I am using Jetpack 35.1 and working on custom camera driver. I am using a closed source application which is trying to capture the RAW12 data. I used pxel format as BG12
I added the below lines to common_camera.c in the
static const struct camera_common_colorfmt camera_common_color_fmts[] = {
MEDIA_BUS_FMT_SBGGR12_1X12,* -
V4L2_COLORSPACE_SRGB,* -
V4L2_PIX_FMT_SBGGR12* -
and pixel_t = “bayer_bggr12”; to my device tree node for mode[n]
So are these the only two places where I shall add for RAW12 format?
I did the kernel tracing and get the below output:
# cat /sys/kernel/debug/tracing/traceuntu:/tmp/bin# sudo echo 0 > /sys/kernel/debug/tracing/events/v4l2/enable
# tracer: nop
# entries-in-buffer/entries-written: 529/529 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
sampleRetrieveD-2597 [001] .... 3332.579426: tegra_channel_open: vi-output, irs2381c 12-003d
sampleRetrieveD-2597 [001] .... 3332.717053: v4l2_qbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp =
0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
sampleRetrieveD-2597 [001] .... 3332.729689: v4l2_qbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp =
sampleRetrieveD-2597 [001] .... 3332.742463: v4l2_qbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp =
sampleRetrieveD-2597 [001] .... 3332.755456: v4l2_qbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = ANY, timestamp =
sampleRetrieveD-2597 [001] .... 3332.786829: tegra_channel_set_power: irs2381c 12-003d : 0x1
sampleRetrieveD-2597 [001] .... 3332.786869: camera_common_s_power: status : 0x1
sampleRetrieveD-2597 [001] .... 3332.814161: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
sampleRetrieveD-2597 [001] .... 3332.814201: csi_s_power: enable : 0x1
sampleRetrieveD-2597 [001] .... 3332.814366: tegra_channel_capture_setup: vnc_id 0 W 224 H 865 fmt c4
sampleRetrieveD-2597 [000] .... 3332.821194: tegra_channel_set_stream: enable : 0x1
sampleRetrieveD-2597 [000] .... 3332.822215: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
sampleRetrieveD-2597 [000] .... 3332.822219: csi_s_stream: enable : 0x1
sampleRetrieveD-2597 [000] .... 3332.822588: tegra_channel_set_stream: irs2381c 12-003d : 0x1
vi-output, irs2-2603 [003] .... 3332.861046: tegra_channel_capture_frame: sof:3355.739334848
vi-output, irs2-2603 [003] .... 3332.861050: tegra_channel_capture_frame: eof:3355.746241760
sampleRetrieveD-2604 [002] .... 3332.861079: v4l2_dqbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3355
739334000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
sampleRetrieveD-2604 [002] .... 3332.916205: v4l2_qbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
= 0, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 0
vi-output, irs2-2603 [003] .... 3332.927697: tegra_channel_capture_frame: sof:3355.805991648
vi-output, irs2-2603 [003] .... 3332.927699: tegra_channel_capture_frame: eof:3355.812898848
sampleRetrieveD-2604 [002] .... 3332.928996: v4l2_dqbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3355
805991000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 1
vi-output, irs2-2603 [003] .... 3332.994398: tegra_channel_capture_frame: sof:3355.872664768
vi-output, irs2-2603 [003] .... 3332.994401: tegra_channel_capture_frame: eof:3355.879571680
sampleRetrieveD-2604 [002] .... 3332.996526: v4l2_qbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
sampleRetrieveD-2604 [002] .... 3333.009554: v4l2_dqbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3355
872664000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 2
vi-output, irs2-2603 [003] .... 3333.061041: tegra_channel_capture_frame: sof:3355.939337216
vi-output, irs2-2603 [003] .... 3333.061043: tegra_channel_capture_frame: eof:3355.946244448
sampleRetrieveD-2604 [002] .... 3333.076614: v4l2_qbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
sampleRetrieveD-2604 [002] .... 3333.089645: v4l2_dqbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3355
939337000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 3
vi-output, irs2-2603 [003] .... 3333.127732: tegra_channel_capture_frame: sof:3356.6010176
vi-output, irs2-2603 [003] .... 3333.127734: tegra_channel_capture_frame: eof:3356.12917120
sampleRetrieveD-2604 [002] .... 3333.157171: v4l2_qbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
sampleRetrieveD-2604 [002] .... 3333.169969: v4l2_dqbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3356
006010000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 4
vi-output, irs2-2603 [003] .... 3333.194382: tegra_channel_capture_frame: sof:3356.72682688
vi-output, irs2-2603 [003] .... 3333.194384: tegra_channel_capture_frame: eof:3356.79589920
sampleRetrieveD-2604 [002] .... 3333.237519: v4l2_qbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
sampleRetrieveD-2604 [002] .... 3333.250556: v4l2_dqbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3356
072682000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 5
vi-output, irs2-2603 [003] .... 3333.261047: tegra_channel_capture_frame: sof:3356.139355712
vi-output, irs2-2603 [003] .... 3333.261049: tegra_channel_capture_frame: eof:3356.146262656
sampleRetrieveD-2604 [002] .... 3333.317589: v4l2_qbuf: minor = 0, index = 1, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
= 0
sampleRetrieveD-2604 [002] .... 3342.652081: v4l2_dqbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3365
340194000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 122
vi-output, irs2-2603 [001] .... 3342.661897: tegra_channel_capture_frame: sof:3365.540212096
vi-output, irs2-2603 [001] .... 3342.661899: tegra_channel_capture_frame: eof:3365.547119360
sampleRetrieveD-2604 [002] .... 3342.719608: v4l2_qbuf: minor = 0, index = 2, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
vi-output, irs2-2603 [001] .... 3342.728572: tegra_channel_capture_frame: sof:3365.606885216
vi-output, irs2-2603 [001] .... 3342.728574: tegra_channel_capture_frame: eof:3365.613792160
sampleRetrieveD-2604 [002] .... 3342.732644: v4l2_dqbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3365
406866000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 123
sampleRetrieveD-2604 [002] .... 3342.799709: v4l2_qbuf: minor = 0, index = 3, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
sampleRetrieveD-2604 [002] .... 3342.812966: v4l2_dqbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp = 3365
473539000, timecode = { type = 0x0, flags = , frames = 0, seconds = 0, minutes = 0, hours = 0, userbits = { 0 0 0 0 } }, sequence = 124
vi-output, irs2-2603 [001] .... 3342.861913: tegra_channel_capture_frame: sof:3365.740230688
vi-output, irs2-2603 [001] .... 3342.861915: tegra_channel_capture_frame: eof:3365.747137600
sampleRetrieveD-2597 [000] .... 3342.866783: tegra_channel_set_stream: enable : 0x0
sampleRetrieveD-2597 [000] .... 3342.866786: tegra_channel_set_stream: irs2381c 12-003d : 0x0
sampleRetrieveD-2597 [000] .... 3342.873919: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x0
sampleRetrieveD-2597 [000] .... 3342.873922: csi_s_stream: enable : 0x0
sampleRetrieveD-2597 [000] .... 3342.875871: tegra_channel_set_power: irs2381c 12-003d : 0x0
sampleRetrieveD-2597 [000] .... 3342.875893: camera_common_s_power: status : 0x0
sampleRetrieveD-2597 [000] .... 3342.891624: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x0
sampleRetrieveD-2597 [000] .... 3342.891628: csi_s_power: enable : 0x0
sampleRetrieveD-2604 [002] .... 3342.891690: v4l2_qbuf: minor = 0, index = 0, type = VIDEO_CAPTURE, bytesused = 387520, flags = MAPPED|QUEUED|TIMESTAMP_UNKNOWN|TIMESTAMP_MONOTONIC, field = NONE, timestamp
sampleRetrieveD-2597 [000] .... 3343.411100: tegra_channel_close: vi-output, irs2381c 12-003d
root@ubuntu:/tmp/bin#
I have the a few queries:
1)
I believe (seeing from the logs) the frame capture is happening (sof, eof are updated)?
But why it might be the case that only sequence number is getting increased? There is no update in the times (h,m,s) and frame numbers. At least the application runs for 7 seconds.
2)
What is the flag TIMESTAMP_UNKNOWN? Is it being passed by application?
3)
Is it possible that I can dump the v4l2 buffer (it is m’mapped by app I guess), in the kernel?
Many thanks.
