I have several questions about memory address…
First, I want to know the starting address (and end address or range) of global and shared memory spaces.
Is there a way to know the starting address of global memory space? Or, are they specified in some document? (Plz let me know)
In regular systems, I could know the addresses (including range) of stack space (e.g., 0x8000000), heap space, etc.
Second, look at the following example code.
void myHost() {
// Note: "float *check" has global memory (I omitted the allocation part)
myKernel<<<1,256>>>(check);
// Load check to host memory
// Print check
__global__ void myKernel(float *check) {
int i, j;
float temp;
float a[4][4];
float b[4][4];
// store memory addresses to check
if (threadIdx.x == 0) {
check[0] = (int)a;
check[1] = (int)b;
subKernel(a);
__device__ void subKernel(float (*a)[4]) {
// do nothing
Actually, check[0] had value 0, and check[1] had value 64. Can anybody explain the meaning of these values for me? (Why the memory address of “a” has 0?)
(Here, some strange thing happened: sometimes check[0] and check[1] showed altered values. That is, in some case, check[0] had value 64 and check[1] had value 0.)
In case when I tried “check[2] = (int)&i;”, I got a critical error. I guess this is because “i” is stored in a register, thus I can’t get its address.
If both a[4][4] and b[4][4] are stored in registers, how could I execute even “check[0] = (int)a;”? (So I don’t think a and b are registers)
I read some articles about local memory. The author said that normally automatic variables are stored in registers, and if the variables are too many to be held in registers, then global memory is used for them.
In this case, “a[4][4] and b[4][4]” are stored in global memory? (because I could do “check[0] = (int)a;”)
Third, if not the case (i.e., a[4][4] and b[4][4] are stored in registers), how can I pass them into “subKernel”? (I cannot know the addresses of registers!)
And how can I update the variables of registers (i.e., “i” and “j” in the above example) in subKernel?
Regards,
