Problems in your code:
GETINDEX(LENGTH, WIDTH, DEPTH) calculates out to 1110. This is more than the actual matrix sizes needed, but this is not a critical problem.
cudaMalloc, like malloc, takes a size in bytes. Therefore you should pass a size parameter to each of your cudaMalloc operations that is the same as the size parameter for your malloc operations:
cudaMalloc((void**)&dMatA, matrixSize);
cudaMalloc((void**)&dMatB, matrixSize);
cudaMalloc((void**)&dMatC, matrixSize);
- You are launching way too many blocks. Each block is 10x10x10 which is acceptable. But the grid calculation is very large:
dim3 block(LENGTH, WIDTH,DEPTH);
dim3 grid(matrixSize / LENGTH, matrixSize/ WIDTH,matrixSize/DEPTH);
You are launching ~4000/10 = ~400 blocks in each dimension! You only actually need 1 block in this case. But even that is not a critical problem if you handle the extra blocks correctly in your kernel with a proper thread check:
if ((len < LENGTH) && (wid < WIDTH) && (dep < DEPTH))
inMatC[GETINDEX(len, wid, dep)] = inMatA[GETINDEX(len, wid, dep)] + inMatB[GETINDEX(len, wid, dep)];
With changes like those, I was able to get your code working without error:
$ cat t74.cu
#include <stdio.h>
#define LENGTH 10
#define WIDTH 10
#define DEPTH 10
#define GETINDEX(x,y,z) (x+y*DEPTH+z*WIDTH*DEPTH)
__global__ void
matrixCalc(float* inMatA, float* inMatB, float* inMatC) {
int len = blockIdx.x*blockDim.x + threadIdx.x;
int wid = blockIdx.y*blockDim.y + threadIdx.y;
int dep = blockIdx.z*blockDim.z + threadIdx.z;
int main(int argc, char** argv) {
// 行列のサイズをバイト単位で算出
int matrixSize = sizeof(float) * GETINDEX(LENGTH,WIDTH,DEPTH);
// ホスト側の行列変数設定
float* hMatA;
float* hMatB;
float* hMatC;
// 行列変数のメモリ確保
hMatA = (float*)malloc(matrixSize);
hMatB = (float*)malloc(matrixSize);
// 初期値設定
int len, row,wid;
for(row=0;row<DEPTH;row++){
for (wid = 0; wid < WIDTH; wid++) {
for (len = 0; len < LENGTH; len++) {
hMatA[GETINDEX(len,wid,row)] = 2;
hMatB[GETINDEX(len, wid, row)] = 1;
float* dMatA;
float* dMatB;
float* dMatC;
cudaMemcpy(dMatA, hMatA, matrixSize, cudaMemcpyHostToDevice);
cudaMemcpy(dMatB, hMatB, matrixSize, cudaMemcpyHostToDevice);
printf("size = %d\n", GETINDEX(LENGTH,WIDTH,DEPTH));
matrixCalc << <grid, block >> >(dMatA, dMatB, dMatC);
cudaThreadSynchronize();
hMatC = (float*)malloc(matrixSize);
cudaMemcpy(hMatC, dMatC, matrixSize, cudaMemcpyDeviceToHost);
for (row = 0; row<DEPTH; row++) {
for (wid = 0; wid < WIDTH; wid++) printf("%f, ",hMatC[GETINDEX(len,wid,row)]);
printf("\n");
printf("\n\n");
free(hMatA);
free(hMatB);
free(hMatC);
cudaFree(dMatA);
cudaFree(dMatB);
cudaFree(dMatC);
nvidia@nvidia-DiGiTS-Dev-Box:~/bobc$ nvcc -arch=sm_61 -o t74 t74.cu
nvidia@nvidia-DiGiTS-Dev-Box:~/bobc$ cuda-memcheck ./t74
========= CUDA-MEMCHECK
size = 1110
3.000000, 3.000000, 3.000000, 3.000000, 3.000000, 3.000000, 3.000000, 3.000000, 3.000000, 3.000000,
========= ERROR SUMMARY: 0 errors
