Graphics:
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: ASUSTeK driver: nvidia
v: 560.35.03 arch: Lovelace bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 24.1.2 driver: X:
loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: nvidia,nvidia-nvswitch resolution: 2560x1440
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib devices: 2
I had another screen freeze.
In the background I had just started journalctl -f in a terminal and when this familiar screen flicker happened I switched to the terminal window with journalctl and not long the screen was already frozen.
After restarting, I queried journalctl as follows:
journalctl --since “2025-01-30 13:40:00” --until “2025-01-30 14:10:00” > log_2025-01-30.txt
The screen freeze was around 13:57:00.
Before the screen freeze, of which I had taken a photo and subsequently marked the area in the journal extract below, there were no nvidia-related error messages.
Some journal entries (around 17 minutes before the screen freeze) that show errors or similar are as follows:
Jan 30 13:41:19 ANDROMEDA kernel: audit: type=1400 audit(1738240879.142:293): apparmor="DENIED" operation="open" class="file" info="Failed name lookup - disconnected path" error=-13 profile="plasmashell" name=".flatpak-info" pid=195163 comm="plasmashell" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
Jan 30 13:42:48 ANDROMEDA kwin_x11[3174]: <Unknown File>:97: TypeError: Cannot read property 'translucencyWindowTypeAnimation' of undefined
Jan 30 13:42:49 ANDROMEDA kwin_x11[3174]: <Unknown File>:97: TypeError: Cannot read property 'translucencyWindowTypeAnimation' of undefined
Jan 30 13:54:58 ANDROMEDA kernel: audit: type=1400 audit(1738241698.476:295): apparmor="DENIED" operation="open" class="file" info="Failed name lookup - disconnected path" error=-13 profile="plasmashell" name=".flatpak-info" pid=195163 comm="plasmashell" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
After the screen freeze before I switched off the pc via power switch I found the following in the journal:
Jan 30 13:56:55 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (3 suppressed)
Jan 30 13:56:55 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:1/3 s:79138994031445 a:79138994139786 f:79138994147416 waiting:108341 process:7630 status:triggered
Jan 30 13:56:55 ANDROMEDA pipewire[2859]: pw.node: (Strawberry-190) xrun state:0x7282e1e02008 pending:0/1 s:79139036679335 a:79138994037885 f:79138994059615 waiting:18446744073666910166 process:21730 status:triggered
>>> photo screen freeze
Jan 30 13:56:59 ANDROMEDA kernel: audit: type=1400 audit(1738241819.049:296): apparmor="DENIED" operation="open" class="file" info="Failed name lookup - disconnected path" error=-13 profile="plasmashell" name=".flatpak-info" pid=195163 comm="plasmashell" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
Jan 30 13:56:59 ANDROMEDA flatpak[198739]: 13:56:59.073 ERROR LyricFindLyricsProvider:204 LyricFind: "Empty reply received from server."
Jan 30 13:56:59 ANDROMEDA flatpak[198739]: 13:56:59.292 ERROR OVHLyricsProvider:114 OVHLyrics: "Error transferring https://api.lyrics.ovh/v1/Heilung/Othan LIVE - server replied: Not Found (203)"
Jan 30 13:56:59 ANDROMEDA flatpak[198739]: 13:56:59.292 ERROR OVHLyricsProvider:114 OVHLyrics: "No lyrics found"
Jan 30 13:56:59 ANDROMEDA kdeconnectd[3404]: 2025-01-30T13:56:59 kdeconnect.core: CompositeUploadJob::startListening() - Error opening a port in range 1739 - 1764
Jan 30 13:57:18 ANDROMEDA plasmashell[195163]: qt.qml.context: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/FullRepresentation.qml:99:25 Parameter "model" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Jan 30 13:57:26 ANDROMEDA plasmashell[195163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:284:9: QML Image: Cannot open: file:///tmp/strawberry-cover-ktx8rz.jpg
Jan 30 13:57:28 ANDROMEDA systemd[2847]: Started app-org.kde.konsole@4512deef22994f2aa6c251c934dacab7.service - Konsole - Terminal.
Jan 30 13:57:28 ANDROMEDA systemd[2847]: Started app-org.kde.konsole-221879.scope.
Jan 30 13:57:29 ANDROMEDA plasmashell[195163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/FullRepresentation.qml:53:13: QML PlasmoidHeading: Binding loop detected for property "leftInset":
qrc:/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:33:5
Jan 30 13:57:55 ANDROMEDA rtkit-daemon[2251]: Supervising 8 threads of 5 processes of 1 users.
<<< photo screen freeze
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU at PCI:0000:01:00: GPU-607aa084-1cf9-f43c-65b1-4be9d9db92f3
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 119, pid=3342, name=nvidia-smi, Timeout after 6s of waiting for RPC response from GPU0 GSP! Expected function 76 (GSP_RM_CONTROL) (0x20808513 0x598).
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU0 GSP RPC buffer contains function 4128 (GSP_POST_NOCAT_RECORD) and data 0x0000000000000005 0x000000c70170b43e.
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU0 RPC history (CPU -> GSP):
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: entry function data0 data1 ts_start ts_end duration actively_polling
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: 0 76 GSP_RM_CONTROL 0x0000000020808513 0x0000000000000598 0x00062cebfb2aed29 0x0000000000000000 y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -1 76 GSP_RM_CONTROL 0x0000000020800a4c 0x0000000000000004 0x00062cebfb0c59c9 0x00062cebfb0c5af2 297us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -2 76 GSP_RM_CONTROL 0x0000000020808513 0x0000000000000598 0x00062cebfb0c541a 0x00062cebfb0c599f 1413us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -3 76 GSP_RM_CONTROL 0x000000002080852f 0x0000000000000308 0x00062cebfb0ae2c1 0x00062cebfb0ae5a7 742us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -4 76 GSP_RM_CONTROL 0x0000000020808530 0x0000000000000390 0x00062cebfb0ae1cb 0x00062cebfb0ae2b7 236us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -5 76 GSP_RM_CONTROL 0x000000002080852f 0x0000000000000308 0x00062cebfb0adefa 0x00062cebfb0ae177 637us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -6 76 GSP_RM_CONTROL 0x0000000020808530 0x0000000000000390 0x00062cebfb0add2f 0x00062cebfb0adef4 453us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -7 76 GSP_RM_CONTROL 0x000000002080852f 0x0000000000000308 0x00062cebfb0ad89c 0x00062cebfb0adcb7 1051us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU0 RPC event history (CPU <- GSP):
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: entry function data0 data1 ts_start ts_end duration during_incomplete_rpc
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: 0 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x000000c70170b43e 0x00062cebfb52444d 0x00062cebfb52444e 1us y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -1 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x00000000016f9800 0x00062cebfb5242c7 0x00062cebfb5242c8 1us y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -2 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x000002ab0109691a 0x00062cebfb5242a2 0x00062cebfb5242a5 3us y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -3 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001257b84 0x00062cebf75d71d2 0x00062cebf75d71d4 2us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -4 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001277c78 0x00062cebf3b97bbb 0x00062cebf3b97bbc 1us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -5 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001257b84 0x00062cebf3b962f9 0x00062cebf3b962fb 2us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -6 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001277c78 0x00062cebf2a90c83 0x00062cebf2a90c84 1us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -7 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001257b84 0x00062cebf2a8d844 0x00062cebf2a8d846 2us
Jan 30 13:58:29 ANDROMEDA kernel: CPU: 1 UID: 1000 PID: 3355 Comm: nvidia-smi Tainted: P OE 6.11.0-108013-tuxedo #14tuxnoble1
Jan 30 13:58:29 ANDROMEDA kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Jan 30 13:58:29 ANDROMEDA kernel: Hardware name: ASUS System Product Name/ROG STRIX X670E-A GAMING WIFI, BIOS 2704 01/17/2025
Jan 30 13:58:29 ANDROMEDA kernel: Call Trace:
Jan 30 13:58:29 ANDROMEDA kernel: <TASK>
Jan 30 13:58:29 ANDROMEDA kernel: dump_stack_lvl+0x76/0xa0
Jan 30 13:58:29 ANDROMEDA kernel: dump_stack+0x10/0x20
Jan 30 13:58:29 ANDROMEDA kernel: os_dump_stack+0xe/0x20 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: _nv012948rm+0x4ee/0x590 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: WARNING: kernel stack frame pointer at 00000000b90e9197 in nvidia-smi:3355 has bad value 00000000988c5c06
Jan 30 13:58:29 ANDROMEDA kernel: unwind stack type:0 next_sp:0000000000000000 mask:0x2 graph_idx:0
Jan 30 13:58:29 ANDROMEDA kernel: 000000006620c9da: ffffb1e3c5437a78 (0xffffb1e3c5437a78)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a4d89584: ffffffffb3861519 (show_trace_log_lvl+0x269/0x420)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000014e7343a: ffffffffb53a94f0 (kallsyms_seqs_of_names+0x98f80/0x20a960)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000082fd9e72: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000594352c8: ffffffffb53d42dc (kallsyms_seqs_of_names+0xc3d6c/0x20a960)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fbcfc342: ffffb1e3c5437ad0 (0xffffb1e3c5437ad0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002e341212: 00000000c54379b8 (0xc54379b8)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000ceb3b5b: 0000000000000002 (0x2)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005833386f: 0000000000000001 (0x1)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007a0e2404: ffffb1e3c5434000 (0xffffb1e3c5434000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b0d6595d: ffffb1e3c5438000 (0xffffb1e3c5438000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000749faff7: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000004fd1935f: ffffb1e3c5434000 (0xffffb1e3c5434000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000009291302e: ffffb1e3c5438000 (0xffffb1e3c5438000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a4ca3f95: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000005a76570b: 0000000000000002 (0x2)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006c41e0c8: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ee333a65: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000026acba86: 0000000000000001 (0x1)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005ef62400: ffffb1e3c5437ac8 (0xffffb1e3c5437ac8)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000018cab3b2: ffffb1e3c5437978 (0xffffb1e3c5437978)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000a25070b: ffffffffc1a60fee (_nv012948rm+0x4ee/0x590 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e58cbce5: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000005d440137: 4888022691342e00 (0x4888022691342e00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b91d4ae0: 0000000000000246 (0x246)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000aac8ffa5: ffffffffb53d42dc (kallsyms_seqs_of_names+0xc3d6c/0x20a960)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000474dfe61: ffff8cf362b78008 (0xffff8cf362b78008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000583bf4f1: 000000000000004c (0x4c)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000070954ffc: 0000000000000006 (0x6)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008094bbc3: ffffb1e3c5437a88 (0xffffb1e3c5437a88)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c1c9bb8f: ffffffffb38617f0 (show_stack+0x20/0x70)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000014441908: ffffb1e3c5437aa8 (0xffffb1e3c5437aa8)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d2ab1fd4: ffffffffb49c3cf6 (dump_stack_lvl+0x76/0xa0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005a567510: ffff8cf362bc0008 (0xffff8cf362bc0008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b8564687: ffff8cf362b40008 (0xffff8cf362b40008)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000137edbf: ffffb1e3c5437ab8 (0xffffb1e3c5437ab8)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000039f40aad: ffffffffb49c3d40 (dump_stack+0x10/0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007b79c529: ffffb1e3c5437ac8 (0xffffb1e3c5437ac8)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ee50f20f: ffffffffc140eb2e (os_dump_stack+0xe/0x20 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b90e9197: ffff8cfec2c95d70 (0xffff8cfec2c95d70)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000072f56b76: ffffffffc1a60fee (_nv012948rm+0x4ee/0x590 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e0150637: ffff8cf362b78008 (0xffff8cf362b78008)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000089e6e5dd: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000009d95bfea: ffff8cf362b40008 (0xffff8cf362b40008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000dd6fce84: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a535c429: 000000000000004c (0x4c)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000090b2d1ff: ffffffffc1d83787 (_nv012865rm+0x77/0x330 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 0000000018f8488d: ffff8cf362be1050 (0xffff8cf362be1050)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000525363f: ffff8cfec2c95df0 (0xffff8cfec2c95df0)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000033ef5441: ffff8cf362b40008 (0xffff8cf362b40008)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008537fc1b: 0000000020808513 (0x20808513)
Jan 30 13:58:29 ANDROMEDA kernel: 000000003d7f47c8: ffff8cf362b78008 (0xffff8cf362b78008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000aa417aa0: ffffffffc1d9f8ff (_nv048628rm+0x49f/0x7f0 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000137cc031: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000e4bfe54: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000003a21e10c: ffffb1e3c5437bb8 (0xffffb1e3c5437bb8)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000057f3a58d: ffff8cf408104808 (0xffff8cf408104808)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000029ffca1d: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d9c7a916: ffffffffc14ff063 (_nv000720rm+0x173/0x320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000004f317ff0: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b253e6ee: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f5147316: ffffffffc14feef0 (_nv000691rm+0x1a0/0x1a0 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e1ba0dda: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000075c5bfc1: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000cc43a289: ffffffffc14b1ddd (_nv013137rm+0x3d/0xa0 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000003ab25a4c: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000eff2b648: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000001fed6283: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005a82fe68: ffffffffc1fc1382 (_nv000745rm+0x8d2/0xe00 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000005c695930: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000099d6719b: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 000000003cfb4489: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d06f0402: ffff8cfec2c93000 (0xffff8cfec2c93000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002b5eb443: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006ec988e9: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c51bedaa: ffffb1e3c5437d60 (0xffffb1e3c5437d60)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fc342073: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ae49bc03: ffffffffc1fc7edf (rm_ioctl+0x7f/0x400 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000009520b887: ffffffffb4a7387e (syscall_exit_to_user_mode+0x4e/0x250)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005eebe536: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000000de3cc5d: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000824e2a14: 0000000000000027 (0x27)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000099dc24a3: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000267195d7: ffffffffb4a6b97a (do_syscall_64+0x8a/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d8759f42: 0000000000000d1b (0xd1b)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000448fefe6: 0000000109338d14 (0x109338d14)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000386805a0: 000f8a086dbaf400 (0xf8a086dbaf400)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e14b5c03: 000f8a095c261c00 (0xf8a095c261c00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000645e289b: 000f8a095c261c00 (0xf8a095c261c00)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000fad08db: 000f8a09d3a7fb40 (0xf8a09d3a7fb40)
Jan 30 13:58:29 ANDROMEDA kernel: 000000004ffec656: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000008a57d5e0: 0000012000000002 (0x12000000002)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c2456ae2: 0000000000000d1b (0xd1b)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000031d3f076: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fca401db: fffffff000000000 (0xfffffff000000000)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000042e1e0cb: ffffffffc21f6490 (_nv046641rm+0x90/0xffffffffffeddc00 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000063207a9: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000011fe7e0d: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000994596e3: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c4595f53: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000004949c7db: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 000000004009de7b: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ebdf1675: ffffffffc13febcb (nvidia_unlocked_ioctl+0x7db/0x920 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000007efaac90: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000007bbe9f0c: ffff8cfec2c93000 (0xffff8cfec2c93000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002b10e2d2: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000026586442: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000008859ab1e: 4888022691342e00 (0x4888022691342e00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000997e4b67: 0000000000000003 (0x3)
Jan 30 13:58:29 ANDROMEDA kernel: 000000009551b0a9: ffff8cf3d7683700 (0xffff8cf3d7683700)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000624beeb1: 00000000c020462a (0xc020462a)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000082f01e55: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c6e4c253: ffff8cf3d7683701 (0xffff8cf3d7683701)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000234bff0c: ffffb1e3c5437d98 (0xffffb1e3c5437d98)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c9a9044b: ffffffffb3d305c0 (__x64_sys_ioctl+0xa0/0xf0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005bd0254f: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d6e48ffa: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000638f4f3e: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000004bebd84: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000002e3c922: ffffb1e3c5437da8 (0xffffb1e3c5437da8)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f08006ca: ffffffffb380adbd (x64_sys_call+0x11ad/0x25f0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ae828af2: ffffb1e3c5437f38 (0xffffb1e3c5437f38)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000bb9398e6: ffffffffb4a6b96e (do_syscall_64+0x7e/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 000000001bfd42a2: ffffffffb3a157c6 (hrtimer_nanosleep+0xb6/0x1a0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fd95bf37: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b3cdf821: ffffffffb3bd7522 (rseq_get_rseq_cs+0x22/0x260)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000004f8038a: ffff8d027daa6118 (0xffff8d027daa6118)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000385b4e54: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f96c0726: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a62343b5: 00007a37df6ecadf (0x7a37df6ecadf)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000088d868c1: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006959dc50: ffffffffb3bd77ff (rseq_ip_fixup+0x8f/0x1f0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000390efaa0: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c16169c8: ffffffffb4e2ad80 (clock_monotonic+0x80/0x80)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e35ce1df: 4888022691342e00 (0x4888022691342e00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000961ee85d: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008ca26f37: ffffffffb38713ed (restore_fpregs_from_fpstate+0x3d/0xd0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000389e6f44: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d794c460: ffff8cf3e6a6a500 (0xffff8cf3e6a6a500)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000cc41573c: 0000000000000005 (0x5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d10c9a42: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d841e9be: ffffffffb38714e0 (switch_fpu_return+0x50/0xe0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f2377d42: 0000000000004000 (0x4000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000174fb206: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000db945f5a: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007903c87e: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000036b947a4: ffffffffb4a739bd (syscall_exit_to_user_mode+0x18d/0x250)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000036e1c41c: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000017edc095: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000012e9eadb: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000daba9323: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d7a010f5: ffffffffb4a6b97a (do_syscall_64+0x8a/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000c79197f: 0000000000004000 (0x4000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006f5266b5: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f410eb14: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000dedd8cfd: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000032e03216: ffffffffb4a739bd (syscall_exit_to_user_mode+0x18d/0x250)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007a106138: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000378e1504: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000299e1b76: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d6eadf82: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008c1f2aa6: ffffffffb4a6b97a (do_syscall_64+0x8a/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005160b7e5: ffffffffb4a72ae7 (sysvec_apic_timer_interrupt+0x57/0xc0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000001272556d: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000614ab03a: ffffffffb4c0012b (entry_SYSCALL_64_after_hwframe+0x76/0x7e)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e4e646f5: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000004a638160: 00000000c020462a (0xc020462a)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d64c34e2: 0000000000000003 (0x3)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000033dc1997: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000056040a9e: 00007a37ddffeae0 (0x7a37ddffeae0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008e262093: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000015ee9c87: 0000000000000246 (0x246)
Jan 30 13:58:29 ANDROMEDA kernel: 000000009dc1ec3b: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a94842be: 00007a37ddffec4c (0x7a37ddffec4c)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e73d1580: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000011b74d8b: ffffffffffffffda (0xffffffffffffffda)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002bedb5b6: 00007a37df724ded (0x7a37df724ded)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008e1718ad: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000518d948f: 00000000c020462a (0xc020462a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000003e7e75dc: 0000000000000003 (0x3)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000047e05805: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007c0bc7eb: 00007a37df724ded (0x7a37df724ded)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ca74d8cd: 0000000000000033 (0x33)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007625735b: 0000000000000246 (0x246)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000063a57bc8: 00007a37ddffea90 (0x7a37ddffea90)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000091898b98: 000000000000002b (0x2b)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f1b85bd3: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv012865rm+0x77/0x330 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv048628rm+0x49f/0x7f0 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv000720rm+0x173/0x320 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv000691rm+0x1a0/0x1a0 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv013137rm+0x3d/0xa0 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv000745rm+0x8d2/0xe00 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? rm_ioctl+0x7f/0x400 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x4e/0x250
Jan 30 13:58:29 ANDROMEDA kernel: ? srso_alias_return_thunk+0x5/0xfbef5
Jan 30 13:58:29 ANDROMEDA kernel: ? do_syscall_64+0x8a/0x170
Jan 30 13:58:29 ANDROMEDA kernel: ? nvidia_unlocked_ioctl+0x7db/0x920 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? __x64_sys_ioctl+0xa0/0xf0
Jan 30 13:58:29 ANDROMEDA kernel: ? x64_sys_call+0x11ad/0x25f0
Jan 30 13:58:29 ANDROMEDA kernel: ? do_syscall_64+0x7e/0x170
Jan 30 13:58:29 ANDROMEDA kernel: ? hrtimer_nanosleep+0xb6/0x1a0
Jan 30 13:58:29 ANDROMEDA kernel: ? rseq_get_rseq_cs+0x22/0x260
Jan 30 13:58:29 ANDROMEDA kernel: ? rseq_ip_fixup+0x8f/0x1f0
Jan 30 13:58:29 ANDROMEDA kernel: ? restore_fpregs_from_fpstate+0x3d/0xd0
Jan 30 13:58:29 ANDROMEDA kernel: ? switch_fpu_return+0x50/0xe0
Jan 30 13:58:29 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x18d/0x250
Jan 30 13:58:29 ANDROMEDA kernel: ? sysvec_apic_timer_interrupt+0x57/0xc0
Jan 30 13:58:29 ANDROMEDA kernel: ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jan 30 13:58:29 ANDROMEDA kernel: </TASK>
Jan 30 13:58:35 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 119, pid=3342, name=nvidia-smi, Timeout after 6s of waiting for RPC response from GPU0 GSP! Expected function 76 (GSP_RM_CONTROL) (0x20808513 0x598).
Jan 30 13:58:41 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 119, pid=195163, name=QSGRenderThread, Timeout after 6s of waiting for RPC response from GPU0 GSP! Expected function 10 (FREE) (0xbeee0403 0x0).
Jan 30 13:58:47 ANDROMEDA kernel: NVRM: Rate limiting GSP RPC error prints for GPU at PCI:0000:01:00 (printing 1 of every 30). The GPU likely needs to be reset.
Jan 30 13:58:58 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 13:58:58 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79260909014530 a:79260909194850 f:79260909203880 waiting:180320 process:9030 status:triggered
Jan 30 13:59:28 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 13:59:28 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79290946014043 a:79290946047783 f:79290946055633 waiting:33740 process:7850 status:triggered
Jan 30 13:59:49 ANDROMEDA wpa_supplicant[1401]: wlp9s0: WPA: Group rekeying completed with 38:10:d5:69:87:df [GTK=CCMP]
Jan 30 13:59:57 ANDROMEDA kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [QSGRenderThread:195198]
Jan 30 13:59:57 ANDROMEDA kernel: Modules linked in: ntfs3 udp_diag tcp_diag inet_diag rfcomm cmac algif_hash algif_skcipher af_alg snd_seq_dummy snd_hrtimer ccm dummy ib_core vboxnetadp(OE) vboxnetflt(OE) vboxdrv(OE) qrtr bnep nvidia_uvm(POE) sunrpc binfmt_misc input_leds nvidia_drm(POE) nvidia_modeset(POE) amd_atl intel_rapl_msr intel_rapl_common nvidia(POE) snd_hda_codec_hdmi edac_mce_amd mt7921e btusb mt7921_common snd_hda_intel btrtl mt792x_lib kvm_amd btintel snd_intel_dspcfg mt76_connac_lib snd_intel_sdw_acpi btbcm btmtk tuxedo_compatibility_check(OE) spd5118 snd_hda_codec mt76 led_class_multicolor snd_usb_audio bluetooth kvm snd_hda_core snd_usbmidi_lib snd_hwdep snd_ump mac80211 snd_seq_midi snd_seq_midi_event snd_rawmidi nls_iso8859_1 rapl eeepc_wmi mfd_aaeon asus_nb_wmi mc snd_seq asus_wmi i2c_piix4 sparse_keymap snd_pcm platform_profile wmi_bmof snd_seq_device k10temp ccp i2c_smbus cfg80211 snd_timer snd drm_ttm_helper libarc4 ttm soundcore joydev razerkbd(OE) gpio_amdpt mac_hid sch_fq_codel msr parport_pc ppdev lp parport
Jan 30 13:59:57 ANDROMEDA kernel: dm_crypt nvme_fabrics efi_pstore nfnetlink dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 hid_generic usbhid uas hid usb_storage crct10dif_pclmul crc32_pclmul polyval_clmulni polyval_generic ghash_clmulni_intel sha256_ssse3 sha1_ssse3 nvme ahci libahci igc xhci_pci nvme_core xhci_pci_renesas nvme_auth video wmi aesni_intel crypto_simd cryptd
Jan 30 13:59:57 ANDROMEDA kernel: CPU: 4 UID: 1000 PID: 195198 Comm: QSGRenderThread Tainted: P OE 6.11.0-108013-tuxedo #14tuxnoble1
Jan 30 13:59:57 ANDROMEDA kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Jan 30 13:59:57 ANDROMEDA kernel: Hardware name: ASUS System Product Name/ROG STRIX X670E-A GAMING WIFI, BIOS 2704 01/17/2025
Jan 30 13:59:57 ANDROMEDA kernel: RIP: 0010:_nv043727rm+0x3b/0x80 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: Code: d3 89 de 48 8d 55 0f c6 45 0f 00 e8 3f 6d 4c ff 80 7d 0f 00 41 89 c4 75 11 41 39 5d 10 76 20 49 8b 45 00 c1 eb 02 44 8b 24 98 <5b> 44 89 e0 41 5c 41 5d 48 83 c5 10 c3 0f 1f 84 00 00 00 00 00 be
Jan 30 13:59:57 ANDROMEDA kernel: RSP: 0018:ffffb1e3c51e37e8 EFLAGS: 00000212
Jan 30 13:59:57 ANDROMEDA kernel: RAX: ffffb1e3c3000000 RBX: 00000000002e0c2c RCX: 0000000000b830b0
Jan 30 13:59:57 ANDROMEDA kernel: RDX: ffff8cf3e500295f RSI: 0000000000b830b0 RDI: ffff8cf362b40008
Jan 30 13:59:57 ANDROMEDA kernel: RBP: ffff8cf3e5002950 R08: 0000000000000020 R09: 0000000000000000
Jan 30 13:59:57 ANDROMEDA kernel: R10: 0000000000b830b0 R11: 0000000000000000 R12: 0000000080010005
Jan 30 13:59:57 ANDROMEDA kernel: R13: ffff8cf362b40ca0 R14: 0000000000000000 R15: 0000000000000000
Jan 30 13:59:57 ANDROMEDA kernel: FS: 00007999b4c006c0(0000) GS:ffff8d027da00000(0000) knlGS:0000000000000000
Jan 30 13:59:57 ANDROMEDA kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jan 30 13:59:57 ANDROMEDA kernel: CR2: 00000184a2120000 CR3: 00000001266a0000 CR4: 0000000000f50ef0
Jan 30 13:59:57 ANDROMEDA kernel: PKRU: 55555554
Jan 30 13:59:57 ANDROMEDA kernel: Call Trace:
Jan 30 13:59:57 ANDROMEDA kernel: <IRQ>
Jan 30 13:59:57 ANDROMEDA kernel: ? show_regs+0x6c/0x80
Jan 30 13:59:57 ANDROMEDA kernel: ? watchdog_timer_fn+0x218/0x2a0
Jan 30 13:59:57 ANDROMEDA kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
Jan 30 13:59:57 ANDROMEDA kernel: ? __hrtimer_run_queues+0x10f/0x2a0
Jan 30 13:59:57 ANDROMEDA kernel: ? rcu_core+0x1d6/0x370
Jan 30 13:59:57 ANDROMEDA kernel: ? hrtimer_interrupt+0xf8/0x250
Jan 30 13:59:57 ANDROMEDA kernel: ? __sysvec_apic_timer_interrupt+0x56/0x130
Jan 30 13:59:57 ANDROMEDA kernel: ? sysvec_apic_timer_interrupt+0x9b/0xc0
Jan 30 13:59:57 ANDROMEDA kernel: </IRQ>
Jan 30 13:59:57 ANDROMEDA kernel: <TASK>
Jan 30 13:59:57 ANDROMEDA kernel: ? asm_sysvec_apic_timer_interrupt+0x1b/0x20
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv043727rm+0x3b/0x80 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv043727rm+0x21/0x80 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv014687rm+0x10f/0x170 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv035969rm+0xcb/0x110 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036175rm+0x10d/0x360 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv030736rm+0xf0/0x1f0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv030736rm+0xc0/0x1f0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv012623rm+0x4f8/0x5c0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036399rm+0xb0/0x130 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036481rm+0x75/0xc0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036482rm+0xd7/0x140 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036473rm+0x12a/0x320 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036474rm+0x98/0xe0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv050276rm+0x114/0x460 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv035412rm+0x3a5/0x5f0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv004243rm+0xd/0x30 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv006122rm+0x1e/0xb0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv018080rm+0x59c/0x680 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv048181rm+0xb3/0xe0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv049956rm+0xb3/0x180 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv049955rm+0x50b/0x660 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv048073rm+0xdd/0x190 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv048074rm+0x41/0x70 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv000587rm+0x4d/0x60 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv000745rm+0x20f/0xe00 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? rm_ioctl+0x7f/0x400 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? srso_alias_return_thunk+0x5/0xfbef5
Jan 30 13:59:57 ANDROMEDA kernel: ? restore_fpregs_from_fpstate+0x3d/0xd0
Jan 30 13:59:57 ANDROMEDA kernel: ? nvidia_unlocked_ioctl+0x7db/0x920 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? __x64_sys_ioctl+0xa0/0xf0
Jan 30 13:59:57 ANDROMEDA kernel: ? x64_sys_call+0x11ad/0x25f0
Jan 30 13:59:57 ANDROMEDA kernel: ? do_syscall_64+0x7e/0x170
Jan 30 13:59:57 ANDROMEDA kernel: ? switch_fpu_return+0x50/0xe0
Jan 30 13:59:57 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x18d/0x250
Jan 30 13:59:57 ANDROMEDA kernel: ? do_syscall_64+0x8a/0x170
Jan 30 13:59:57 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x4e/0x250
Jan 30 13:59:57 ANDROMEDA kernel: ? sysvec_apic_timer_interrupt+0x57/0xc0
Jan 30 13:59:57 ANDROMEDA kernel: ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jan 30 13:59:57 ANDROMEDA kernel: </TASK>
Jan 30 14:00:01 ANDROMEDA CRON[222202]: pam_unix(cron:session): session opened for user root(uid=0) by root(uid=0)
Jan 30 14:00:01 ANDROMEDA CRON[222203]: (root) CMD (timeshift --check --scripted)
Jan 30 14:00:01 ANDROMEDA crontab[222231]: (root) LIST (root)
Jan 30 14:00:01 ANDROMEDA crontab[222232]: (root) LIST (root)
Jan 30 14:00:01 ANDROMEDA systemd[1]: run-timeshift-222203-backup.mount: Deactivated successfully.
Jan 30 14:00:01 ANDROMEDA CRON[222202]: pam_unix(cron:session): session closed for user root
Jan 30 14:00:19 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (2 suppressed)
Jan 30 14:00:19 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000003 Count 00803b49
Jan 30 14:00:19 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79338898778794 a:79338898815374 f:79338898825964 waiting:36580 process:10590 status:triggered
Jan 30 14:00:27 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (2 suppressed)
Jan 30 14:00:27 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79348931062168 a:79348931091848 f:79348931100798 waiting:29680 process:8950 status:triggered
Jan 30 14:00:29 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 14:00:29 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:1/3 s:79350945136329 a:79350945172549 f:79350945181529 waiting:36220 process:8980 status:triggered
Jan 30 14:00:59 ANDROMEDA kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Jan 30 14:01:01 ANDROMEDA kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Jan 30 14:01:03 ANDROMEDA kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Jan 30 14:01:03 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 14:01:03 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:1/3 s:79385356694691 a:79386825035293 f:79386825076193 waiting:1468340602 process:40900 status:triggered
Jan 30 14:01:03 ANDROMEDA kernel: clocksource: Long readout interval, skipping watchdog check: cs_nsec: 2697992225 wd_nsec: 2697991224
Jan 30 14:01:09 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-66 noise=9999 txrate=585000
Jan 30 14:01:12 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-66 noise=9999 txrate=585000
Jan 30 14:01:15 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=9999 txrate=585000
Jan 30 14:01:24 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=585000
>>> switched off the pc via power button <<<
-- Boot 94b2f3930af148bb92c56249d8d182e0 --
Jan 30 14:02:10 ANDROMEDA kernel: Linux version 6.11.0-108013-tuxedo (root@runner-47n-egjk-project-32919825-concurrent-0) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #14tuxnoble1 SMP PREEMPT_DYNAMIC Mon Dec 16 18:07:37 UTC 2024 (Ubuntu 6.11.0-108013.14tuxnoble1-tuxedo 6.11.0)
Jan 30 14:02:10 ANDROMEDA kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.11.0-108013-tuxedo root=UUID=dd2d00e8-5c62-4ca8-bedd-e15faea4695f ro quiet splash intel_iommu=igfx_off loglevel=3 udev.log_level=3 vt.handoff=7
Jan 30 14:02:10 ANDROMEDA kernel: KERNEL supported cpus:
Jan 30 14:02:10 ANDROMEDA kernel: Intel GenuineIntel
Jan 30 14:02:10 ANDROMEDA kernel: AMD AuthenticAMD
Jan 30 14:02:10 ANDROMEDA kernel: Hygon HygonGenuine
Jan 30 14:02:10 ANDROMEDA kernel: Centaur CentaurHauls
Jan 30 14:02:10 ANDROMEDA kernel: zhaoxin Shanghai
