Questions re OptiX implementation
I have some questions regarding OptiX implementation which may help me shed light on some observations in my thesis.
Does OptiX in any way use shared memory to optimize access to buffers?
How does OptiX manage the stack, ie. if i have some big struct in the payload (random number state), is it passed up and down?
I guess that was it for now but I may have others as well.
Hi xtc,
I had to ask James for this one :-). His response:
No. OptiX current uses shared memory only for certain intra-warp communication and SM wide load balancing. Note that you should not use shared memory directly in your own programs, because OptiX manages all the shared memory and may not leave any available for your programs.
Stack memory is currently stored in local memory. At this time ray payloads are passed by pointer and not by value, so there is no copying of the ray payload occurring when passing the payload around. You will of course get copying if you do rpl = rpl2.
Note that these are current implementation details and can of course change for future versions of OptiX.
Best,
GM
