We are about to implement RDSH (not VDI) in our network, but I got conflicting info from the internet and local vendors, so I hope someone can answer a few questions.
Our RDSH clients requirements are simple, office and some in-house apps (mostly web-based), but the unclear part is being able to view HD media (through browser or a media player).
Is a GPU required for this type of use?
If not, Will a GPU offload this type of work from the CPU? or will that not work?
If I use a GPU, will a single RDSH VM be able to use multiple GPUs?
How can I calculate the required memory (and GPU required) per user?
How many users per server?
Which GPU do you recommend for this type of use?
What type of Licensing is needed?
Setup info:
All clients will be limited to a single monitor and a maximum res of 1920x1080.
All clients will be connected to their RDSH server via 1GB.
All servers will be running as a VM on a Hyper-V 2016 server.
