You have several errors:
→ first: your blocksize is 2??? it’s very strange;
→ second: 1280*720 = 921600/2 = 460800 blocks??? Are you sure? You have to check the limit of the grid. In the CCs 1.0,1.1,1.2, 1.3 and 2.0 is 65535 blocks. If you exceeds this limit, your execution does not fail but the kernel is not executed.
this code is about the longest common subsequence problem
__global__ void LCS( int* C, char* A, char* B, int wA, int wB)
int current_Index = blockIdx.x * blockDim.x + thread_Id;
int wC=wA+1;
int j,i;
int mn=0;
if(wA>wB)
//for(k=0;k<=wA;k++){
if (current_Index<=wA)
j=current_Index;
i=0;
mn=min(current_Index,wB);
while((i<=mn)||(j>0))
if (i==0 && j==0)
C[i*wC+j]=0;
if (A[current_Index-1]==B[current_Index-1])
C[i*wC+j]=C[(i-1)*wC+j-1]+1;
else
C[i*wC+j]=max(C[(i-1)*wC+j],C[i*wC+j-1]);
if (i<=mn)
i=i+1;
if (j>0)
j=j+1;
__syncthreads();
current_Index = blockIdx.x * blockDim.x + thread_Id+1;;
if(current_Index<=wB)
j=wA;
i=current_Index;
while(i<=wB)
else
i=i+1;
j=j-1;
__syncthreads();
(the parallelism exists in the elements of the antidiagonal)
Which is equivalent to
for (i=0;i<N+1;i++)
C[i][0]=0;
for (j=1;j<M+1;j++)
C[0][j]=0;
for (i=1;i<N+1;i++)
for(j=1;j<M+1;j++)
if (X[j-1]==Y[i-1])
C[i][j]=C[i-1][j-1]+1;
else
C[i][j]=max(C[i-1][j],C[i][j-1]);
in C
block_size=16
wA= 2*Block_size //dimension of the array of char A
wB= bloch_size // dimension of the array of char B
when i execute the kernel i get wrong result in the matrix C (the matrix result of the dynamic programming of LCS)
Can you help me to find the error? if it is in the index of matrix and char’s array or either
int wC=wA+1;
int j,i;
int mn=0;
if(wA>wB)
j=current_Index;
i=0;
if (i==0 && j==0)
C[i*wC+j]=0;
else
if (i<=mn)
i=i+1;
if (j>0)
j=j+1;
__syncthreads();
j=wA;
i=current_Index;
while(i<=wB)
else
i=i+1;
j=j-1;
__syncthreads();
for (i=0;i<N+1;i++)
C[i][0]=0;
for (j=1;j<M+1;j++)
C[0][j]=0;
for (i=1;i<N+1;i++)
for(j=1;j<M+1;j++)
if (X[j-1]==Y[i-1])
else
in C
block_size=16
Hi!
Well, i have any doubts about your code:
→ what is thread_Id?? Perhaps you wanted to write threadIdx.x? Did not?
→ If you wanted to write threadIdx.x, you are trying to access to A[-1] = B[-1] in the sentence ‘if (A[current_Index-1]==B[current_Index-1])’
This is a bit strange.
→ 16 threads is a halfwarp, i would use 32 of blockSize. The size of blocks is always better if it is a multiple of 32.
Hi!
As i said before, this code ‘A[current_Index-1]==B[current_Index-1]’ when current_index = 0 (thread #0 in block #0) is attempting to
access a A[-1] and B[-1]. This is an error. The range of current_index is [0,(blockDim.x*gridDim.x-1)], is not? Then, the correct access would be A[current_index] and B[current_index].
More, if you have changed the size of blocks (16 to 32), you have to change the size of arrays and its initialization too.
yes i changed it to A[current_Index] the same thing in B
the size of the arrays A and B are:
my problem is that i want to fill the matrix result anti-diagonal by anti-diagonal because in my algorithm every cell C[i][j] depends on the cell C[i-1][j-1] , C[i-1][j] and C[i][j-1]
so we can fill one anti-diagonal in the same time (in parallel)
is there any change in the index to realize this parallelism?
