I have trained model. Here is the class
class UNet(nn.Module):
def __init__(self, n_channels=1, n_classes=2):
super(UNet, self).__init__()
self.inc = down(1, 32)
self.down1 = down(32, 64)
self.down2 = down(64, 128)
self.down3 = down(128, 256)
self.down4 = down(256, 512)
self.up1 = up(512, 512)
self.up2 = up(512 + 256, 256)
self.up3 = up(256 + 128, 128)
self.up4 = up(128 + 64, 64)
self.outc = outconv(64 + 32, 1)
def forward(self, x):
x1 = self.inc(x)
x2 = self.down1(x1)
x3 = self.down2(x2)
x4 = self.down3(x3)
x5 = self.down4(x4)
x = self.up1(x5, x4)
x = self.up2(x, x3)
x = self.up3(x, x2)
x = self.up4(x, x1)
x = self.outc(x)
return torch.tanh(x)
class down(nn.Module):
def __init__(self, in_ch, out_ch):
super(down, self).__init__()
self.conv = nn.Sequential(
nn.Conv2d(in_ch, out_ch, 3, stride=2, padding=1),
nn.BatchNorm2d(out_ch),
nn.ReLU())
x = self.conv(x)
return x
class up(nn.Module):
super(up, self).__init__()
nn.ConvTranspose2d(in_ch, out_ch, 2, stride=2, padding=0),
nn.Dropout(p=0.5),
nn.ReLU())
def forward(self, x1, x2):
x = self.conv(x1)
x = torch.cat([x2, x], dim=1)
return x
class outconv(nn.Module):
super(outconv, self).__init__()
self.conv = nn.ConvTranspose2d(in_ch, out_ch, 2, stride=2, padding=0)
x = self.conv(x)
return x
I try to convert it to tensorRt with torch2trt converter. Here is the log of process from jupyter notebook console
[TensorRT] INFO: Applying generic optimizations to the graph for inference.
[TensorRT] INFO: Original: 33 layers
[TensorRT] INFO: After dead-layer removal: 33 layers
[TensorRT] INFO: Fusing convolution weights from (Unnamed Layer* 0) [Convolution] with scale (Unnamed Layer* 1) [Scale]
[TensorRT] INFO: Fusing convolution weights from (Unnamed Layer* 3) [Convolution] with scale (Unnamed Layer* 4) [Scale]
[TensorRT] INFO: Fusing convolution weights from (Unnamed Layer* 6) [Convolution] with scale (Unnamed Layer* 7) [Scale]
[TensorRT] INFO: Fusing convolution weights from (Unnamed Layer* 9) [Convolution] with scale (Unnamed Layer* 10) [Scale]
[TensorRT] INFO: Fusing convolution weights from (Unnamed Layer* 12) [Convolution] with scale (Unnamed Layer* 13) [Scale]
[TensorRT] INFO: After scale fusion: 28 layers
[TensorRT] INFO: Fusing (Unnamed Layer* 0) [Convolution] with (Unnamed Layer* 2) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 3) [Convolution] with (Unnamed Layer* 5) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 6) [Convolution] with (Unnamed Layer* 8) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 9) [Convolution] with (Unnamed Layer* 11) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 12) [Convolution] with (Unnamed Layer* 14) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 16) [Scale] with (Unnamed Layer* 17) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 20) [Scale] with (Unnamed Layer* 21) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 24) [Scale] with (Unnamed Layer* 25) [Activation]
[TensorRT] INFO: Fusing (Unnamed Layer* 28) [Scale] with (Unnamed Layer* 29) [Activation]
[TensorRT] INFO: After vertical fusions: 19 layers
[TensorRT] INFO: After swap: 19 layers
[TensorRT] INFO: After final dead-layer removal: 19 layers
[TensorRT] INFO: After tensor merging: 19 layers
[TensorRT] INFO: Eliminating concatenation (Unnamed Layer* 18) [Concatenation]
[TensorRT] INFO: Retargeting (Unnamed Layer* 11) [Activation]_output to (Unnamed Layer* 18) [Concatenation]_output
[TensorRT] INFO: Retargeting (Unnamed Layer* 17) [Activation]_output to (Unnamed Layer* 18) [Concatenation]_output
[TensorRT] INFO: Eliminating concatenation (Unnamed Layer* 22) [Concatenation]
[TensorRT] INFO: Retargeting (Unnamed Layer* 8) [Activation]_output to (Unnamed Layer* 22) [Concatenation]_output
[TensorRT] INFO: Retargeting (Unnamed Layer* 21) [Activation]_output to (Unnamed Layer* 22) [Concatenation]_output
[TensorRT] INFO: Eliminating concatenation (Unnamed Layer* 26) [Concatenation]
[TensorRT] INFO: Retargeting (Unnamed Layer* 5) [Activation]_output to (Unnamed Layer* 26) [Concatenation]_output
[TensorRT] INFO: Retargeting (Unnamed Layer* 25) [Activation]_output to (Unnamed Layer* 26) [Concatenation]_output
[TensorRT] INFO: Eliminating concatenation (Unnamed Layer* 30) [Concatenation]
[TensorRT] INFO: Retargeting (Unnamed Layer* 2) [Activation]_output to (Unnamed Layer* 30) [Concatenation]_output
[TensorRT] INFO: Retargeting (Unnamed Layer* 29) [Activation]_output to (Unnamed Layer* 30) [Concatenation]_output
[TensorRT] INFO: After concat removal: 15 layers
[TensorRT] INFO: Graph construction and optimization completed in 0.0351903 seconds.
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 0) [Convolution] + (Unnamed Layer* 2) [Activation](3)
[TensorRT] INFO: Tactic 0 time 0.54672
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 0) [Convolution] + (Unnamed Layer* 2) [Activation](2)
[TensorRT] INFO: Tactic 6 time 2.80048
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 0) [Convolution] + (Unnamed Layer* 2) [Activation](14)
[TensorRT] INFO: Tactic 3146172331490511787 time 2.18669
[TensorRT] INFO: Tactic 3528302785056538033 time 0.72176
[TensorRT] INFO: Tactic 5443600094180187792 time 0.6728
[TensorRT] INFO: Tactic 5824828673459742858 time 4.45536
[TensorRT] INFO: Tactic -6618588952828687390 time 0.69616
[TensorRT] INFO: Tactic -6362554771847758902 time 1.11968
[TensorRT] INFO: Tactic -2701242286872672544 time 2.17491
[TensorRT] INFO: Tactic -2535759802710599445 time 1.08195
[TensorRT] INFO: Tactic -675401754313066228 time 1.12784
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 0) [Convolution] + (Unnamed Layer* 2) [Activation](1)
[TensorRT] INFO: Tactic 0 time 3.46669
[TensorRT] INFO: Tactic 1 scratch requested: 98816, available: 0
[TensorRT] INFO: Tactic 2 scratch requested: 589824, available: 0
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 0) [Convolution] + (Unnamed Layer* 2) [Activation](33)
[TensorRT] INFO: --------------- Chose 3 (0)
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 3) [Convolution] + (Unnamed Layer* 5) [Activation](3)
[TensorRT] INFO: Tactic 0 time 1.8392
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 3) [Convolution] + (Unnamed Layer* 5) [Activation](2)
[TensorRT] INFO: Tactic 6 time 3.87354
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 3) [Convolution] + (Unnamed Layer* 5) [Activation](14)
[TensorRT] INFO: Tactic 3146172331490511787 time 3.48906
[TensorRT] INFO: Tactic 3528302785056538033 time 2.37526
[TensorRT] INFO: Tactic 5443600094180187792 time 2.14822
[TensorRT] INFO: Tactic 5824828673459742858 time 3.40544
[TensorRT] INFO: Tactic -6618588952828687390 time 1.55994
[TensorRT] INFO: Tactic -6362554771847758902 time 1.27136
[TensorRT] INFO: Tactic -2701242286872672544 time 2.89786
[TensorRT] INFO: Tactic -2535759802710599445 time 1.22448
[TensorRT] INFO: Tactic -675401754313066228 time 1.25974
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 3) [Convolution] + (Unnamed Layer* 5) [Activation](1)
[TensorRT] INFO: Tactic 0 time 4.83414
[TensorRT] INFO: Tactic 1 scratch requested: 25088, available: 0
[TensorRT] INFO: Tactic 2 scratch requested: 4718592, available: 0
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 3) [Convolution] + (Unnamed Layer* 5) [Activation](33)
[TensorRT] INFO: --------------- Chose 14 (-2535759802710599445)
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 6) [Convolution] + (Unnamed Layer* 8) [Activation](3)
[TensorRT] INFO: Tactic 0 time 1.11046
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 6) [Convolution] + (Unnamed Layer* 8) [Activation](2)
[TensorRT] INFO: Tactic 6 time 1.98544
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 6) [Convolution] + (Unnamed Layer* 8) [Activation](14)
[TensorRT] INFO: Tactic 3146172331490511787 time 1.13718
[TensorRT] INFO: Tactic 3528302785056538033 time 2.6223
[TensorRT] INFO: Tactic 5443600094180187792 time 1.37126
[TensorRT] INFO: Tactic 5824828673459742858 time 1.11578
[TensorRT] INFO: Tactic -6618588952828687390 time 1.48784
[TensorRT] INFO: Tactic -6362554771847758902 time 1.21818
[TensorRT] INFO: Tactic -2701242286872672544 time 1.12512
[TensorRT] INFO: Tactic -2535759802710599445 time 1.17814
[TensorRT] INFO: Tactic -675401754313066228 time 1.21862
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 6) [Convolution] + (Unnamed Layer* 8) [Activation](1)
[TensorRT] INFO: Tactic 0 time 3.2784
[TensorRT] INFO: Tactic 1 scratch requested: 6656, available: 0
[TensorRT] INFO: Tactic 2 scratch requested: 2359296, available: 0
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 6) [Convolution] + (Unnamed Layer* 8) [Activation](33)
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 9) [Convolution] + (Unnamed Layer* 11) [Activation](3)
[TensorRT] INFO: Tactic 0 time 1.076
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 9) [Convolution] + (Unnamed Layer* 11) [Activation](2)
[TensorRT] INFO: Tactic 6 time 2.21725
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 9) [Convolution] + (Unnamed Layer* 11) [Activation](14)
[TensorRT] INFO: Tactic 3146172331490511787 time 1.10688
[TensorRT] INFO: Tactic 3528302785056538033 time 1.73837
[TensorRT] INFO: Tactic 5443600094180187792 time 2.2024
[TensorRT] INFO: Tactic 5824828673459742858 time 1.07421
[TensorRT] INFO: Tactic -6618588952828687390 time 2.12707
[TensorRT] INFO: Tactic -6362554771847758902 time 1.1808
[TensorRT] INFO: Tactic -2701242286872672544 time 1.95904
[TensorRT] INFO: Tactic -2535759802710599445 time 1.11232
[TensorRT] INFO: Tactic -675401754313066228 time 1.16397
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 9) [Convolution] + (Unnamed Layer* 11) [Activation](1)
[TensorRT] INFO: Tactic 0 time 2.84109
[TensorRT] INFO: Tactic 1 scratch requested: 2048, available: 0
[TensorRT] INFO: Tactic 2 scratch requested: 1179648, available: 0
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 9) [Convolution] + (Unnamed Layer* 11) [Activation](33)
[TensorRT] INFO: --------------- Chose 14 (5824828673459742858)
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 12) [Convolution] + (Unnamed Layer* 14) [Activation](3)
[TensorRT] INFO: Tactic 0 time 2.10848
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 12) [Convolution] + (Unnamed Layer* 14) [Activation](2)
[TensorRT] INFO: Tactic 6 time 3.44688
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 12) [Convolution] + (Unnamed Layer* 14) [Activation](14)
[TensorRT] INFO: Tactic 3146172331490511787 time 2.18742
[TensorRT] INFO: Tactic 3528302785056538033 time 3.88074
[TensorRT] INFO: Tactic 5443600094180187792 time 4.26378
[TensorRT] INFO: Tactic 5824828673459742858 time 2.11472
[TensorRT] INFO: Tactic -6618588952828687390 time 3.1528
[TensorRT] INFO: Tactic -6362554771847758902 time 2.26848
[TensorRT] INFO: Tactic -2701242286872672544 time 3.07386
[TensorRT] INFO: Tactic -2535759802710599445 time 2.21392
[TensorRT] INFO: Tactic -675401754313066228 time 2.2447
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 12) [Convolution] + (Unnamed Layer* 14) [Activation](1)
[TensorRT] INFO: Tactic 0 time 2.87024
[TensorRT] INFO: Tactic 1 scratch requested: 512, available: 0
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 12) [Convolution] + (Unnamed Layer* 14) [Activation](33)
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 15) [Deconvolution](4)
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 15) [Deconvolution](16)
[TensorRT] INFO:
[TensorRT] INFO: --------------- Timing (Unnamed Layer* 15) [Deconvolution](22)
[TensorRT] INFO: Tactic 0 scratch requested: 655360, available: 0
[TensorRT] ERROR: Internal error: could not find any implementation for node (Unnamed Layer* 15) [Deconvolution], try increasing the workspace size with IBuilder::setMaxWorkspaceSize()
[TensorRT] ERROR: ../builder/tacticOptimizer.cpp (1330) - OutOfMemory Error in computeCosts: 0
I know that converter doesn’t implement whole functionality of torch. And i checked all classes used in my model. All except nn.Sequential are supported. As for nn.Sequential - in the example notebook (torch2trt github) for segmentation used deeplabv3_resnet101 model, which contains this layer.
Any suggestions, how can convert my model successfully?
