Qwen3.8-27B-NVFP4 on a single DGX Spark — up to 1M context, vLLM+MTP measurements
Qwen3.8-27B was released today, and unsloth put up an NVFP4 quantization the same afternoon. It runs on a single DGX Spark without any modification to vLLM. This is what I found getting it up, including a packaging bug in the checkpoint that silently truncates every prompt at 2048 tokens.
EDIT: Unsloth meanwhile uploaded a fixed version, so you can ignore the section about the tokenizer bug fix.
Setup
Hardware DGX Spark, GB10, 121.63 GiB unified memory, driver 580.173.02
Container ghcr.io/spark-arena/dgx-vllm-eugr-nightly:latest (source tag nightly-20260801)
vLLM 0.26.1rc1.dev244+gd6a593feb.d20260801
FlashInfer d020372b068f335e2fe427372e134977a2235c49
Model unsloth/Qwen3.8-27B-NVFP4, 23.4 GB download
Note the container predates the model by two weeks. No newer build was needed:
The working command
vllm serve unsloth/Qwen3.8-27B-NVFP4 \
  --host 0.0.0.0 --port 8000 \
  --tensor-parallel-size 1 \
  --gpu-memory-utilization 0.45 \
  --max-model-len 262144 \
  --max-num-seqs 4 \
  --max-num-batched-tokens 8192 \
  --enable-chunked-prefill \
  --enable-prefix-caching \
  --reasoning-parser qwen3 \
  --tool-call-parser qwen3_xml \
  --enable-auto-tool-choice \
  --distributed-executor-backend mp \
  --speculative-config '{"method":"mtp","num_speculative_tokens":5}'
Two things that are easy to get wrong:
The MTP head needs no separate model. model_mtp.safetensors sits next to the weights, but its 15 tensors are registered in model.safetensors.index.json (1968 tensors total), so vLLM finds them in the checkpoint. --speculative-config takes no "model" field. At startup you should see:
Resolved architecture: Qwen3_5MTP
Detected MTP model. Sharing target model embedding weights with the draft model.
Detected MTP model. Sharing target model lm_head weights with the draft model.
Architecturally this is the same model as Qwen3.6-27B. I diffed both config.json files field by field — no difference in architecture, quantization groups, ignore list (303 entries), or vision tower. Dense, 64 layers, hidden 5120, 24 heads / 4 KV heads / head_dim 256, hybrid attention with 48 linear_attention + 16 full_attention layers, MLP in NVFP4 and attention in FP8, vision tower left in bf16. If you have a working Qwen3.6-27B config, swapping the model name is enough.
The tokenizer bug
This is the part I would most like other people to know about.
unsloth/Qwen3.8-27B-NVFP4 ships a tokenizer.json with truncation compiled in:
"truncation": {"direction": "Right", "max_length": 2048, "strategy": "LongestFirst", "stride": 0}
Qwen/Qwen3.8-27B — the original — has "truncation": null. So does Qwen/Qwen3.6-27B. The unsloth repack of 3.6 sets 16384, the repack of 3.8 sets 2048.
With images it fails loudly. A 1920×1200 image produces 2280 visual tokens, the text gets cut at 2048, and the placeholder count no longer matches the patch count:
ValueError: Mismatch in `image` token count between text and `input_ids`.
Got ids=[2047] and text=[2280].
Images below roughly 1.4 MP pass through fine, which makes this look intermittent if you happen to test with small crops.
With text it fails silently. No error, no warning — the prompt is simply cut at 2048 tokens. A server advertising max_model_len: 262144 effectively stops listening after 2048. If your model appears to ignore the beginning of long inputs, this is worth checking first.
Checking whether you’re affected
import json, glob
p = glob.glob("~/.cache/huggingface/hub/models--unsloth--Qwen3.8-27B-NVFP4/snapshots/*/")[0]
print(json.load(open(p + "tokenizer.json"))["truncation"])   # must be None
Fixing it without touching the cache
I took unsloth’s own tokenizer.json and set only truncation to null, leaving every other field byte-identical, then mounted the corrected file read-only over the cache path:
-v /path/to/fixed/tokenizer.json:/cache/huggingface/hub/models--unsloth--Qwen3.8-27B-NVFP4/snapshots/<hash>/tokenizer.json:ro
The HF cache stays untouched and checksum-clean, and a later hf download overwrites nothing.
Do not simply copy the file from Qwen/Qwen3.8-27B. I tried that first and compared before using it: the two repos also differ in decoder (add_prefix_space, trim_offsets), model, and pre_tokenizer, and unsloth’s tokenizer_config.json has been converted to the transformers-5 style (model_specific_special_tokens, backend: tokenizers, top-level image_token/video_token) while the original still uses added_tokens_decoder and an inline chat_template. Swapping wholesale changes tokenization behaviour. Change the one field.
After the fix
A 1920×1200 image goes through at 2380 prompt tokens and is read correctly down to 9-pixel text. A 7573-token text prompt arrives complete — verified by asking the model to name the last word before the question, which it does.
262k natively, 1M via YaRN
max_position_embeddings is 262144 and rope_parameters has rope_type: "default" with no scaling. unsloth’s card mentions 1M as “extensible”, which means YaRN, injected at launch:
--max-model-len 1048576
--hf-overrides '{"text_config":{"rope_parameters":{
    "rope_type":"yarn","factor":4.0,"original_max_position_embeddings":262144,
    "mrope_interleaved":true,"mrope_section":[11,11,10],
    "partial_rotary_factor":0.25,"rope_theta":10000000}}}'
Three things cost me time here:
  1. The override must go into text_config. There are no rope_parameters at the top level, and an override placed there is silently ignored — vLLM keeps deriving 262144 and rejects the larger --max-model-len.
  2. It replaces the dict rather than merging. mrope_section, mrope_interleaved, partial_rotary_factor and rope_theta must be written along or the model loses its multimodal RoPE.
  3. factor scales directly. vLLM computes original_max_position_embeddings × factor (config/model.py, around line 2318). 4.0 gives 1048576, 2.0 gives 524288.
You can verify the whole thing without a GPU by constructing a ModelConfig with hf_overrides and reading back max_model_len.
YaRN here is static — it applies to every request including short ones, and Qwen recommends enabling it only when the length is actually needed. I keep 262144 as the default and put 1M behind an environment switch.
Memory
At --gpu-memory-utilization 0.45, from vLLM’s own profiling output:
GiB
Weights + non-torch 26.16
Peak activation 1.80
CUDA graphs 0.15
Fixed 28.11
KV cache 27.56
That gives 777,645 KV tokens, 2.97× concurrency at full 262k context. Engine init took 220.5 s, 72.3 s of it compilation.
The hybrid attention is what makes this comfortable: only the 16 full_attention layers grow with context, and they carry just 4 KV heads at head_dim 256. The 48 linear_attention layers hold a constant state per sequence.
Measured KV cost is 37,169 bytes per token. Pure attention math gives 32,768 (16 × 4 × 256 × 2 bytes at fp8) — the difference is the linear-attention state, which vLLM places in the same pool. Worth knowing if you size from first principles: my calculation was 12 % optimistic.
For 1M context that means roughly 36.3 GiB of KV, so --gpu-memory-utilization needs at least 0.53. I’d use 0.60 for headroom (~1.25× concurrency at 1M). vLLM reports a ceiling of 82.01 GiB KV, i.e. about 2.31M tokens, if you want two concurrent full-context requests.
Performance
Prompt: Please generate a Python program that demonstrates the Bubblesort algorithm. temperature 0, streaming, median of 5 runs after warmup, num_speculative_tokens: 5.
thinking no thinking
Prompt 64 tokens 24 tokens
Output 378 tokens 246 tokens
Time to first token 0.417 s 0.401 s
Decode 24.0 tok/s 26.0 tok/s
Total 16.1 s 9.8 s
Run-to-run spread was 24.0–24.1 and 25.9–26.1 tok/s.
Time to first token on a 64-token prompt is almost entirely fixed overhead (~0.23 s measured at 116 tokens), so don’t derive a prefill rate from it. Measured separately, with a distinct non-shared prefix per request:
Prompt tokens Prefill
4,566 1,734 tok/s
11,988 1,153 tok/s
24,015 1,014 tok/s
47,857 853 tok/s
Speculative decoding
Aggregated over six content-varied prompts (code, prose, SQL, a list, a technical explanation, a short story):
num_speculative_tokens TTFT Decode
0 (off) 0.201 s 11.4 tok/s
3 0.265 s 23.6 tok/s*
5 0.300 s 24.7 tok/s
6 0.318 s 22.6 tok/s
8 0.351 s 21.7 tok/s
* one prompt hit the 4096-token limit and produced repetitive output, which drafts unrealistically well — treat that number as optimistic.
The MTP head roughly doubles decode throughput. Between 3 and 8 the differences are within about 14 % and barely above my measurement noise, so 5 is a mild preference rather than a finding. Note also that speculative decoding costs full CUDA graphs — vLLM logs FULL_AND_PIECEWISE is not supported with spec-decode ... setting cudagraph_mode=PIECEWISE. Only num_speculative_tokens: 0 gets the full graphs.
Three ways I fooled myself, in case they save you time
All three are the same shape: something caches or varies, and you measure it instead of the model.
Speculative decoding cannot be measured with a single prompt. Acceptance rate is a property of the generated text, and because the draft itself perturbs the numerics, the same prompt yields a different completion after each restart. My first sweep — one prompt, three repetitions — reported 36.0 tok/s at 8 draft tokens with beautifully consistent min/max. Re-running the identical configuration gave 28.1. The tight spread only showed that three repetitions of the same completion are stable. Average over several different prompts.
Prefix caching wrecks prefill measurements. Building prompts of increasing length from the same repeated filler means every longer prompt shares its head with all shorter ones. That produced an apparent 22,539 tok/s at 80k tokens — and, as a tell, a 10k prompt that prefilled faster than a 4k one. With a unique prefix per request the real number at 48k is 853 tok/s.
The multimodal cache does the same for images. Sending the same image twice skips the vision tower entirely: 1.01 s cold versus 0.16 s on repeat, a factor of six. Any image benchmark that reuses files measures the cache.
Still open
The bug is still live in the public repo. unsloth/Qwen3.6-27B-NVFP4 has the same defect with max_length: 16384 — less likely to bite, since few images produce that many tokens, but it will silently truncate long text just the same.
Happy to answer questions about the setup. Configuration details, exact flags, and the reasoning behind each are in comments in my launch script; I can share that too if it’s useful.
That’s a huge error by Unsloth. Have you reported it? They should fix that in minutes.
It worries me that their 3.6 version also had a less obvious version of the same error, capping at 16k. That may explain some of my findings with the Unsloth 3.6 27B leading me to abandon it.
Agree. I think if you post here @helge it looks like the Unsloth team will respond:
Thanks for pointing to the Unsloth discussion section. I reported it also there.
Are you happy with it overall? Or would you wait for the MoE model to come out so you can run a larger quantisation?
Qwen3.8-27B Unsloth NVFP4 vs PrismaAQUA 5.5-bit on RTX 5090 (vLLM 0.27.1)
A/B on a single RTX 5090 32GB. Same serving recipe for both:
  • vLLM 0.27.1
  • --max-model-len 191000
  • --max-num-seqs 2 (shared KV pool)
  • --gpu-memory-utilization 0.975
  • --kv-cache-dtype fp8
  • prefix caching on, no MTP
  • vision / multimodal on
  • --reasoning-parser qwen3
  • --tool-call-parser qwen3_coder
  • thinking on by default
Models:
Both booted cleanly with vision. Unsloth fit 196,968 KV tokens (1.03× at 191k). Aqua fit exactly 191,000 (1.00×) — slightly heavier BF16 lm_head / embeddings / vision tower.
Speed — llama-benchy pp=2048, tg=128, concurrency=1, 3 runs:
Unsloth PP / TG / TTFT Aqua PP / TG / TTFT
depth 0 8201 tok/s / 66.6 tok/s / 251 ms 8674 tok/s / 65.0 tok/s / 237 ms
depth 8k 9402 tok/s / 65.6 tok/s / 1090 ms 10070 tok/s / 64.1 tok/s / 1018 ms
Prefill: Aqua ~+6–7%. Decode: Unsloth ~+2%. For interactive use they are effectively the same.
Tool quality — full tool-eval-bench 69 scenarios (not --short):
Model Seeds Scores Mean
Unsloth 42, 42 repeat, 123 92 / 90 / 90 90.7
Aqua 42, 42 repeat, 123, 7, 2024 88 / 88 / 88 / 88 / 87 87.8
Aqua was extremely stable (±1). Unsloth stayed ≥90 on the confirmation runs. The ~3-point gap is real, not a one-run fluke.
Both pass thinking, tool_choice=required, and a tiny vision smoke test.
Verdict: keep Unsloth NVFP4 as the daily driver on 5090 if you care about tool calling. Aqua is a viable drop-in: same 191k window, same ~65 tok/s decode, slightly faster prefill, slightly tighter KV. I would not switch to Aqua for quality.
Danielhanchen replied to your post in hugging face and it is now fixed !
Thank you !
Yes, got noticed by them. The new tokenizer version is byte identical to the suggested fix. It is actually surprising that this wasn’t noticed with their Qwen3.6-27B-NVFP4 version already, but the 16K limit was apparently less conspicuous (requires very large images to run into that limit).
I noticed that the unsloth/Qwen3.8-27B-NVFP4 model is actually only 20b parameters, not 27. Has anyone noticed a difference in performance/accuracy vs a full 27b model?
Not quite — it really is a 27B model. When we count the parameters straight out of the safetensors headers of unsloth/Qwen3.8-27B-NVFP4, we get:
Component Parameters
Language model (64 layers) 24.35 B
Embeddings 1.27 B
lm_head 1.27 B
Vision tower 0.46 B
MTP head 0.42 B
Total 27.78 B
Plus 0.94 B of quantization scales, which aren’t parameters — that’s one FP8 value per 16-weight group, part of how NVFP4 stores things.
Where the 20B probably comes from: NVFP4 weights are stored as U8 tensors with two 4-bit values packed per byte. If you walk the tensor shapes and sum the elements without accounting for that packing, you silently drop half of every MLP weight — and the MLPs are the bulk of this model. That lands you right around 20B, which matches your number suspiciously well.
The other easy trap is inferring from file size. The checkpoint is 22.6 GB, but that’s a mixed-precision quantization: MLPs at 4 bit, attention at FP8, vision tower and norms at bf16. No single bits-per-weight assumption reproduces the parameter count from it.
On your actual question — since it isn’t a smaller model, the comparison you want isn’t “20B vs 27B” but “NVFP4 vs bf16”. For that, RedHatAI and NVIDIA publish recovery evals for their Qwen and Gemma NVFP4 checkpoints; unsloth doesn’t publish any for theirs, so quality there is an unmeasured assumption rather than a documented one.
OK, that helps. I was wondering why on Unsloth’s own pages for the models, they list the NVFP4 modes as 20b while they list others as 28b or 27b. I was assuming that being the same model, derived from the same upstream source that those numbers were intentional and were tied to the model size. What am I missing?
As meanwhile Unsloth fixed the tokenizer bug, I change the title of the thread and added an “EDIT” note to the initial post.
Another measurement may be worth mentioning:
I tested also with a 2 nodes (ray) cluster setup. Here I reached up to 37 tok/s (another user reported in another thread, he could reach ~45 tok/s with 2 nodes.
Then I tested concurrency with that 2 nodes cluster. With SPEC_TOKENS=5 and parallel sessions, the vLLM server crashed but with SPEC_TOKENS=3 I ran some tests successfully with 8 concurrent sessions and in total it generated ~117 tok/s. But it is too early to say, if this is a stable setup - it would need more longtime load tests to be valid.
Don’t have a better answer. Perhaps someone else can explain?
Could be a typo! The model’s card does show 27B parameters:
elsaco@spark1:~$ hf models card unsloth/Qwen3.8-27B-NVFP4 --text
---cut---
## Model Overview
- Type: Causal Language Model with Vision Encoder
- Training Stage: Pre-training & Post-training
- Language Model
    - Number of Parameters: 27B
---cut---
HF often reports incorrect model size because in some widgets it uses total file size for the calculation, not parameters size from headers. Probably incompatibility with some model compression formats.
I’ve tried probably 20 different recipes across vLLM and SGLang and this is the absolute best for a single spark as far as I can tell. Currently getting 39 t/s decode and 98 t/s aggregate. Optimized for long run agentic work in Hermes and OpenClaw across 4 concurrent lanes - 256k context. (Credit to eugr and drowzeys for their work on this)
Is the 39tks at C1?
I get about 15-25 tok/s in OpenCode using this recipe.
I’m getting 26tks (31 peak) on llama benchy pp2048 tg128 on somewhat this recipe
And me only 18.3 tok/s and almost 0tok/s at 32k of context …
  ✓     filler @ d0  18.3 eff t/s  18.1 stream t/s  α=55.1%  waste=45%  τ=1.7  win=3
  ✓       code @ d0  22.2 eff t/s  22.1 stream t/s  α=60.7%  waste=39%  τ=1.8  win=3
  ✓ structured @ d0  22.1 eff t/s  22.0 stream t/s  α=62.9%  waste=37%  τ=1.9  win=3
  ✓     filler @ d16384  6.3 eff t/s  6.3 stream t/s  α=48.4%  waste=52%  τ=1.5  win=3
  ✓       code @ d16384  22.2 eff t/s  22.1 stream t/s  α=60.7%  waste=39%  τ=1.8  win=3
  ✓ structured @ d16384  22.1 eff t/s  22.0 stream t/s  α=62.9%  waste=37%  τ=1.9  win=3
  ✓     filler @ d32768  3.7 eff t/s  3.7 stream t/s  α=43.6%  waste=56%  τ=1.3  win=3
  ✓       code @ d32768  22.2 eff t/s  22.0 stream t/s  α=60.7%  waste=39%  τ=1.8  win=3
  ✓ structured @ d32768  22.1 eff t/s  21.9 stream t/s  α=62.9%  waste=37%  τ=1.9  win=3
