Hi
I recently updated my pgi complier to 13.7 and I got a very strange problem. There are no problem to compile the Fortran-based model. However, when I run the model, it will stop at mo_inirun.F90 where it reads the namelist file. It is not working even if I removed most or all the variables in the namelist file. The only message is:
Segmentation fault
There is no problem to compile and run the model with pgi10.x or pgi7.x. So I’d like to know how to deal with this errors.
In addition, I have another question. When I use the pretty old version pgi7.x, if there is an error reading namelist file it will print out the error message ‘inirun: Failed to open namelist file’ in the log file (see the code below). However, since I use version 10.xx or newer, iostat=iret doesn’t work. It always gives me the meaningless “Segmentation fault”. Is there any compiler flags option to turn this error information on. Otherwise it is very difficult to figure out where is the error. I am running a chemical transport model with hundreds of modules and I really need these code generated error information.
Thank you for your help in advance.
Liu
Below is the code and namelist file
file = 26
open( unit = file, file = trim(nml_file),iostat=iret )
if( iret /= 0 ) then
write(,) ‘inirun: Failed to open namelist file’
call endrun
end if
read(file,nlist,iostat=iret) !!! the code stops at here
write(,) 'inirun: Failed to read namelist file ‘,trim(nml_file),’; error = ',iret
call endrun
end if
close( file )
-------a.nml
&NLIST
aa = 1.0
