I can confirm this problem, the result of datatype=reduce_float is always failed if size is large.
Seems the float reduction in the SDK sample is bugous or the threshold of 1e-8*size is set too low.
Here is my test result on an untouched SDK reduction of SDK 2.3:
[font=“Courier New”]reduction.exe -n=4194304 -type=float
Reducing array of type float.
Using Device 0: “GeForce GTX 295”
4194304 elements
128 threads (max)
64 blocks
Average time: 0.188263 ms
Bandwidth: 89.115625 GB/s
GPU result = 16314.394531250000
CPU result = 16314.394531250000
TEST PASSED
reduction.exe -n=8388608 -type=float
8388608 elements
128 threads (max)
64 blocks
Average time: 0.353715 ms
Bandwidth: 94.862807 GB/s
GPU result = 32639.140625000000
CPU result = 32639.140625000000
TEST PASSED
reduction.exe -n=16777216 -type=float
16777216 elements
128 threads (max)
64 blocks
Average time: 0.686262 ms
Bandwidth: 97.788991 GB/s
GPU result = 65281.000000000000
CPU result = 65281.992187500000
TEST FAILED
reduction.exe -n=33554432 -type=float
33554432 elements
128 threads (max)
64 blocks
Average time: 1.359144 ms
Bandwidth: 98.751637 GB/s
GPU result = 130561.000000000000
CPU result = 130563.984375000000
TEST FAILED[/font]
