those are crop numbers so 3864-1692-1692 = 480 and 2180-1800 = 380
take a 8m camera and display the cropped middle section of the frame, make it 480x380, if this is wrong, please give me the correct nvvidconv params, these worked before
Also my main display is a Mipi DSI display 480x800, is it possible that something is not set correctly and nvvidconv is confused by the display size.
what does nvvidconv use as the display size? How do I display the display size info.
When I run this command a box flashes very quickly on my actual display but nothing gets displayed, so nveglglessink understands the display, it appears that nvvidconv is the problem.
@Honey_Patouceul nvvidconv seems to be ignoring my top/bottom/left/right and is maintaining the aspect ratio, left/right might used, but the image is not filling the complete height of 380
I remember seeing a ignore-aspect or something similar but nvvidconv does not have any aspect parameter.
Please post the pipeline so that I can reproduce and figure out what could be the cause.
Do you crop with a ROI smaller than 480x380 ?
You may try adding pixel-aspect-ratio=1/1 into the output caps of nvvidconv.
So yes the app is changing the values on the fly, but zoom is working, you can see the values all changing. zoom reset works set the numbers back to the original.
Then topDown just tries to move the video in the window, topDown moves the top of the video down so the video should move up in the window, and it fails. Is it complaining that left/right are not changing?
Where does this message come from I would really like to add values to it so I can see what it thinks left is and what it things width really is.
SrcCrop rect’s left must not be greater than width
zoom(1098) b4 top 520 b 1660 l 1212 r 2652
zoom(1106) after top 576 b 1604 l 1312 r 2552
zoom(1098) b4 top 576 b 1604 l 1312 r 2552
zoom(1106) after top 632 b 1548 l 1412 r 2452
zoom(1098) b4 top 632 b 1548 l 1412 r 2452
zoom(1106) after top 688 b 1492 l 1512 r 2352
zoom(1098) b4 top 688 b 1492 l 1512 r 2352
zoom(1106) after top 744 b 1436 l 1612 r 2252
zoomReset(1126) b4 top 744 b 1436 l 1612 r 2252
zoomReset(1134) after top 520 b 1660 l 1212 r 2652
topDown(1177) b4 top 520 b 1660 l 1212 r 2652
topDown(1183) after top 620 b 1760 l 1212 r 2652
nvbuffer_transform Failed
gst_nvvconv_transform: NvBufferTransform Failed
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:camera: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:camera:
streaming stopped, reason error (-5)
ERROR: from element /GstPipeline:pipeline0/GstQueue:q1: Internal data stream error.
gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline0/GstQueue:q1:
We don’t support changing the settings on the fly in nvvidconv plugin. For this usecase, it is better to use jetson_multimedia_api to have more flexibility.
Although I’m curious, I don’t have so much time for trying your case. Again, you may help providing some code reproducing the error so that is easier to try.
I made a quick test with gstreamer in python and found similar errors with crop out of boundaries or NvDdkVicConfigure/nvbuffer_transform failures. Seems related to nvvidconv output resolution, but unsure if Argus can also be affected or not by this and I am unable to figure out the cause for now.
What seems to be an easier path would be trying new buf api and nvvideoconvert (not sure, it may require deep-stream plugins).
Try the following and share by modifying this example for easier help:
#!/usr/bin/env python
import signal
import sys
import time
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GObject
# Signal handler for stopping pipeline before destruction, so that Argus keeps ok.
def signal_handler(sig, frame):
p.set_state(Gst.State.NULL)
sys.exit(0)
# Initialize gstreamer
GObject.threads_init()
Gst.init(None)
# Define pipeline
gst_str = "nvarguscamerasrc sensor-id=0 bufapi-version=1 ! video/x-raw(memory:NVMM),format=NV12,width=1920,height=1080,framerate=30/1 ! nvvideoconvert name=cropper nvbuf-memory-type=4 ! capsfilter name=cflt caps=\"video/x-raw(memory:NVMM),width=480,height=380,pixel-aspect-ratio=1/1\" ! nvegltransform ! nveglglessink window-width=480 window-height=380"
# Create the pipeline
p = Gst.parse_launch (gst_str)
if not p:
print('Failed to launch pipeline. Aborting')
exit
# Register signal handler for proper termination if receiving SIGINT such as Ctrl-C
signal.signal(signal.SIGINT, signal_handler)
# get cropper component
cropper = p.get_by_name("cropper")
#print(cropper.get_property("src-crop"))
#print(cropper.get_property("dest-crop"))
# Get capsfilter output element
cf = p.get_by_name("cflt")
if not cf :
print('Failed to get cf')
exit(-1)
ocaps= cf.get_property('caps')
print ocaps.to_string()
# Start the pipeline
p.set_state(Gst.State.READY)
p.set_state(Gst.State.PAUSED)
p.set_state(Gst.State.PLAYING)
# Run for 5s
time.sleep(5)
print('Set top at 540')
#p.set_state(Gst.State.PAUSED)
new_caps = Gst.Caps.from_string("video/x-raw(memory:NVMM),format=NV12,width=1920,height=540,pixel-aspect-ratio=1/1")
cf.set_property("caps", new_caps)
cropper.set_property('src-crop', '0:540:1920:1080')
print cf.get_property('caps').to_string()
#p.set_state(Gst.State.PLAYING)
# Run for 5s
time.sleep(5)
print('Set left at 960')
new_caps = Gst.Caps.from_string("video/x-raw(memory:NVMM),format=NV12,width=960,height=540,pixel-aspect-ratio=1/1")
cropper.set_property('src-crop', '960:540:1920:1080')
# Run for 5s
time.sleep(5)
# Done. Stop the pipeline before clean up on exit.
exit(0)
@Honey_Patouceul@WayneWWW Thanks but that is for r32.5.1, and I am on r32.3.1, do you or a Nvidia person have the correct pointer to r32.3.1,
Also I am on a tx2-4g, and if deepstream needs cuda to be installed, I will fail for disk space problems, This is bring back some old nightmares, so lets see what if get for help.
I looked into Announcement in this forum and checked the R32.3.1 release where I see it should be DS-4.0.2.
You would find this version here(being logged).
You may follow these instructions (Jetson Setup/To install the DeepStream SDK/Method 2: Using the DeepStream tar package)
Note that the code I’ve posted above was only tested on NX with R32.5.1 and DS5.
