- Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found version "1.2.11")
-- Found PNG: /usr/lib/aarch64-linux-gnu/libpng.so (found version "1.6.34")
-- Looking for /usr/include/libpng/png.h
-- Looking for /usr/include/libpng/png.h - found
-- Found OpenEXR: /usr/lib/aarch64-linux-gnu/libIlmImf.so
-- Checking for module 'gtk+-3.0'
--   Found gtk+-3.0, version 3.22.30
-- Checking for module 'gthread-2.0'
--   Found gthread-2.0, version 2.56.4
-- Checking for module 'gstreamer-base-1.0'
--   Found gstreamer-base-1.0, version 1.14.4
-- Checking for module 'gstreamer-video-1.0'
--   Found gstreamer-video-1.0, version 1.14.4
-- Checking for module 'gstreamer-app-1.0'
--   Found gstreamer-app-1.0, version 1.14.4
-- Checking for module 'gstreamer-riff-1.0'
--   Found gstreamer-riff-1.0, version 1.14.4
-- Checking for module 'gstreamer-pbutils-1.0'
--   Found gstreamer-pbutils-1.0, version 1.14.4
-- Checking for module 'libdc1394-2'
--   Found libdc1394-2, version 2.2.5
-- Checking for module 'libv4l1'
--   Found libv4l1, version 1.14.2
-- Checking for module 'libv4l2'
--   Found libv4l2, version 1.14.2
-- Looking for linux/videodev.h
-- Looking for linux/videodev.h - found
-- Looking for linux/videodev2.h
-- Looking for linux/videodev2.h - found
-- Looking for sys/videoio.h
-- Looking for sys/videoio.h - not found
-- Checking for modules 'libavcodec;libavformat;libavutil;libswscale'
--   Found libavcodec, version 57.107.100
--   Found libavformat, version 57.83.100
--   Found libavutil, version 55.78.100
--   Found libswscale, version 4.8.100
-- Checking for module 'libavresample'
--   Found libavresample, version 3.7.0
-- Checking for module 'libgphoto2'
--   Found libgphoto2, version 2.5.16
-- Could not find OpenBLAS include. Turning OpenBLAS_FOUND off
-- Could not find OpenBLAS lib. Turning OpenBLAS_FOUND off
-- Found Atlas: /usr/include/aarch64-linux-gnu
-- Found Atlas (include: /usr/include/aarch64-linux-gnu, library: /usr/lib/aarch64-linux-gnu/libatlas.so)
-- LAPACK(Atlas): LAPACK_LIBRARIES: /usr/lib/aarch64-linux-gnu/liblapack.so;/usr/lib/aarch64-linux-gnu/libcblas.so;/usr/lib/aarch64-linux-gnu/libatlas.so
-- LAPACK(Atlas): Support is enabled.
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- Could NOT find JNI (missing: JAVA_AWT_LIBRARY JAVA_JVM_LIBRARY JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH2 JAVA_AWT_INCLUDE_PATH)
-- Could NOT find Pylint (missing: PYLINT_EXECUTABLE)
-- Could NOT find Matlab (missing: MATLAB_MEX_SCRIPT MATLAB_INCLUDE_DIRS MATLAB_ROOT_DIR MATLAB_LIBRARIES MATLAB_LIBRARY_DIRS MATLAB_MEXEXT MATLAB_ARCH MATLAB_BIN)
-- VTK is not found. Please set -DVTK_DIR in CMake to VTK build directory, or to VTK install subdirectory with VTKConfig.cmake file
-- Performing Test CXX_HAS_MFPU_NEON
-- Performing Test CXX_HAS_MFPU_NEON - Failed
-- Performing Test C_HAS_MFPU_NEON
-- Performing Test C_HAS_MFPU_NEON - Failed
-- Performing Test HAVE_CXX_WNO_DEPRECATED
-- Performing Test HAVE_CXX_WNO_DEPRECATED - Success
-- Performing Test HAVE_CXX_WNO_MISSING_PROTOTYPES
-- Performing Test HAVE_CXX_WNO_MISSING_PROTOTYPES - Failed
-- Performing Test HAVE_CXX_WNO_MISSING_DECLARATIONS
-- Performing Test HAVE_CXX_WNO_MISSING_DECLARATIONS - Success
-- Performing Test HAVE_CXX_WNO_SHADOW
-- Performing Test HAVE_CXX_WNO_SHADOW - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_PARAMETER
-- Performing Test HAVE_CXX_WNO_UNUSED_PARAMETER - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_LOCAL_TYPEDEFS
-- Performing Test HAVE_CXX_WNO_UNUSED_LOCAL_TYPEDEFS - Success
-- Performing Test HAVE_CXX_WNO_SIGN_COMPARE
-- Performing Test HAVE_CXX_WNO_SIGN_COMPARE - Success
-- Performing Test HAVE_CXX_WNO_SIGN_PROMO
-- Performing Test HAVE_CXX_WNO_SIGN_PROMO - Success
-- Performing Test HAVE_CXX_WNO_UNDEF
-- Performing Test HAVE_CXX_WNO_UNDEF - Success
-- Performing Test HAVE_CXX_WNO_TAUTOLOGICAL_UNDEFINED_COMPARE
-- Performing Test HAVE_CXX_WNO_TAUTOLOGICAL_UNDEFINED_COMPARE - Failed
-- Performing Test HAVE_CXX_WNO_IGNORED_QUALIFIERS
-- Performing Test HAVE_CXX_WNO_IGNORED_QUALIFIERS - Success
-- Performing Test HAVE_CXX_WNO_EXTRA
-- Performing Test HAVE_CXX_WNO_EXTRA - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_FUNCTION
-- Performing Test HAVE_CXX_WNO_UNUSED_FUNCTION - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_CONST_VARIABLE
-- Performing Test HAVE_CXX_WNO_UNUSED_CONST_VARIABLE - Success
-- Performing Test HAVE_CXX_WNO_SHORTEN_64_TO_32
-- Performing Test HAVE_CXX_WNO_SHORTEN_64_TO_32 - Failed
-- Performing Test HAVE_CXX_WNO_DEPRECATED_DECLARATIONS
-- Performing Test HAVE_CXX_WNO_DEPRECATED_DECLARATIONS - Success
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/core/src/convert.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/core/src/convert.sse4_1.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/core/mathfuncs_core.sse2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/core/mathfuncs_core.avx.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/core/mathfuncs_core.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/core/stat.sse4_2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/core/stat.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/imgproc/src/corner.avx.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/imgproc/src/filter.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/imgproc/src/imgwarp.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/imgproc/src/imgwarp.sse4_1.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/imgproc/src/resize.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/imgproc/src/resize.sse4_1.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/imgproc/src/undistort.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/imgproc/accum.sse2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/imgproc/accum.avx.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/objdetect/src/haar.avx.cpp
-- Performing Test HAVE_CXX_WNO_PARENTHESES
-- Performing Test HAVE_CXX_WNO_PARENTHESES - Success
-- Performing Test HAVE_CXX_WNO_MAYBE_UNINITIALIZED
-- Performing Test HAVE_CXX_WNO_MAYBE_UNINITIALIZED - Success
-- Performing Test HAVE_CXX_WNO_ENUM_COMPARE
-- Performing Test HAVE_CXX_WNO_ENUM_COMPARE - Success
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/dnn/layers/layers_common.avx.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/release/modules/dnn/layers/layers_common.avx2.cpp
-- Excluding from source files list: /home/jetson-tx2/opencv-3.4.0/modules/features2d/src/fast.avx2.cpp
-- Performing Test HAVE_CXX_WNO_OVERLOADED_VIRTUAL
-- Performing Test HAVE_CXX_WNO_OVERLOADED_VIRTUAL - Success
-- Performing Test HAVE_CXX_WNO_UNUSED_PRIVATE_FIELD
-- Performing Test HAVE_CXX_WNO_UNUSED_PRIVATE_FIELD - Failed
-- General configuration for OpenCV 3.4.0 =====================================
--   Version control:               unknown
--   Platform:
--     Timestamp:                   2019-07-17T09:09:29Z
--     Host:                        Linux 4.9.140-tegra aarch64
--     CMake:                       3.10.2
--     CMake generator:             Unix Makefiles
--     CMake build tool:            /usr/bin/make
--     Configuration:               RELEASE
--   CPU/HW features:
--     Baseline:                    NEON FP16
--       required:                  NEON
--       disabled:                  VFPV3
--   C/C++:
--     Built as dynamic libs?:      YES
--     C++11:                       YES
--     C++ Compiler:                /usr/bin/c++  (ver 7.4.0)
--     C++ flags (Release):         -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG  -DNDEBUG
--     C++ flags (Debug):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -g  -O0 -DDEBUG -D_DEBUG
--     C Compiler:                  /usr/bin/cc
--     C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -O3 -DNDEBUG  -DNDEBUG
--     C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wno-implicit-fallthrough -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -g  -O0 -DDEBUG -D_DEBUG
--     Linker flags (Release):
--     Linker flags (Debug):
--     ccache:                      YES
--     Precompiled headers:         NO
--     Extra dependencies:          dl m pthread rt
--     3rdparty dependencies:
--   OpenCV modules:
--     To be built:                 calib3d core dnn features2d flann highgui imgcodecs imgproc ml objdetect photo python2 python3 python_bindings_generator shape stitching superres video videoio videostab
--     Disabled:                    js world
--     Disabled by dependency:      -
--     Unavailable:                 cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev java ts viz
--     Applications:                apps
--     Documentation:               NO
--     Non-free algorithms:         NO
--   GUI:
--     GTK+:                        YES (ver 3.22.30)
--       GThread :                  YES (ver 2.56.4)
--       GtkGlExt:                  NO
--     VTK support:                 NO
--   Media I/O:
--     ZLib:                        /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
--     JPEG:                        /usr/lib/aarch64-linux-gnu/libjpeg.so (ver )
--     WEBP:                        build (ver encoder: 0x020e)
--     PNG:                         /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
--     TIFF:                        /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
--     JPEG 2000:                   build (ver 1.900.1)
--     OpenEXR:                     /usr/lib/aarch64-linux-gnu/libImath.so /usr/lib/aarch64-linux-gnu/libIlmImf.so /usr/lib/aarch64-linux-gnu/libIex.so /usr/lib/aarch64-linux-gnu/libHalf.so /usr/lib/aarch64-linux-gnu/libIlmThread.so (ver 2.2.0)
--   Video I/O:
--     DC1394:                      YES (ver 2.2.5)
--     FFMPEG:                      YES
--       avcodec:                   YES (ver 57.107.100)
--       avformat:                  YES (ver 57.83.100)
--       avutil:                    YES (ver 55.78.100)
--       swscale:                   YES (ver 4.8.100)
--       avresample:                YES (ver 3.7.0)
--     GStreamer:
--       base:                      YES (ver 1.14.4)
--       video:                     YES (ver 1.14.4)
--       app:                       YES (ver 1.14.4)
--       riff:                      YES (ver 1.14.4)
--       pbutils:                   YES (ver 1.14.4)
--     libv4l/libv4l2:              1.14.2 / 1.14.2
--     v4l/v4l2:                    linux/videodev.h linux/videodev2.h
--     gPhoto2:                     YES
--   Parallel framework:            pthreads
--   Trace:                         YES (built-in)
--   Other third-party libraries:
--     Lapack:                      YES (/usr/lib/aarch64-linux-gnu/liblapack.so /usr/lib/aarch64-linux-gnu/libcblas.so /usr/lib/aarch64-linux-gnu/libatlas.so)
--     Eigen:                       YES (ver 3.3.4)
--     Custom HAL:                  YES (carotene (ver 0.0.1))
--   OpenCL:                        YES (no extra features)
--     Include path:                /home/jetson-tx2/opencv-3.4.0/3rdparty/include/opencl/1.2
--     Link libraries:              Dynamic load
--   Python 2:
--     Interpreter:                 /usr/bin/python2.7 (ver 2.7.15)
--     Libraries:                   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.15+)
--     numpy:                       /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
--     packages path:               lib/python2.7/dist-packages
--   Python 3:
--     Interpreter:                 /usr/bin/python3 (ver 3.6.8)
--     Libraries:                   /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.8)
--     numpy:                       /usr/local/lib/python3.6/dist-packages/numpy/core/include (ver 1.16.4)
--     packages path:               lib/python3.6/dist-packages
--   Python (for build):            /usr/bin/python2.7
--   Java:
--     ant:                         NO
--     JNI:                         NO
--     Java wrappers:               NO
--     Java tests:                  NO
--   Matlab:                        NO
--   Install to:                    /usr/local
-- Configuring done
-- Generating done
-- Build files have been written to: /home/jetson-tx2/opencv-3.4.0/release
after running with cv2.videocapture(0) which i expect to not work i get these errors:
nvbuf_utils: Could not get EGL display connection nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR nvbuf_utils: Could not get EGL display connection nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR Opening in O_NON
BLOCKING MODE VIDEOIO ERROR: libv4l unable convert to requested pixfmt nvbuf_utils: Could not get EGL display connection nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR nvbuf_utils: Could not get EGL display connection nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR nvbu
f_utils: ERROR getting proc addr of eglDestroyImageKHR Opening in BLOCKING MODE VIDEOIO ERROR: libv4l unable to ioctl VIDIOCSPICT OpenCV Error: Unspecified error (GStreamer: unable to start pipeline ) in cvCaptureFromCAM_GStreamer, file /home/jetson-tx2/Clear/build/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp, line 890 VIDEOIO(cvCreateCapture
_GStreamer(CV_CAP_GSTREAMER_V4L2, reinterpret_cast<char *>(index))): raised OpenCV exception: /home/jetson-tx2/Clear/build/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp:890: error: (-2) GStreamer: unable to start pipeline in function cvCaptureFromCAM_GStreamer Detections have been saved successfully.
When i use this pipeline instead
"nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720,format=(string)NV12, framerate=(fraction)24/1 ! nvvidconv flip-method=0 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink"
i get this error:
"nvbuf_utils: Could not get EGL display connection
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:521 No cameras available
if i export display=:0 or any number for that case i get this error:
No protocol specified
Unable to init server: Could not connect: Connection refused
(Video detection:30651): Gtk-WARNING **: 09:23:14.156: cannot open display: :0
i’m fresh out of ideas at this point.
bump
The error looks like that openCV cannot access your camera.
Could you help to execute the GStreamer command directly on the console to see if works?
v4l2-ctl -d /dev/video0 --list-formats
Running this through i do get output of the sensor information. But when i run any command through gstreamer, such as:
gst-inspect-1.0 nvarguscamerasrc
Please note this does finish it’s output but it prints the errors first before outputting.
or
gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=640, height=480, framerate=30/1, format=NV12' ! nvvidconv flip-method=2 ! nvegltransform ! nveglglessink -e
I keep getting these errors:
Please try if this comment also works for you:
[url]L4T 32.1 h264 encoder pipeline, any way to suppress "nvbuf_utils" messages? - Jetson TX2 - NVIDIA Developer Forums
Could you please guide me towards writing the pipeline as i don’t really have a clue to do what he said to do…
Please share
nvarguscamerasrc is for Bayer sensors. Maybe your camera is not a Bayer sensor? Also are you on r32.1?
You should be able to build OpenCV with CUDA if you install full system image and packages through SDK manager/Jetpack. Seems certain packages are missed in your system.
Output below:
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'BG10'
        Name        : 10-bit Bayer BGBG/GRGR
i am running Jetpack 4.2 and have installed the full system image and packages.
edit:
also
# R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64, DATE: Wed Mar 13 07:41:08 UTC 2019
Are you able to see preview if you run
nvidia@nvidia-desktop:~$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=640, height=480, framerate=30/1, format=NV12' ! nvoverlaysink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 2592 x 1944 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 2592 x 1458 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 34000, max 550385000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 16.000000; Exposure Range min 22000, max 358733000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1280 H = 720
   seconds to Run    = 0
   Frame Rate = 120.000005
GST_ARGUS: PowerService: requested_clock_Hz=4032000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:18.327722963
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
GST_ARGUS:
PowerServiceHwVic::cleanupResources
jetson-tx2@jetson-tx2:~/Desktop$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:VNMM),width=640,height=480,framerate=30/1,format=NV12' ! nvoverlaysink
WARNING: erroneous pipeline: could not link nvarguscamerasrc0 to nvoverlaysink-nvoverlaysink0, neither element can handle caps video/x-raw(memory:VNMM), width=(int)640, height=(int)480, framerate=(fraction)30/1, format=(string)NV12
You need to check your sensor driver first. For using Argus, the sensor driver has to be programmed accordingly. Please refer to [Sensor Driver Programming Guide] in Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
Or contact camera vendor for help.
Comment #9 shows the log of running default camera board ov5693. It should recognize the camera and print out [Available Sensor modes].
I am using the default camera board…
And just remembered to mention this. I’m running the Jetson headless with x2go but it still wouldn’t work with the HDMI cable connected and not connected to an x2go session or an ssh session.
It should be something wrong in your environment. Please follow below steps to verify it on devkit:
  1. Install whole package through SDKManager
  2. Remove OpenCV 3.3.1
sudo apt-get purge "libopencv*"
  1. Execute the script to install OpenCV3.4.0
$ mkdir OpenCV
<s>$ ./install_opencv3.4.0_Xavier.sh OpenCV</s>
$ ./install_opencv3.4.0_TX2.sh OpenCV
$ sudo ldconfig -v
  1. Make sure OpenCV is in correct version
nvidia@nvidia-desktop:~$ python
Python 2.7.15+ (default, Nov 27 2018, 23:36:35)
[GCC 7.3.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> cv2.__version__
'3.4.0'
  1. Build and run test code in
    https://devtalk.nvidia.com/default/topic/1042892/jetson-agx-xavier/nvarguscamerasrc-opencv-solved-/post/5290833/#5290833
We have verified the steps on r32.1/TX2. You may try to run it successfully first. It is a bit strange it even fails in gst-launch-1.0. Looks to be something wrong in your system.
so i should run the xavier version of the install?
Target Hardware is selective. Please click on it and choose Jetson TX2. You also can select Jetpack 4.2 or 4.2.1 in ‘TARGET OPERATING SYSTEM’.
no i mean for the opencv install since that’s what you wrote in your message.
My bad. I have corrected the typo.
ummm i need this for python 3.
Please follow the steps to verify python 2.7.15+. And then upgrade to python 3. If you see failure after the upgrade, the issue should be triggered by python 3.
