Hi all,
For maxwell streaming multiprocessor, the warp scheduler picks one or two instructions from a ready warp to issue cycle by cycle. My questions are:
what would make a wrap stall? L2 cache miss, function calls or anything else.
is it preemptive or not? I mean if nothing makes the warp stall, will the scheduler let it run till the end and then issue instructions of other warps?
there are four schedulers in every maxwell SM. I wonder is there any way to find out which warps are scheduled by the same scheduler? For example, I got 8 warps from 0 to 7, so there should be 2 warps scheduled by each scheduler. I wanna know which warp is scheduled with warp 0.
Looking forward to any reply, thanks.
Every instruction has either a fixed or variable latency. If some other instruction is dependent on the result of another then that instruction will stall until the required number of clocks transpire. Other warps with ready instructions will execute during these stalls. More on that here: https://github.com/NervanaSystems/maxas/wiki/Control-Codes
Thanks a lot. Just one more question. As you indicated, schedulers distribute warps in a round-robin fashion.How do you know this, is there any document or something else? Thanks again.
