Hello, I have a questions regarding the Sample provided by Nvidia called DCT8x8 which is applied to an image to execute the algorithm in parallel. more info: http://developer.download.nvidia.com/compute/DevZone/C/html/C/src/dct8x8/doc/dct8x8.pdf
The code executes forward DCT and it’s inverse on a BMP image.
My first question is, is there a way to calculate the only the forward transform to obtain the JPG?
Second, there are several parts of the code that I don’t understand I hope someone that is familiar with DTC and CUDA can help me with those.
First: in the file dtc8x8_gold.cpp the program uses the following matrices:
const float DCTv8matrix[BLOCK_SIZE2] =
0.3535533905932738f, 0.4903926402016152f, 0.4619397662556434f, 0.4157348061512726f, 0.3535533905932738f, 0.2777851165098011f, 0.1913417161825449f, 0.0975451610080642f,
0.3535533905932738f, 0.4157348061512726f, 0.1913417161825449f, -0.0975451610080641f, -0.3535533905932737f, -0.4903926402016152f, -0.4619397662556434f, -0.2777851165098011f,
0.3535533905932738f, 0.2777851165098011f, -0.1913417161825449f, -0.4903926402016152f, -0.3535533905932738f, 0.0975451610080642f, 0.4619397662556433f, 0.4157348061512727f,
0.3535533905932738f, 0.0975451610080642f, -0.4619397662556434f, -0.2777851165098011f, 0.3535533905932737f, 0.4157348061512727f, -0.1913417161825450f, -0.4903926402016153f,
0.3535533905932738f, -0.0975451610080641f, -0.4619397662556434f, 0.2777851165098009f, 0.3535533905932738f, -0.4157348061512726f, -0.1913417161825453f, 0.4903926402016152f,
0.3535533905932738f, -0.2777851165098010f, -0.1913417161825452f, 0.4903926402016153f, -0.3535533905932733f, -0.0975451610080649f, 0.4619397662556437f, -0.4157348061512720f,
0.3535533905932738f, -0.4157348061512727f, 0.1913417161825450f, 0.0975451610080640f, -0.3535533905932736f, 0.4903926402016152f, -0.4619397662556435f, 0.2777851165098022f,
0.3535533905932738f, -0.4903926402016152f, 0.4619397662556433f, -0.4157348061512721f, 0.3535533905932733f, -0.2777851165098008f, 0.1913417161825431f, -0.0975451610080625f
const float DCTv8matrixT[BLOCK_SIZE2] =
0.3535533905932738f, 0.3535533905932738f, 0.3535533905932738f, 0.3535533905932738f, 0.3535533905932738f, 0.3535533905932738f, 0.3535533905932738f, 0.3535533905932738f,
0.4903926402016152f, 0.4157348061512726f, 0.2777851165098011f, 0.0975451610080642f, -0.0975451610080641f, -0.2777851165098010f, -0.4157348061512727f, -0.4903926402016152f,
0.4619397662556434f, 0.1913417161825449f, -0.1913417161825449f, -0.4619397662556434f, -0.4619397662556434f, -0.1913417161825452f, 0.1913417161825450f, 0.4619397662556433f,
0.4157348061512726f, -0.0975451610080641f, -0.4903926402016152f, -0.2777851165098011f, 0.2777851165098009f, 0.4903926402016153f, 0.0975451610080640f, -0.4157348061512721f,
0.3535533905932738f, -0.3535533905932737f, -0.3535533905932738f, 0.3535533905932737f, 0.3535533905932738f, -0.3535533905932733f, -0.3535533905932736f, 0.3535533905932733f,
0.2777851165098011f, -0.4903926402016152f, 0.0975451610080642f, 0.4157348061512727f, -0.4157348061512726f, -0.0975451610080649f, 0.4903926402016152f, -0.2777851165098008f,
0.1913417161825449f, -0.4619397662556434f, 0.4619397662556433f, -0.1913417161825450f, -0.1913417161825453f, 0.4619397662556437f, -0.4619397662556435f, 0.1913417161825431f,
0.0975451610080642f, -0.2777851165098011f, 0.4157348061512727f, -0.4903926402016153f, 0.4903926402016152f, -0.4157348061512720f, 0.2777851165098022f, -0.0975451610080625f
float Q[BLOCK_SIZE2] =
32.f, 33.f, 51.f, 81.f, 66.f, 39.f, 34.f, 17.f,
33.f, 36.f, 48.f, 47.f, 28.f, 23.f, 12.f, 12.f,
51.f, 48.f, 47.f, 28.f, 23.f, 12.f, 12.f, 12.f,
81.f, 47.f, 28.f, 23.f, 12.f, 12.f, 12.f, 12.f,
66.f, 28.f, 23.f, 12.f, 12.f, 12.f, 12.f, 12.f,
39.f, 23.f, 12.f, 12.f, 12.f, 12.f, 12.f, 12.f,
34.f, 12.f, 12.f, 12.f, 12.f, 12.f, 12.f, 12.f,
17.f, 12.f, 12.f, 12.f, 12.f, 12.f, 12.f, 12.f
float C_a = 1.387039845322148f; //!< a = (2^0.5) * cos( pi / 16); Used in forward and inverse DCT.
float C_b = 1.306562964876377f; //!< b = (2^0.5) * cos( pi / 8); Used in forward and inverse DCT.
float C_c = 1.175875602419359f; //!< c = (2^0.5) * cos(3 * pi / 16); Used in forward and inverse DCT.
float C_d = 0.785694958387102f; //!< d = (2^0.5) * cos(5 * pi / 16); Used in forward and inverse DCT.
float C_e = 0.541196100146197f; //!< e = (2^0.5) * cos(3 * pi / 8); Used in forward and inverse DCT.
float C_f = 0.275899379282943f; //!< f = (2^0.5) * cos(7 * pi / 16); Used in forward and inverse DCT.
can someone please explain me why are those values being used and the reason for their usage?
also in the file dct8x8_kernel_quantization.cu there is another Q matrix, that my guess is that is indicating the threshold for quantization, and if so, why those values?
__constant__ short Q[] =
32, 33, 51, 81, 66, 39, 34, 17,
33, 36, 48, 47, 28, 23, 12, 12,
51, 48, 47, 28, 23, 12, 12, 12,
81, 47, 28, 23, 12, 12, 12, 12,
66, 28, 23, 12, 12, 12, 12, 12,
39, 23, 12, 12, 12, 12, 12, 12,
34, 12, 12, 12, 12, 12, 12, 12,
17, 12, 12, 12, 12, 12, 12, 12
my last question is,
I have the feeling that those values are specified for the “barbara.bmp” image which if true, will not let me use a different image than the defaul one, and that is what I’m looking for to do, besides understanding the code.
Thank you very much for your help!
Saul
