system
June 22, 2017, 7:31am
1
I am getting fallowing dump with 100G mellanox card at initiator side. when I am running random write this failure observed. random read writing with out any issues.
could you provide inputs to resolve this issue.
[ 868.210565] mlx5_0:dump_cqe:263:(pid 0): dump error cqe
[ 868.210567] 00000000 00000000 00000000 00000000
[ 868.210568] 00000000 00000000 00000000 00000000
[ 868.210569] 00000000 08007806 250000ea b13e11d3
[ 868.210576] nvme nvme0: MEMREG for CQE 0xffff88040f9181b8 failed with status memory management operation error (6)
march
July 9, 2017, 8:19am
2
What is the test you use ? fio ?
Can you provide me the command line.
Marc
I am not using MLNX OFED stack. I am using inbox driver. that is our main requirement. But with MLNXOFED also we are getting random write failure. The crash I have to you is not MLNX OFED one. it is inbox driver.
[root@xhd-ipsspdk1 ~]# lspci -xxxvvv | grep -i mellanox
09:00.0 Ethernet controller: Mellanox Technologies MT27700 Family [ConnectX-4]
Subsystem: Mellanox Technologies Device 0014
09:00.1 Ethernet controller: Mellanox Technologies MT27700 Family [ConnectX-4]
[root@xhd-ipsspdk1 ~]# mst start
Starting MST (Mellanox Software Tools) driver set
Loading MST PCI module - Success
Loading MST PCI configuration module - Success
Create devices
Unloading MST PCI module (unused) - Success
[root@xhd-ipsspdk1 ~]# mst status -v
MST modules:
MST PCI module is not loaded
MST PCI configuration module loaded
PCI devices:
DEVICE_TYPE MST PCI RDMA NET NUMA
ConnectX4(rev:0) /dev/mst/mt4115_pciconf0.1 09:00.1 mlx5_1 net-enp9s0f1 0
ConnectX4(rev:0) /dev/mst/mt4115_pciconf0 09:00.0 mlx5_0 net-enp9s0f0 0
[root@xhd-ipsspdk1 ~]# ofed_info -s
MLNX_OFED_LINUX-3.4-2.0.0.0:
march
June 27, 2017, 10:35am
5
Can you please tell me which kernel version do you use ?
I need to check what is the status of this patch in the MOFED driver.
Can you send me your lscpi output of the Mellanox Adapter you use and his PSID, and the driver version.
mst start
mst status -v
flint -d /dev/mst/ q (query to get PSID)
ofed_info -s
Marc
march
June 25, 2017, 12:46pm
7
