RDMA GPUDirect//nvidia-peer-memory/cuda issue
​Hi,
I’m having an issue getting RDMA GPU to GPU working correctly.
I’m setup at the ibverbs/cmverbs level.
My RDMA transaction starts by the client sending an IBV_WR_SEND request with the buffer information for the server to do a IBV_WR_RDMA_WRITE_WITH_IMM back of a much larger buffer.
The GPUs are just Quadros (K600) and the HCAs are VPI ConnectX-5s running Eth.
I can get a transfer to occur from the server host memory to the client gpu memory, but I cannot get either a gpu-gpu transfer to occur, or a server gpu memory to a client host memory to occur.
What I see as a response from the IBV_WR_RDMA_WRITE_WITH_IMM is a wc failure on the server of a local protection fault. So basically I get that error anytime I try to do a transfer from the server gpu to a client, but not for host memory to a client’s gpu memory. The layout is the same for the server host memory as it is for the server gpu memory (one just uses the cudaMalloc).
RHEL 7.6, nv_peer_memory_1.0-8, cuda 10.1, OFED 4.6-1.0.1.1
Is there some configuration item I’m missing when sourcing from a GPU memory vs the host memory? I’m just using cudaMalloc and the same ibv_reg_mr call for the GPU version and posix_memalign and ibv_reg_mr for the host memory version.
Will this configuration work GPU-GPU? And if not, why would host-GPU work?
Also host->gpu will work in either direction.
Any suggestions?
it can be a lot of things. What is the output of:
$sudo lspci -vvv | grep -i acs
Does it work without nv_peer_mem module loaded?
if it helps, perftest suite - GitHub - linux-rdma/perftest: Infiniband Verbs Performance Tests - has code with CUDA support. I would suggest to check the working code. In addition, linux-rdma mailing list could it be better choice to ask this kind of programming questions
​Although a useful suggestion (ref perftest_resources.c in that package, ~L62 function pp_init_gpu) that doesn’t seem to correct my problem. I’ve checked the WR pointers and they appear to be correct. Does GPUDirect just not support an IBV_WR_RDMA_WRITE_WITH_IMM transaction? The perftest only appears to test IBV_WR_RDMA_WRITE and IBV_WR_RDMA_READ.
I also question if I should be using cudaMalloc or the cuMemAlloc that the perftest is using? I thought we aren’t supposed to mix those libraries?
​With the latest perftest tool, I’m seeing something similar (failed status 4 which is the local protection fault) but with the ib_write_bw if I use the --use_cuda.
server:
./ib_write_bw -d mlx5_0 -i 1 -F --report_gbits -R --use_cuda
client:
./ib_write_bw -d mlx5_0 -i 1 -F --report_gbitgs 15.15.15.5 -R --use_cuda
It works without the “–use_cuda”.
The ib_read_bw fails in the same manner.
Any hints?
mlx5: D2701: got completion with error:
00000000 00000000 00000000 00000000
00000001 00000000 00000000 00000000
00000000 00008914 10000137 000097d2
Completion with error at client
Failed status 11: wr_id 0 syndrom 0x89
scnt=128, ccnt=0
Failed to complete run_iter_bw function successfully
initializing CUDA
There is 1 device supporting CUDA
[pid = 5441, dev = 0] device name = [Quadro K600]
creating CUDA Ctx
making it the current CUDA Ctx
cuMemAlloc() of a 131072 bytes GPU buffer
allocated GPU buffer address at 0000000b00a00000 pointer=0xb00a00000
RDMA_Read BW Test
Dual-port : OFF Device : mlx5_0
Number of qps : 1 Transport type : IB
Connection type : RC Using SRQ : OFF
TX depth : 128
CQ Moderation : 100
Mtu : 4096[B]
Link type : Ethernet
GID index : 2
Outstand reads : 16
rdma_cm QPs : ON
Data ex. method : rdma_cm
local address: LID 0000 QPN 0x0137 PSN 0x876fba
GID: 00:00:00:00:00:00:00:00:00:00:255:255:15:15:15:07
remote address: LID 0000 QPN 0x00b2 PSN 0xacda4
GID: 00:00:00:00:00:00:00:00:00:00:255:255:15:15:15:05
#bytes #iterations BW peak[Gb/sec] BW average[Gb/sec] MsgRate[Mpps]
No… without the nv_peer_mem the ibv_reg_mr of the cuda memory fails.
See attached for lspci output for the client and server and also a dump of the k600 quadro capabilities.
​The output from cudaDeviceCanAccessPeer is 0.
I’m going between two hosts and I can still write into gpu memory on one end… I just can’t source from gpu memory. Its the same if I swap the client/server ends.
I’m somewhat stuck.
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ARICap: MFVC- ACS-, Next Function: 0
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
and a dump of the gpu capabilities:
Name = Quadro K600
uuid = 0x441B3084
luid[0] = 0x0
luid[1] = 0x0
luid[2] = 0x0
luid[3] = 0x0
luid[4] = 0x0
luid[5] = 0x0
luid[6] = 0x0
luid[7] = 0x0
luidDeviceNodeMask = 0
totalGlobalMem = 1029963776
sharedMemPerBlock = 49152
regsPerBlock = 65536
warpSize] = 32
memPitch = 2147483647
maxThreadsPerBlock = 1024
maxThreadsDim[3] = 1024,1024,64
maxGridSize[3] = 2147483647,65535,65535
clockRate = 875500 KHz
totalConstMem = 65536
major compute capability = 3
minor compute capability = 0
textureAlignment = 512
texturePitchAlignment = 32
deviceOverlap = 1
multiProcessorCount = 1
kernelExecTimeoutEnabled = 0
integrated = 0
canMapHostMemory = 1
computeMode = 0
maxTexture1D = 65536
maxTexture1DMipmap = 16384
maxTexture1DLinear = 134217728
maxTexture2D[2] = 65536,65536
maxTexture2DMipmap[2] = 16384,16384
maxTexture2DLinear = 65000,65000,1048544
maxTexture2DGather[2] = 16384,16384
maxTexture3D[3] = 4096,4096,4096
maxTexture3DAlt[3] = 2048,2048,16384
maxTextureCubemap = 16384
maxTexture1DLayered[2] = 16384,2048
maxTexture2DLayered[3] = 16384,16384,2048
maxTextureCubemapLayered[2] = 16384,2046
maxSurface1D = 65536
maxSurface2D[2] = 65536,32768
maxSurface3D[3]) = 65536,32768,2048
maxSurface1DLayered[2] = 65536,2048
maxSurface2DLayered[3] = 65536,32768,2048
maxSurfaceCubemap = 32768
maxSurfaceCubemapLayered[2] = 32768,2046
surfaceAlignment = 512
concurrentKernels = 1
ECCEnabled = 0
pciBusID = 5
pciDeviceID = 0
pciDomainID = 0
tccDriver = 0
asyncEngineCount = 1
unifiedAddressing= 1
memoryClockRate = 891000
memoryBusWidth = 128
l2CacheSize = 262144
maxThreadsPerMultiProcessor = 2048
streamPrioritiesSupported = 0
globalL1CacheSupported = 0
localL1CacheSupported = 1
sharedMemPerMultiprocessor = 49152
regsPerMultiprocessor = 65536
managedMemory = 1
isMultiGpuBoard = 0
multiGpuBoardGroupID = 0
hostNativeAtomicSupported = 0
singleToDoublePrecisionPerfRatio = 24
pageableMemoryAccess = 0
concurrentManagedAccess = 0
computePreemptionSupported = 0
canUseHostPointerForRegisteredMem = 0
cooperativeLaunch = 0
cooperativeMultiDeviceLaunch= 0
sharedMemPerBlockOptin = 49152
pageableMemoryAccessUsesHostPageTables = 0
directManagedMemAccessFromHost = 0
Does it work using hugepages?
​This much at least turned out to be a bad build. Something was crossed up with my various installs. I reinstalled mofed and the installed tools worked. My local build of the perftest master was messed up. After the mofed install, I reconfigured and rebuilt the perftest. That then started to work also. Doesn’t appear to have solved my code’s problem, but at least I know the hardware is working and the installation is correct now. So that’s actually a very useful step.
See attached for some sample code for GPU to GPU transfer between hosts. It’s based off the geek in the corners sample 2 I think… It gives a protection error (4) if doing and RDMA_WRITE from cuda memory to cuda memory (not host/cuda pinned memory, that works).
Its a bit of a hack as I do a cudaMemcpy to fill/read the gpu memory with the message string being sent/recevied, but it exercises the RDMA.
I get the same error if I try to do a loopback (to same GPU), but I wasn’t expecting that to work anyway.
Could I please get someone to try and see if the attached works for them?
Or review it and clue me in on what I’m doing wrong?
I’ve also tried using the method of memory allocation in perftools (not in attached), but I get the same results. The perftools run ok (ib_write_bw) per the earlier post, though they were giving the same error until I reconfigured/recompiled perftools. Maybe I’m linking something badly?
Same error EN or IPoIB, using ConnextX-5 VPI cards.
You might need to edit the makefile to get rid of that last cp to bin.
​I have to backpedal on that last answer.
In order for cuda support to be configured into the perftools, it looks like you have to define CUDA_PATH (/usr/local/cuda-xx) and CUDA_H_PATH (/usr/local/cuda-xx/include/cuda.h).
If you don’t do that, the perftools will still accept the --use_cuda flag, but it won’t do anything with it.
I’ve verified internally that using fresh OS installation + fresh Mellanox OFED v4.6, CUDA v9.2 and perftest v4.4 recompiled with CUDA support works
​The end result of this whole mess is that the NVIDIA K600 is not supported with gpu memory rdma.
I’m not clear if the list is being maintained, but if your gpu is not on this list: https://developer.nvidia.com/gpudirectforvideo#GPUs then its probably not going to work.
