Hi All,
I have a set of subroutines that solves certain types of differential equations. The algorithm makes use of some constants that are rational numbers, and are therefore exact. These constants are set in a subroutine that is called many times:
IMPLICIT NONE
INTEGER, INTENT(IN) :: ns
INTEGER, INTENT(IN) :: nsd
REAL(KIND=dp), INTENT(OUT) :: a(nsd,ns)
REAL(KIND=dp), INTENT(OUT) :: b(ns)
IF(ns == 6)THEN
b(1)=88.0_dp/1024.0_dp
b(2)=185.0_dp/1024.0_dp
b(3)=239.0_dp/1024.0_dp
a(1,1)=44.0_dp/1024.0_dp
a(1,2)=-15.0_dp/1024.0_dp
a(1,3)=10.0_dp/1024.0_dp
a(1,4)=-6.0_dp/1024.0_dp
END IF
I have a module which selects the KIND:
! gives REAL*16
! integer, parameter :: dp = selected_real_kind(33,4931)
! gives REAL*10
! integer, parameter :: dp = selected_real_kind(18,4931)
! gives double precision, REAL*8
integer, parameter :: dp = selected_real_kind(15,307)
! gives single precision, REAL*4
integer, parameter :: sp = selected_real_kind(6,37)
The KIND is usually set to the equivalent of REAL8, but the equivalents to REAL10 and REAL*16 are possible for some compilers.
So the questions is: Is it better to leave the rational expressions, or should I put in the decimal forms, like
b(3) = 0.2333984375_dp
As noted above, this routine is called many times. I realize there might be on the order of microseconds in the difference of the execution time, but it is the principle of the matter.
Also related, another routine returns the weights and abscissa for Gaussian quadrature. These can be precomputed to large number of digits. For example
IF(norder == 4)THEN
ww(1)= 6.52145154862546142626936050778001E-01_dp
xx(1)=-3.39981043584856264802665759103245E-01_dp
ww(2)= 6.52145154862546142626936050778001E-01_dp
xx(2)= 3.39981043584856264802665759103245E-01_dp
ww(3)= 3.47854845137453857373063949221999E-01_dp
xx(3)=-8.61136311594052575223946488892809E-01_dp
ww(4)= 3.47854845137453857373063949221999E-01_dp
xx(4)= 8.61136311594052575223946488892809E-01_dp
RETURN
END IF
These coefficients are suitable up to KIND=16. I assume the compiler has enough sense to take the leading digits as needed when KIND=4 or KIND=8.
Jerry
