PyTorch for Jetson
When I try to import torchvision it is showing an error. SyntaxError: future feature annotations is not defined. I am using jetpack 4.6 rev3 with pytorch v1.8.0 and torchvision v0.9.0 .
Hi @arjunslvrj, can you try running pip3 install 'pillow<9' ?
Thank you dusty
CMake can’t find TorchVision when using l4t-pytorch:r35.1.0-pth1.13-py3 docker image and warning of missing kineto library when using libtorch. I am currently trying to load a torchscript model in C++ that requires me to inclued torchvision/vision.h .
CMake Error at CMakeLists.txt:24 (find_package):
  By not providing "FindTorchVision.cmake" in CMAKE_MODULE_PATH this project
  has asked CMake to find a package configuration file provided by
  "TorchVision", but CMake did not find one.
  Could not find a package configuration file provided by "TorchVision" with
  any of the following names:
    TorchVisionConfig.cmake
    torchvision-config.cmake
  Add the installation prefix of "TorchVision" to CMAKE_PREFIX_PATH or set
  "TorchVision_DIR" to a directory containing one of the above files.  If
  "TorchVision" provides a separate development package or SDK, be sure it
  has been installed.
I have tried to add the following CMAKE_PREFIX_PATHs with no sucess:
list(APPEND  /usr/local/lib/python3.8/dist-packages/torchvision-0.13.0a0+da3794e-py3.8-linux-aarch64.egg/)
list(APPEND  /usr/local/lib/python3.8/dist-packages/torchvision-0.13.0a0+da3794e-py3.8-linux-aarch64.egg/torchvision/)
CMake can find libtorch when I use the following:
list(APPEND CMAKE_PREFIX_PATH /usr/local/lib/python3.8/dist-packages)
But it does give a warning:
CMake Warning at /usr/local/lib/python3.8/dist-packages/torch/share/cmake/Torch/TorchConfig.cmake:22 (message):
  static library kineto_LIBRARY-NOTFOUND not found.
Call Stack (most recent call first):
  /usr/local/lib/python3.8/dist-packages/torch/share/cmake/Torch/TorchConfig.cmake:127 (append_torchlib_if_found)
  CMakeLists.txt:25 (find_package)
Hi @franciscon9k63, it doesn’t appear that the torchvision C++ headers get installed when torchvision is built, and I’m not sure how to build it with that enabled. This is how I build/install torchvision in the container’s dockerfile:
Perhaps you could clone that branch of the torchvision repo to get the headers?
hi, I meet a problem. I need your help.
machine: Jetson Xaview, Jetpack 5.1
torch version: torch-1.14.0a0+44dac51c.nv23.1
when executed "torchrun **** ",
File “/home/nvidia/.local/bin/torchrun”, line 5, in
from torch.distributed.run import main
File “/home/nvidia/.local/lib/python3.8/site-packages/torch/distributed/run.py”, line 383, in
from torch.distributed.elastic.rendezvous.utils import _parse_rendezvous_config
File “/home/nvidia/.local/lib/python3.8/site-packages/torch/distributed/elastic/rendezvous/init.py”, line 131, in
from .api import * # noqa: F403
File “/home/nvidia/.local/lib/python3.8/site-packages/torch/distributed/elastic/rendezvous/api.py”, line 10, in
from torch.distributed import Store
ImportError: cannot import name ‘Store’ from ‘torch.distributed’ (/home/nvidia/.local/lib/python3.8/site-packages/torch/distributed/init.py)
Hi @Kic1101, these wheels were built with USE_DISTRIBUTED disabled, so they don’t support torch.distributed. If you need that, you would need to rebuild PyTorch from source.
Thanks that was it. I followed the instructions from : GitHub - pytorch/vision: Datasets, Transforms and Models specific to Computer Vision
I did the following
ARG LIBTORCH_PATH=/usr/local/lib/python3.8/dist-packages/torch/
RUN git clone https://github.com/pytorch/vision torchvision && \
    cd torchvision && \
    git checkout ${TORCHVISION_VERSION} && \
    mkdir build && \
    cd build && \
    cmake -DCMAKE_PREFIX_PATH=${LIBTORCH_PATH}-DWITH_CUDA=on .. && \
    make -j$(nproc) && \
    sudo make install && \
    rm -rf /torchvision
Thanks @franciscon9k63, that’s good to know how you built it with that enabled 👍
It explains the matter. Thanks a lot.
I got problems while installing torchvision. I installed torch 1.8 and wanted to install torchvision 0.9.0, but the result is:
Finished processing dependencies for torchvision==0.9.0a0+01dfa8e
nvidia@ubuntu:~/torchvision$ python3
Python 3.6.9 (default, Nov 25 2022, 14:10:45)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> import torchvision
  File "<stdin>", line 1, in <module>
  File "/home/nvidia/torchvision/torchvision/__init__.py", line 7, in <module>
    from torchvision import datasets
  File "/home/nvidia/torchvision/torchvision/datasets/__init__.py", line 1, in <module>
    from .lsun import LSUN, LSUNClass
  File "/home/nvidia/torchvision/torchvision/datasets/lsun.py", line 2, in <module>
    from PIL import Image
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 656, in _load_unlocked
  File "<frozen importlib._bootstrap>", line 626, in _load_backward_compatible
  File "/home/nvidia/.local/lib/python3.6/site-packages/Pillow-9.4.0-py3.6-linux-aarch64.egg/PIL/Image.py", line 59, in <module>
  File "<frozen importlib._bootstrap>", line 951, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 894, in _find_spec
  File "<frozen importlib._bootstrap_external>", line 1157, in find_spec
  File "<frozen importlib._bootstrap_external>", line 1131, in _get_spec
  File "<frozen importlib._bootstrap_external>", line 1112, in _legacy_get_spec
  File "<frozen importlib._bootstrap>", line 441, in spec_from_loader
  File "<frozen importlib._bootstrap_external>", line 544, in spec_from_file_location
  File "/home/nvidia/.local/lib/python3.6/site-packages/Pillow-9.4.0-py3.6-linux-aarch64.egg/PIL/_deprecate.py", line 1
the strange thing: when I want to install a different version of torch, it installs everytime torch 1.8.0. also when I delete and uninstall the package.
Does anyone knows what I can do?
Please try running pip3 install 'pillow<9'
Try double-checking the URL of the wheel that you downloaded. Perhaps the wheel is for PyTorch 1.8. Each version has a different URL.
I see Jetpack 5.0 comes with Python3.8 and PyTorch v1.12.0.
I’ve installed python3.11 on my Jetson (Xavier), is there any chance of getting PyTorch to work in python3.11? Or should I just stick with python3.8 which after all is provided with Jetpack 5.0
@joachimScale I’m not sure if Python 3.11 is officially supported/test in PyTorch yet (especially for aarch64+CUDA), but I did find this thread about it:
We only build PyTorch wheels for the default version of Python that comes with Ubuntu (and on JetPack 5.0, that’s Python 3.8). However you could try building it yourself from source.
Heads up that an update is needed as newer PyTorch pip wheels are available, such as for JetPack SDK 5.1 here:
https://developer.download.nvidia.com/compute/redist/jp/v51/pytorch/
Looks like everything is still Python 3.8 while 3.11.2 is the latest stable version.
Thank you, @dusty_nv !
Thanks @adam-erickson, yes new PyTorch wheels will now be on that server, and I’ve posted a link to the official docs at the top of this thread: https://docs.nvidia.com/deeplearning/frameworks/install-pytorch-jetson-platform/index.html
Yes, we distribute the PyTorch wheels for the default version of Python that comes with Ubuntu, and for Ubuntu 20.04 (JetPack 5.0/5.1) that is Python 3.8. For Python 3.11, you would need to build PyTorch from source.
