My network has input shape (-1, 3, 112, 112) meaning it supports dynamic batch sizes.
I am registering several optimization profiles as follows. You can assume that m_options.optBatchSizes = std::vector<unsigned int>{2, 4, 8};
// Specify the optimization profiles and the
IOptimizationProfile* defaultProfile = builder->createOptimizationProfile();
defaultProfile->setDimensions(inputName, OptProfileSelector::kMIN, Dims4(1, m_inputC, m_inputH, m_inputW));
defaultProfile->setDimensions(inputName, OptProfileSelector::kOPT, Dims4(1, m_inputC, m_inputH, m_inputW));
defaultProfile->setDimensions(inputName, OptProfileSelector::kMAX, Dims4(m_options.maxBatchSize, m_inputC, m_inputH, m_inputW));
config->addOptimizationProfile(defaultProfile);
// Specify all the optimization profiles.
for (const auto& optBatchSize: m_options.optBatchSizes) {
if (optBatchSize == 1) {
continue;
if (optBatchSize > m_options.maxBatchSize) {
throw std::runtime_error("optBatchSize cannot be greater than maxBatchSize!");
IOptimizationProfile* profile = builder->createOptimizationProfile();
profile->setDimensions(inputName, OptProfileSelector::kMIN, Dims4(1, m_inputC, m_inputH, m_inputW));
profile->setDimensions(inputName, OptProfileSelector::kOPT, Dims4(optBatchSize, m_inputC, m_inputH, m_inputW));
profile->setDimensions(inputName, OptProfileSelector::kMAX, Dims4(m_options.maxBatchSize, m_inputC, m_inputH, m_inputW));
config->addOptimizationProfile(profile);
Later in my code when I am running inference, I am trying to switch the optimization profile based on the batch size. If the batch size matches one of the registered profiles, then I want to switch the profile. You can assume that m_optProfIndx is a std::unordered_map<int, int> mapping the batch size to the registered profileIndex.
// Determine if the batch size is in our optimization profile
auto it = m_optProfIndx.find(batchSize);
if (it != m_optProfIndx.end()) {
// Switch the optimization profile
m_context->setOptimizationProfileAsync(it->second, m_cudaStream);
m_context->setBindingDimensions(0, inputDims);
When I try running my code, it crashed with error message:
IExecutionContext::setBindingDimensions: bindingIndex 0 is not in profile 1. Using bindingIndex = 2 instead.
1: [convolutionRunner.cpp::executeConv::458] Error Code 1: Cudnn (CUDNN_STATUS_EXECUTION_FAILED)
terminate called after throwing an instance of 'std::runtime_error'
It looks like it is crashing on the call to m_context->setBindingDimensions(0, inputDims);.
For reference, inputDims is defined as follows: Dims4 inputDims = {static_cast<int32_t>(inputFaceChips.size()), m_inputC, m_inputH, m_inputW};, where inputFaceChips.size() is the current batch size.
