JetPack 4.3 - L4T R32.3.1 released
We are pleased to announce JetPack 4.3 supporting Jetson AGX Xavier series, Jetson TX2 series, Jetson TX1, and Jetson Nano.
JetPack 4.3 key features include new versions of TensorRT and cuDNN, Docker support for CSI cameras, Xavier DLA, and Video Encoder from within containers, and a new Debian package server put in place to host all NVIDIA JetPack-L4T components for installation and future JetPack OTA updates.
Please refer to the JetPack Release Notes and L4T Release Notes for additional info.
JetPack 4.3 Highlights:
  • Support for TensorRT 6.0.1 and cuDNN 7.6.3
  • Full support for DLA INT8 on Jetson AGX Xavier
  • Support for installation of JetPack components via Debian package archives
    • JetPack components are provided as Debian packages via a public APT server hosted by NVIDIA, enabling easier upgrades of JetPack components to future versions. Previous versions of JetPack need to be re-flashed to JetPack 4.3, after which the APT server can be used.
  • Support for CSI, DLA, and Video Encoder from within containers
    • On all Jetson products: Camera Serial Interface (CSI) and NVENC are now supported from within containers.
    • On Jetson AGX Xavier series only: NVIDIA Deep Learning Accelerator (DLA) engines are now supported from within containers.
  • Support for DeepStream 4.0.2
  • Support for ISAAC SDK version 2019.3
  • New easy to use Jetson-IO tool to configure 40-pin header on Jetson developer kits
  • Developer preview of VPI (Vision Programing Interface), a software library that provides Computer Vision and Image Processing algorithms implemented on Xavier Vision Accelerator, GPU and CPU.
    • GPU and CPU implementations are not optimized for performance in this preview release of VPI. A future release will bring performance optimized GPU and CPU implementations
JetPack 4.3 components:
  • L4T R32.3.1 (K4.9)
  • Ubuntu 18.04 LTS aarch64
  • CUDA 10.0
  • cuDNN 7.6.3
  • TensorRT 6.0.1
  • VisionWorks 1.6
  • OpenCV 4.1
  • Nsight Systems 2019.6
  • Nsight Graphics 2019.5
  • Nsight Compute 2019.3
  • SDK Manager 1.0.0
Download JetPack…https://developer.nvidia.com/embedded/jetpack
JetPack Release Notes…https://docs.nvidia.com/jetson/jetpack/release-notes/index.html
L4T Release Notes…https://developer.nvidia.com/jetson-linux-driver-package-release-notes-r3231-ga
Thank you for the JetPack 4.3 release!
I cannot find the previous version 4.2.3 in the JetPack archive https://developer.nvidia.com/embedded/jetpack-archive.
This means that you have retired JetPack 4.2.3?
Hi tfuru2, you can still select JetPack 4.2.3 from the SDK Manager to install, and the Nano SD card image for 4.2.3 is still available to download here. We will get the archives page updated with 4.2.3 as well.
Thanks for this release, it looks great !
Can we have a bit more detail about the Jetson IO-tool to easily configure the 40-pin header please?
How easy will it be to have GPIO as in RPis for example?
Hi pariente, recommend that you consult the Jetson-IO documentation found here:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fhw_setup_jetson_io.html
As previously, the Jetson.GPIO Python API is provided which is compatible with rPI.GPIO library.
Thank! I found the 4.2.3 at the link you mentioned.
Oh great, thanks for the docs page, I didn’t find it before, sorry.
It’s exactly what I needed !
Still no API for the Stereo & Opitcal Flow Engine (SOFE) on the Xavier?
Hi mosshammer.a, the new VPI API provides hardware-accelerated stereo and optical flow tracking.
Thanks for your response. I’ve already seen the VPI documentation, but what I’m particularly looking for is something comparable to the Optical Flow SDK, which is already supported by the DeepStream 4.0 SDK and apparently uses dedicated hardware chips such as NVENC on Turing GPUs and the SOFE on the Xavier (from the DeepStream FAQ: “Optical flow functionality is supported only on NVIDIA® Jetson AGX Xavier™ and on GPUs with Turing architecture (NVIDIA® T4, NVIDIA® GeForce® RTX 2080, etc.).”). The limitations of the PVA on stereo estimation resolution are just too limiting for a lot of use cases. There’s also CUDA support, but I need the GPU resources for DNN inference. And while there’s support for optical flow tracking in the VPI, there’s no support for calculation of sparse/dense optical flow yet. Could you share any information on the availability of an API that provides such functionality outside of DeepStream as the official Optical Flow SDK does not support Xavier?
I don’t have additional details to share yet at this point, but I have provided your feedback to the team, thanks for that.
Hi all, we have a new on-demand webinar about JetPack 4.3, covering what’s new and a deep-dive on key features.
It’s now available to stream here: https://nvda.ws/2T0DNDk
Has there been any progress about this topic?
I read https://docs.nvidia.com/vpi/index.html.
As a result, I found stereo matching API in VPI.
https://docs.nvidia.com/vpi/algo_stereo_disparity.html
But, I could not find optical flow API in VPI.
Do you have a plan to provide optical flow API in VPI?
Hi, I’ve tried to setup the Jetpack 4.3 to Xavier with SDK manager but failed on OpenCV download steps as following error log. Installing JetPack 4.2.3 was success fully finished. So, my environment would be good. Someone help?
/////// error log (removed href for forum limitation) ////////
* 11:17:09 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:09 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:09 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:09 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:09 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:25 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:25 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:25 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:25 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:25 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:41 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:41 ERROR : OpenCV on Target : Download 'OpenCV on Target' failure
* 11:17:41 ERROR : OpenCV on Target : undefined
* 11:17:41 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:41 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:41 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:17:41 ERROR : OpenCV on Target : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:08 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-libs.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:09 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:09 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-python.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:09 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-licenses.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:24 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-libs.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:25 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:25 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-python.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:25 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-licenses.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:40 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-libs.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:40 ERROR : OpenCV on Host : Download 'OpenCV on Host' failure
* 11:18:40 ERROR : OpenCV on Host : undefined
* 11:18:40 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-dev.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:41 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-python.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:41 ERROR : OpenCV on Host : Download 'OpenCV on Host' failure
* 11:18:41 ERROR : OpenCV on Host : undefined
* 11:18:41 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-licenses.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:18:48 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-samples.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:19:05 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-samples.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:19:21 ERROR : OpenCV on Host : download error: -ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.3/JETPACK_43_b132/ubuntu1804/OpenCV-4.1.1-2-gd5a58aa75-x86_64-samples.deb failed with Error: The .mtd file is corrupt. Start a new download.
* 11:19:21 ERROR : OpenCV on Host : Download 'OpenCV on Host' failure
* 11:19:21 ERROR : OpenCV on Host : undefined
DOWNLOAD FAILED
Please review the terminal tab for details. Resolve and RETRY.
Hi @mkoikawa, there is currently an issue with the server that we are working to fix, sorry about that - please keep an eye on this thread: OpenCV download failed when installing Jetpack 4.3 through SDK Manager - #2 by kayccc
The downloads should be working again now - please let us know if you still have any problems. Thanks.
