__constant__ float DCTv8matrix[] = {
0.3535533905932738f, 0.4903926402016152f, 0.4619397662556434f, 0.4157348061512726f, 0.3535533905932738f, 0.2777851165098011f, 0.1913417161825449f, 0.0975451610080642f,
0.3535533905932738f, 0.4157348061512726f, 0.1913417161825449f, -0.0975451610080641f, -0.3535533905932737f, -0.4903926402016152f, -0.4619397662556434f, -0.2777851165098011f,
0.3535533905932738f, 0.2777851165098011f, -0.1913417161825449f, -0.4903926402016152f, -0.3535533905932738f, 0.0975451610080642f, 0.4619397662556433f, 0.4157348061512727f,
0.3535533905932738f, 0.0975451610080642f, -0.4619397662556434f, -0.2777851165098011f, 0.3535533905932737f, 0.4157348061512727f, -0.1913417161825450f, -0.4903926402016153f,
0.3535533905932738f, -0.0975451610080641f, -0.4619397662556434f, 0.2777851165098009f, 0.3535533905932738f, -0.4157348061512726f, -0.1913417161825453f, 0.4903926402016152f,
0.3535533905932738f, -0.2777851165098010f, -0.1913417161825452f, 0.4903926402016153f, -0.3535533905932733f, -0.0975451610080649f, 0.4619397662556437f, -0.4157348061512720f,
0.3535533905932738f, -0.4157348061512727f, 0.1913417161825450f, 0.0975451610080640f, -0.3535533905932736f, 0.4903926402016152f, -0.4619397662556435f, 0.2777851165098022f,
0.3535533905932738f, -0.4903926402016152f, 0.4619397662556433f, -0.4157348061512721f, 0.3535533905932733f, -0.2777851165098008f, 0.1913417161825431f, -0.0975451610080625f
what is that matrix for ?
__global__ void CUDAkernel1DCT(float *Dst, int ImgWidth, int OffsetXBlocks, int OffsetYBlocks)
// Block index
const int bx = blockIdx.x + OffsetXBlocks;
const int by = blockIdx.y + OffsetYBlocks;
as i have understand we have an id for each block , (x,y) in the grid.
now we want the block (8X8 pix. ) id (not cuda block id) , but as mentioned
in the DCT documentation we have cuda_block for every >> macroblock
– which contains of 4 or 16 vertical 8X8 pix. blocks
so how do we get the index of the right 8X8 pix. block ?
// Texture coordinates
const float tex_x = (float)( (bx << BLOCK_SIZE_LOG2) + tx ) + 0.5f;
const float tex_y = (float)( (by << BLOCK_SIZE_LOG2) + ty ) + 0.5f;
can you explain for me what’s the operator << means ?
in other words what do the command :
do ?
and what is that “0.5f” ?
