R35.6.0, uefi crashes after updating customer-customized logo
https://docs.nvidia.com/jetson/archives/r35.6.0/DeveloperGuide/SD/Bootloader/UEFI.html?highlight=logo#customized-logo
Following this instruction, we rebuilt the uefi_jetson.bin file and replaced it for burning, but uefi crashed after burning. The newly compiled uefi_jetsion.bin can be burned and run normally on R35.1.
The burning command and crash log are as follows:
flash command:
sudo ./flash.sh -r -k A_cpu-bootloader  jetson-agx-orin-devkit mmcblk0p1
crash log:
FW Boot Done
�ICE:  BL31: v2.6(release):5e1f8b33d
NOTICE:  BL31: Built : 01:45:47, Aug 28 2024
I/TC: Physical secure memory base 0x83c040000 size 0x3fc0000
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Wed Aug 28 08:55:22 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Unhandled Exception in EL3.
x30            = 0x000000005000138c
x0             = 0x0000000000000000
x1             = 0xfffffffffffff000
x2             = 0xfffffffffffdd000
x3             = 0x0000000000022000
x4             = 0x0000000000000588
x5             = 0x0000000832000590
x6             = 0x0000000000000000
x7             = 0x0000000000000000
x8             = 0x000000082ce00000
x9             = 0x0000000000100004
x10            = 0x000000082ce123c8
x11            = 0x0000000000011ef8
x12            = 0x000000082ce11b89
x13            = 0x0000000000000000
x14            = 0x0000000000000000
x15            = 0x0000000000000000
x16            = 0x0000000000000000
x17            = 0x0000000000000000
x18            = 0x0000000000000000
x19            = 0x0000000000000000
x20            = 0x0000000000000000
x21            = 0x0000000000000000
x22            = 0x0000000000000000
x23            = 0x0000000000000000
x24            = 0x0000000000000000
x25            = 0x0000000000000000
x26            = 0x0000000000000000
x27            = 0x0000000000000000
x28            = 0x0000000000000023
x29            = 0x0000000000000000
scr_el3        = 0x000000000003073d
sctlr_el3      = 0x00000000b0cd183f
cptr_el3       = 0x0000000000000000
tcr_el3        = 0x0000000080823518
daif           = 0x00000000000002c0
mair_el3       = 0x00000000004404ff
spsr_el3       = 0x00000000200003c9
elr_el3        = 0x0000000000000200
ttbr0_el3      = 0x0000000050026ac1
esr_el3        = 0x0000000082000010
far_el3        = 0x0000000000000200
spsr_el1       = 0x0000000000000000
elr_el1        = 0x0000000000000000
spsr_abt       = 0x0000000000000000
spsr_und       = 0x0000000000000000
spsr_irq       = 0x0000000000000000
spsr_fiq       = 0x0000000000000000
sctlr_el1      = 0x0000000030d00800
actlr_el1      = 0x0000000000000000
cpacr_el1      = 0x0000000000000000
csselr_el1     = 0x0000000000000000
sp_el1         = 0x0000000000000000
esr_el1        = 0x0000000000000000
ttbr0_el1      = 0x0000000000000000
ttbr1_el1      = 0x0000000000000000
mair_el1       = 0x0000000000000000
amair_el1      = 0x0000000000000000
tcr_el1        = 0x0000000000000000
tpidr_el1      = 0x0000000000000000
tpidr_el0      = 0x0000000000000000
tpidrro_el0    = 0x0000000000000000
par_el1        = 0x0000000000000800
mpidr_el1      = 0x0000000081000000
afsr0_el1      = 0x0000000000000000
afsr1_el1      = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1       = 0x0000000000000000
cntp_ctl_el0   = 0x0000000000000000
cntp_cval_el0  = 0x0000000000000000
cntv_ctl_el0   = 0x0000000000000000
cntv_cval_el0  = 0x0000000000000000
cntkctl_el1    = 0x0000000000000000
sp_el0         = 0x0000000000000000
isr_el1        = 0x0000000000000040
cpuectlr_el1   = 0xa000000b40543000
gicd_ispendr regs (Offsets 0x200 - 0x278)
 Offset:                        value
0000000000000200:               0x0000000000000000
0000000000000204:               0x0000000000000000
0000000000000208:               0x0000000000000000
000000000000020c:               0x0000000000000000
0000000000000210:               0x0000000000000000
0000000000000214:               0x0000000000000000
0000000000000218:               0x0000000000000000
000000000000021c:               0x0000000000020000
0000000000000220:               0x0000000000000000
0000000000000224:               0x0000000000000000
0000000000000228:               0x0000000000000000
000000000000022c:               0x0000000000000000
0000000000000230:               0x0000000000000000
0000000000000234:               0x0000000000000000
0000000000000238:               0x0000000000000000
000000000000023c:               0x0000000000000000
0000000000000240:               0x0000000000000000
0000000000000244:               0x0000000000000000
0000000000000248:               0x0000000000000000
000000000000024c:               0x0000000000000000
0000000000000250:               0x0000000000000000
0000000000000254:               0x0000000000000000
0000000000000258:               0x0000000000000000
000000000000025c:               0x0000000000000000
0000000000000260:               0x0000000000000000
0000000000000264:               0x0000000000000000
0000000000000268:               0x0000000000000000
000000000000026c:               0x0000000000000000
0000000000000270:               0x0000000000000000
0000000000000274:               0x0000000000000000
0000000000000278:               0x0000000000000000
000000000000027c:               0x0000000000000000
Maybe I didn’t describe my problem clearly,I want to replace the nvidia logo image in uefi. There is a problem with the newly built uefi_jetson.bin
Hi wangxiaozhuang,
Please share the steps how do you build the UEFI binary.
You may sync the wrong UEFI source for R35.6.0.
Hi KevinFFF,
Already solved.
  • custom board for AGX Oin.
https://github.com/NVIDIA/edk2-nvidia/wiki/Build-without-docker
  • Refer to this document to compile uefi and it will start normally
edkrepo clone nvidia-uefi NVIDIA-Platforms r35.6.0
  • The key here is to change it to the r35.6.0 branch. You cannot use the main branch directly.
