Install tesla v100 graphics card driver appears the following error:
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Sun May 26 07:36:17 2019
installer version: 418.67
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
-no-x-check
-no-nouveau-check
-no-opengl-files
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 64 CPUs online; setting concurrency level to 32.
WARNING: You do not appear to have an NVIDIA GPU supported by the 418.67 NVIDIA Linux graphics driver installed in this system. For further details, please see the app
endix SUPPORTED NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.
→ The file ‘/tmp/.X0-lock’ exists and appears to contain the process ID ‘2450’ of a runnning X server.
→ Continuing per the ‘–no-x-check’ option.
→ Installing NVIDIA driver version 418.67.
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (A
nswer: Yes)
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (418.67):
executing: ‘/usr/sbin/ldconfig’…
→ done.
→ Driver file installation is complete.
→ Installing DKMS kernel module:
→ done.
ERROR: Unable to load the ‘nvidia-drm’ kernel module.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the READM
