Questions about Gst-nvmultistreamtiler usage
When the four-channel flow data is used to infer the model, Gst-nvmultistreamtiler is used before the nvinfer plug-in to concatenate into a 2×2 big picture. Does nvinfer infer infer directly infer with this big picture?
It depends on your model.
The input form of my network is: 4 inputs are stitched together into a 2×2 large graph as input. According to what you said, my understanding is that I can directly use the output of the Gst-nvmultistreamtiler plugin. Can I interpret it that way? Looking forward to your reply,thank you
Yes. Basically, nvinfer can also process the picture size to the model input. If you want process by yourself, please refer to our preprocess plugin.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvdspreprocess.html
I want to ask a question: deepstream reads local streams of jpeg images. How to get the name of the image in the probe of the plug-in later.
You can get it with the g_object_get (G_OBJECT (src), "location", &location, NULL); API.
Please open a new topic if you have new problem for better reference for others. Thanks
