Hi @Shekhar.L
Here’s a working example I’ve set up that randomizes textures in a material created using the material graph:
prim_path = "/World/Looks/MetalWithDefect/normalmap_texture"
textures = ['./RandomTextures/Dent_01.png', './RandomTextures/Dent_02.png', './RandomTextures/Dent_03.png']
with rep.new_layer():
def alter_attribute():
material = rep.get.prims(path_pattern = prim_path)
with material:
choice = rep.distribution.choice(textures)
rep.modify.attribute("inputs:texture", choice)
return material.node
rep.randomizer.register(alter_attribute)
with rep.trigger.on_frame(num_frames=10):
rep.randomizer.alter_attribute()
This simply assigns a different texture into the normalmap_texture prim. This works with a single material in the scene, randomizing the textures. There wont be any shader recompilation when the prim texture is reassigned. Though there might be a loading delay if the textures aren’t in memory (from what I understand).
Let me know if this helps!
