Hello, I benchmarked two quantizations of the same Qwen3.8-27B on a single Nvidia DGX Spark
Qwen/Qwen3.8-27B-FP8— fine-grained FP8 (block 128, e4m3), official Qwen FP8 build.unsloth/Qwen3.8-27B-NVFP4— Unsloth Dynamic NVFP4 (4-bit MLP + 8-bit attention + FP8 KV cache).
The results show a consistent 30–34 % faster generation throughput for the NVFP4 model from Unsloth,
plus a smaller model and lower KV-cache memory, especially for decode-heavy workloads.
Both runs use vLLM 0.27.1 with 16 concurrent prompts and identical flags,
Workloads
- Prompt-heavy: 8000 input / 1000 output tokens
- Decode-heavy: 1000 input / 8000 output tokens
- Balanced: 1000 input / 1000 output tokens
Command used for each run (model and lengths change per scenario):
vllm serve <model> --port 8000 --dtype auto
vllm bench serve \
--model <model> \
--dataset-name random \
--random-input-len <IN> \
--random-output-len <OUT> \
--request-rate 10000 \
--num-prompts 16 \
--ignore-eos
Results summary
Output token throughput (16 concurrent requests)
| Scenario | FP8 (tok/s) | NVFP4 (tok/s) | NVFP4 gain |
| Prompt-heavy (8k→1k) | 65.58 | 87.91 (peak 128) | +34 % |
| Decode-heavy (1k→8k) | 99.47 | 132.07 (peak 144) | +33 % |
| Balanced (1k→1k) | 104.44 | 134.41 (peak 144) | +29 % |
Latency & efficiency
| Metric | FP8 | NVFP4 |
| Prompt-heavy TTFT (mean) | 36 904 ms | 29 815 ms |
| Decode-heavy TPOT (mean) | 160.19 ms | 120.60 ms |
| Balanced TPOT (mean) | 147.90 ms | 114.73 ms |
| Decode-heavy KV-cache usage | ~15 % | ~5.6 % |
| Model size | 30.9 GB | 23.4 GB |
FP8 - Qwen/Qwen3.8-27B-FP8
Prompt-heavy
vllm bench serve --model Qwen/Qwen3.8-27B-FP8 \
--random-input-len 8000 --random-output-len 1000 \
--request-rate 10000 --num-prompts 16 --ignore-eos
============ Serving Benchmark Result ============
Successful requests: 16
Failed requests: 0
Request rate configured (RPS): 10000.00
Benchmark duration (s): 243.97
Total input tokens: 128000
Total generated tokens: 16000
Request throughput (req/s): 0.07
Output token throughput (tok/s): 65.58
Peak output token throughput (tok/s): 96.00
Peak concurrent requests: 16.00
Total token throughput (tok/s): 590.25
---------------Time to First Token----------------
Mean TTFT (ms): 36904.45
Median TTFT (ms): 36629.98
P99 TTFT (ms): 70322.99
-----Time per Output Token (excl. 1st token)------
Mean TPOT (ms): 203.19
Median TPOT (ms): 203.67
P99 TPOT (ms): 230.32
---------------Inter-token Latency----------------
Mean ITL (ms): 203.19
Median ITL (ms): 174.58
P99 ITL (ms): 1181.35
Decode-heavy
--random-input-len 1000 --random-output-len 8000 \
Failed requests: 0
Benchmark duration (s): 1286.83
Total input tokens: 16000
Total generated tokens: 128000
Request throughput (req/s): 0.01
Output token throughput (tok/s): 99.47
Peak output token throughput (tok/s): 112.00
Total token throughput (tok/s): 111.90
Mean TTFT (ms): 4929.30
Median TTFT (ms): 5038.53
P99 TTFT (ms): 7935.26
Mean TPOT (ms): 160.19
Median TPOT (ms): 160.18
P99 TPOT (ms): 160.59
Mean ITL (ms): 160.19
Median ITL (ms): 159.83
P99 ITL (ms): 176.42
Balanced
--random-input-len 1000 --random-output-len 1000 \
Failed requests: 0
Benchmark duration (s): 153.20
Request throughput (req/s): 0.10
Output token throughput (tok/s): 104.44
Total token throughput (tok/s): 208.88
Mean TTFT (ms): 4930.32
Median TTFT (ms): 5044.74
P99 TTFT (ms): 7925.80
Mean TPOT (ms): 147.90
Median TPOT (ms): 147.80
P99 TPOT (ms): 151.19
Mean ITL (ms): 147.90
Median ITL (ms): 145.57
P99 ITL (ms): 148.39
NVFP4 - unsloth/Qwen3.8-27B-NVFP4
Prompt-heavy
vllm bench serve --model unsloth/Qwen3.8-27B-NVFP4 \
Failed requests: 0
Benchmark duration (s): 182.01
Request throughput (req/s): 0.09
Output token throughput (tok/s): 87.91
Peak output token throughput (tok/s): 128.00
Total token throughput (tok/s): 791.16
Mean TTFT (ms): 29814.55
Median TTFT (ms): 30020.07
P99 TTFT (ms): 54669.85
Mean TPOT (ms): 149.37
Median TPOT (ms): 149.31
P99 TPOT (ms): 171.43
Mean ITL (ms): 149.37
Median ITL (ms): 128.22
P99 ITL (ms): 893.95
Decode-heavy
Failed requests: 0
Benchmark duration (s): 969.15
Request throughput (req/s): 0.02
Output token throughput (tok/s): 132.07
Peak output token throughput (tok/s): 144.00
Total token throughput (tok/s): 148.58
Mean TTFT (ms): 4047.64
Median TTFT (ms): 4138.09
P99 TTFT (ms): 6493.16
Mean TPOT (ms): 120.60
Median TPOT (ms): 120.59
P99 TPOT (ms): 120.94
Mean ITL (ms): 120.60
Median ITL (ms): 120.36
P99 ITL (ms): 129.30
Balanced
Failed requests: 0
Benchmark duration (s): 119.04
Request throughput (req/s): 0.13
Output token throughput (tok/s): 134.41
Total token throughput (tok/s): 268.82
Mean TTFT (ms): 4046.00
Median TTFT (ms): 4133.61
P99 TTFT (ms): 6502.03
Mean TPOT (ms): 114.73
Median TPOT (ms): 114.65
P99 TPOT (ms): 117.45
Mean ITL (ms): 114.73
Median ITL (ms): 112.64
P99 ITL (ms): 115.53
