1- Does this command burn two keys (PKC and SBK) or 3 keys? What is KEK2 option for?
2- I have read that it may be possible to change the fused keys on the device by refusing them (changing some of the zeros to ones). Is this possible and do you have any examples on how to do this? If possible, I would like to see examples on how we convert our existing keys to binary and then change the bits.
Fuse burning operations are high-risk because they cannot be reversed.
let’s taking your fuse command-line as an example,
actually, it looks incorrect…
the authentication type should be SBKPKC, since you’re given PKC and SBK keys.
besides, KEK2, which is the key encryption key, please also note that KEK2 is a 128-bit key file.
Thank you Jerry, is it possible to re-fuse a device that has already been fused (by converting some of the zeros to 1s). Any instructions on how to do this?
I did not realize that you’ve -p option enabled, (the ODM production mode fuse, aka. “Security Mode”)
it’s the fuse to lock the values of the other manufacturing fuses.
you cannot change them (SKB, PKC and KEK keys) once the ODM production mode fuse has been programmed.
