Question about nvpps and PTP
I am currently using nvpps on Jetson AGX Orin to capture a gpio pps event timestamp. After reading the document about time sync and source code of kernel, I think perhaps (not sure) it can get the timestamp of trigger event in different time source (ptp0, tsc…).
Here is the steps i had done:
  1. modify dt and flash
  2. check nvpps indeed in gpio mode.
  3. write a user code to get event timestamp
It worked and got a timestamp of event, but the stamp looks weird, it doesn’t match the timestamp of /dev/ptp0. Here is the description of my question:
First I check dmesg message is normal:
[ 10.296576] nvpps c6a0000.nvpps: nvpps_probe
[ 10.296721] nvpps c6a0000.nvpps: primary-emac found ethernet@6800000
[ 10.296733] nvpps c6a0000.nvpps: primary emac base address 0x6810000
[ 10.296736] nvpps c6a0000.nvpps: using ptp notifier method on emac ethernet@6800000
[ 10.296737] nvpps c6a0000.nvpps: tsc_res_ns(32)
[ 10.299277] nvpps c6a0000.nvpps: gpio_to_irq(273)
[ 10.299385] nvpps c6a0000.nvpps: HTE request timestamp succeed
[ 10.302528] nvpps c6a0000.nvpps: nvpps cdev(488:0)
[ 10.302564] nvpps nvpps0: Registered IRQ 273 for nvpps
[ 10.302588] nvpps c6a0000.nvpps: TSC config ptx 0x113
Second I copied the nvpps_ioctl.h from source code and write a test code.
nvpps_test.txt (2.1 KB)
And then I run the ptp4l as grand master by this tutorial and get the ptp time by command:
sudo ptp4l -m -f ./ptp4lgm.conf
sudo phc_ctl /dev/ptp0 get
phc_ctl[5305.788]: clock time is 1763965467.366055372 or Mon Nov 24 14:24:27 2025
Finally i run the compiled test code and get result like this, obviously the ptp time is not correct and also the irq_latency is weird:
sudo ./nvpps_test
Opening /dev/nvpps0…
Driver Version: 0.2
API Version:    0.4
evt_mode = 1 (GPIO)
tsc_mode = 0 (nsec)
Waiting for events…
Event 2968:
PTP time:         1764100922068881168 ns
Secondary PTP:    0 ns
TSC:              4399585001120 (nsec)
IRQ latency:      18446607686574694880 ns
Resolution:       32 ns
I use a button to trigger the pps gpio input, Looking forward any advice and correction, thank you.
I reviewed the source code again, but I still have no idea why the timestamp is behaving strangely. The timestamp I’m getting is neither the system time nor the PTP time — it’s two days after the current time, and it increases faster than normal time.
From what I understand, the driver obtains PTP timestamps either by using the system clock or by reading from the PTP-capable EMAC hardware. The synchronization between the PTP clock and the TSC should work in both GPIO mode and timer mode.
Below is my device tree configuration for nvpps:
	nvpps {
		status = "okay";
		compatible = "nvidia,tegra234-nvpps";
		reg = <0x0 0xc6a0000 0x0 0x1000>;
		primary-emac = <&mgbe0>;
		sec-emac = <&mgbe0>;
		nvpps-gpios = <&gpio_aon TEGRA234_AON_GPIO(BB, 0) GPIO_ACTIVE_HIGH>;
		timestamps = <&hte_aon TEGRA234_AON_GPIO(BB, 0)>;
		timestamp-names = "nvpps_gpio";
I have not enabled memmap_phc_regs yet, but it does not appear to be related to this issue. Is that correct?
I’ve been working on this for a while but haven’t been able to make progress. Any insights or help would be greatly appreciated.
Hi peichun.huang,
Could you use pps-gpio driver instead and refer to the following threads for the similar use case?
Pps_gpio interrupt not asserted - #8 by KevinFFF
PPS input to GPIO on Jetpack 6.1 - #8 by erik93
I’m using devkit, the version is 6.2.1-r36.4.4, thank you for your advice, I will try pps-gpio.
But now I got a little confused, in which case, we can only use nvpps? Or we can use pps-gpio to solve all these external trigger in/out problems. I saw someone modify nvpps source code to generate pps pulse to other device, was it suppose to do that?
By the way, I found that when I use jetson-io.py to configure PWM, it may override the changes I applied before flashing or use overlay. Is there a way to prevent this from happening, or I will need to write all the overlay into one file?
PPS-GPIO test update:
I tried the overlay method with pwm enabled in same overlay file.
jetson-io-hdr40-user-custom.dts.txt (1.6 KB)
I measure the pwm signal and confirm it is correct (10Hz). Also I check the dmesg and gpio, and the config.
[    0.099377] pps_core: LinuxPPS API ver. 1 registered
[    0.099380] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.182700] pps pps0: new PPS source ktimer
[    0.182705] pps pps0: ktimer PPS source registered
[    0.182708] pps_ldisc: PPS line discipline registered
[    3.998683] pps pps1: new PPS source pps-gpio.-1
[    3.998742] pps pps1: Registered IRQ 233 as PPS source
[   10.842838] nvpps c6a0000.nvpps: nvpps_probe
[   10.842982] nvpps c6a0000.nvpps: primary-emac found ethernet@6800000
[   10.842996] nvpps c6a0000.nvpps: primary emac base address 0x6810000
[   10.843000] nvpps c6a0000.nvpps: using ptp notifier method on emac ethernet@6800000
[   10.843002] nvpps c6a0000.nvpps: tsc_res_ns(32)
[   10.843014] nvpps c6a0000.nvpps: PPS GPIO not provided in DT, only Timer mode available
[   10.845167] nvpps c6a0000.nvpps: nvpps cdev(488:0)
[   10.845240] nvpps c6a0000.nvpps: TSC config ptx 0x113
 gpio-357 (PC.00               |pps-gpio            ) in  lo IRQ ACTIVE LOW
$ zcat /proc/config.gz | less | grep PPS
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
CONFIG_PPS_CLIENT_KTIMER=y
CONFIG_PPS_CLIENT_LDISC=y
CONFIG_PPS_CLIENT_GPIO=y
# PPS generators support
And then I test with pwm output directly to pin 16 (gpio 357), however no irq were triggered, thus of course the ppstest failed.
233: 0 0 0 0 0 0 0 0 2200000.gpio 9 Edge pps-gpio.-1
Update
  1. Tried compile with CONFIG_PPS_CLIENT_GPIO=m and load module manually, still got same result.
  2. Tried modify code like this topic Enable PSS on Jetson-GPIO Pin Header - #26 by KevinFFF, failed with error:
[    3.955310] pps-gpio pps-gpio: error -ENOENT: failed to request PPS GPIO
[    3.955324] pps-gpio: probe of pps-gpio failed with error -2
  1. rmmod the pps-gpio and tried gpiomon 0 9 and got nothing
Thanks for your patience and kindly reply.
Success
I finally use pin 12 (gpio 398) and successfully conduct pps interrupt and ppstest. I think it may be hardware issue, and here is my summary of debug steps, hope it may help for someone struggling.
  1. must check the IO was triggered at first by gpiomon $chip %offset, you can use sudo cat /sys/kernel/debug/gpio to find chip and offset.
  2. check module was load correctly by sudo cat /sys/kernel/debug/gpio and sudo dmesg | grep pps.
P.S. It seems the IO output of jetson is not powerful enough to push the input perfectly at 10Hz, the voltage would drop sometime.
