Hi
I’m trying to stream the video feed from my camera attached to the Jetson Nano. I’m kind of confused with how to use Gstreamer properly.
(note I have to use v4l2src over nvarguscamerasrc as my camera doesn’t support nvargus)
The first thing I tried to do was simply preview the video, which I was successful using
gst-launch-1.0 v4l2src device="/dev/video0" ! "video/x-raw, width=1280, height=400, format=GRAY8" ! nvvidconv ! 'video/x-raw(memory:NVMM), format=I420' ! nvoverlaysink sync=false
However, I’m quite confused why I have to convert the grayscale format to I420 before it can work with nvoverlaysink / autovideosink (why can’t I leave it in GRAY8?). This is because I plan to stream the video over RTSP, and would like to keep it in a grayscale format for better performance.
I would then like to publish this using RTSP, so I compiled test-launch as in the FAQ, and this pipeline works for me:
./test-launch "v4l2src ! video/x-raw, width=1280, height=400, framerate=20/1, format=GRAY8 ! nvvidconv ! video/x-raw(memory:NVMM), format=(string)I420 ! omxh264enc ! video/x-h264, stream-format=byte-stream, alignment=au ! h264parse ! rtph264pay name=pay0 pt=96"
Similar to my first question, how can I change this pipeline to only send 8-bit greyscale instead of 3 channels?
Here are the formats available on my camera:
(base) j@nano:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'GREY'
Name : 8-bit Greyscale
Index : 1
Pixel Format: 'Y10 '
Name : 10-bit Greyscale
Index : 2
Pixel Format: 'Y16 '
Name : 16-bit Greyscale
and the output of gst-device-monitor-1.0 in case it’s helpful
(base) j@nano:~$ gst-device-monitor-1.0
Device found:
name : vi-output, arducam-csi2 6-000c
class : Video/Source
caps : video/x-raw, format=(string)GRAY8, width=(int)2560, height=(int)800, framerate=(fraction)[ 0/1, 2147483647/1 ];
video/x-raw, format=(string)GRAY8, width=(int)2560, height=(int)720, framerate=(fraction)[ 0/1, 2147483647/1 ];
video/x-raw, format=(string)GRAY8, width=(int)1280, height=(int)400, framerate=(fraction)[ 0/1, 2147483647/1 ];
video/x-raw, format=(string)GRAY8, width=(int)640, height=(int)200, framerate=(fraction)[ 0/1, 2147483647/1 ];
video/x-raw, format=(string)GRAY16_LE, width=(int)2560, height=(int)800, framerate=(fraction)[ 0/1, 2147483647/1 ];
video/x-raw, format=(string)GRAY16_LE, width=(int)2560, height=(int)720, framerate=(fraction)[ 0/1, 2147483647/1 ];
video/x-raw, format=(string)GRAY16_LE, width=(int)1280, height=(int)400, framerate=(fraction)[ 0/1, 2147483647/1 ];
video/x-raw, format=(string)GRAY16_LE, width=(int)640, height=(int)200, framerate=(fraction)[ 0/1, 2147483647/1 ];
properties:
udev-probed = true
device.bus_path = platform-54080000.vi
sysfs.path = /sys/devices/50000000.host1x/54080000.vi/video4linux/video0
device.subsystem = video4linux
device.product.name = "vi-output\,\ arducam-csi2\ 6-000c"
device.capabilities = :capture:
device.api = v4l2
device.path = /dev/video0
v4l2.device.driver = tegra-video
v4l2.device.card = "vi-output\,\ arducam-csi2\ 6-000c"
v4l2.device.bus_info = platform:54080000.vi:0
v4l2.device.version = 264649 (0x000409c9)
v4l2.device.capabilities = 2216689665 (0x84200001)
v4l2.device.device_caps = 69206017 (0x04200001)
gst-launch-1.0 v4l2src ! ...
