Re-inditification
i am new to deepstream , i am using devel server with a container and i want to use re-inditification model . so i downloaded it unzipped and try to use onnx in a python script but :aceback (most recent call last):
File “reid.py”, line 9, in
onnx_session = onnxruntime.InferenceSession(model_path)
File “/usr/local/lib/python3.8/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py”, line 419, in init
self._create_inference_session(providers, provider_options, disabled_optimizers)
File “/usr/local/lib/python3.8/dist-packages/onnxruntime/capi/onnxruntime_inference_collection.py”, line 452, in _create_inference_session
sess = C.InferenceSession(session_options, self._model_path, True, self._read_config_from_model)
onnxruntime.capi.onnxruntime_pybind11_state.InvalidProtobuf: [ONNXRuntimeError] : 7 : INVALID_PROTOBUF : Load model from resnet50_market1501_aicity156.onnx failed:Protobuf parsing failed.
Seems the log you posted is irrelevant with Deepstream, can you share more context of the issue?
I’m having the same issue. and you’re right it’s not directly related to DeepStream.
I’m simply trying to run inference using the model provided here https://catalog.ngc.nvidia.com/orgs/nvidia/teams/tao/models/reidentificationnet (same model as in this post) using the command
The docs about the model mention a model load key
"The model is encrypted and can be decrypted with the following key:
  • Model load key: nvidia_tao
Please make sure to use this as the key for all TAO commands that require a model load key."
is this related somehow?
“Model load key” is for etlt/tlt model, which is encrypted and the key is needed when using such model. It’s not needed for ONNX model.
Can you share your code to reproduce the issue?
i tried to use etlt but i have an issue with the engine file i tried genrating it from onnx but it still makes an issue
i have a problem in general with model in deepstream .i download from ngc but its always an issue . onnx or etlt , is there a guide for thi specific part of models in deepstreamand thank you in advance
Normally you can use either onnx model or etlt model, you may check the usage of samples in folder /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps.
May be you can provide the full log and reproducing steps of the issue you met and let’s check what the problem is.
this what happens when i want to use any python binding app or even sample apps python3 deepstream_test_1.py reta.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file reta.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline . and its stuck like this
in the config file its :
model-file=…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel
proto-file=…/…/…/…/samples/models/Primary_Detector/resnet10.prototxt
model-engine-file=…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
labelfile-path=…/…/…/…/samples/models/Primary_Detector/labels.txt
int8-calib-file=…/…/…/…/samples/models/Primary_Detector/cal_trt.bin
but in the repo /resnet10.caffemodel_b1_gpu0_int8.engine this doesnt exist . i know you can build itb but i wanna the best practices here
The engine file is created from the model file if the program can run correctly.
deepstream_test1.py can only accept h264 file, you may refer to the description in README.
And I didn’t see the relation between “python3 deepstream_test1.py reta.mp4” and the code below, can you clarify?
Here is the code to reproduce thew issue
import onnxruntime
model_path = "resnet50_market1501_aicity156.onnx"
The model was downloaded via
wget --content-disposition https://api.ngc.nvidia.com/v2/models/nvidia/tao/reidentificationnet/versions/deployable_v1.1/zip -O reidentificationnet_deployable_v1.1.zip
the model’s md5sum is af1c079ac1e8e068a43492d4d1dc5854
And the full log
InvalidProtobuf                           Traceback (most recent call last)
Cell In[11], line 1
----> 1 session = ort.InferenceSession(model_path)
File ~/.local/lib/python3.10/site-packages/onnxruntime/capi/onnxruntime_inference_collection.py:419, in InferenceSession.__init__(self, path_or_bytes, sess_options, providers, provider_options, **kwargs)
    416 disabled_optimizers = kwargs["disabled_optimizers"] if "disabled_optimizers" in kwargs else None
    418 try:
--> 419     self._create_inference_session(providers, provider_options, disabled_optimizers)
    420 except (ValueError, RuntimeError) as e:
    421     if self._enable_fallback:
File ~/.local/lib/python3.10/site-packages/onnxruntime/capi/onnxruntime_inference_collection.py:452, in InferenceSession._create_inference_session(self, providers, provider_options, disabled_optimizers)
    450 session_options = self._sess_options if self._sess_options else C.get_default_session_options()
    451 if self._model_path:
--> 452     sess = C.InferenceSession(session_options, self._model_path, True, self._read_config_from_model)
    453 else:
    454     sess = C.InferenceSession(session_options, self._model_bytes, False, self._read_config_from_model)
Moving to TAO forum for better support.
After checking, unfortunately this onnx file is actually an .etlt file. The naming is not correct in ngc model card page.
I decrypt it and upload it here.
resnet50_market1501_aicity156_decode.onnx (91.9 MB)
@yingliu Thanks a lot! now I can load the model without any errors. One more question if you don’t mind: what steps did you take in order to decode the etlt file and convert it to onnx?
Please refer to Fpenet retraining output file onnx but deepstream is using tlt - #12 by Morganh.
i still have the same issue even with ‘sample_720p.h264’ it stops at creating pipeline .
about this , this is not directly about the python test1 but im trying to build a reidentification application using deepstream and i had issues building the model using onnx file
Please follow official github https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps/blob/master/apps/tao_others/README.md to get started for running re-id network with deepstream.
Thank you . about the python biding test apps that stops after the starting pipeeline is there something missing . i am using triton devel and and cloned the python apps repo in ‘deepstream-6.1/sources/apps/deepstream_python_apps/apps/deepstream-test2’
Please try to run with GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream . For this re-id model, as mentioned in TAO user guide, ReIdentificationNet - NVIDIA Docs, you can also run with GitHub - NVIDIA-AI-IOT/tao-toolkit-triton-apps: Sample app code for deploying TAO Toolkit trained models to Triton
