Hello, I am experiencing some inexplicable behaviour when capturing greyscale RAW12 frames from the TX2.
Input: “0x00AA”
Output:“0xAA2A”
This doesn’t seem to follow the memory mappings laid out in the nVidia documents, any ideas why?
camera_common.c:
static const struct camera_common_colorfmt camera_common_color_fmts[] = {
MEDIA_BUS_FMT_SRGGB12_1X12,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_SRGGB12,
MEDIA_BUS_FMT_SRGGB10_1X10,
V4L2_PIX_FMT_SRGGB10,
MEDIA_BUS_FMT_SRGGB8_1X8,
V4L2_PIX_FMT_SRGGB8,
MEDIA_BUS_FMT_Y12_1X12,
V4L2_COLORSPACE_RAW,
V4L2_PIX_FMT_Y12,
int camera_common_try_fmt(struct v4l2_subdev *sd, struct v4l2_mbus_framefmt *mf)
if (mf->code != MEDIA_BUS_FMT_SRGGB8_1X8 &&
mf->code != MEDIA_BUS_FMT_SRGGB10_1X10 &&
mf->code != MEDIA_BUS_FMT_SRGGB12_1X12 &&
mf->code != MEDIA_BUS_FMT_Y12_1X12)
mf->code = MEDIA_BUS_FMT_SRGGB10_1X10;
err = -EINVAL;
mf->field = V4L2_FIELD_NONE;
if (mf->code == MEDIA_BUS_FMT_Y12_1X12){
mf->colorspace = V4L2_COLORSPACE_RAW;
else{
mf->colorspace = V4L2_COLORSPACE_SRGB;
return err;
sensor_common.c:
static int extract_pixel_format(
const char *pixel_t, u32 *format)
size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
*format = V4L2_PIX_FMT_SBGGR10;
else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
*format = V4L2_PIX_FMT_SRGGB10;
else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
*format = V4L2_PIX_FMT_SBGGR12;
else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
*format = V4L2_PIX_FMT_SRGGB12;
else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
*format = V4L2_PIX_FMT_XBGGR10P;
else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
*format = V4L2_PIX_FMT_XRGGB10P;
else if (strncmp(pixel_t, "raw12", size) == 0){
*format = V4L2_PIX_FMT_Y12;
printk ("Requesting RAW12 extract_pixel_format\n");
else {
pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
return -EINVAL;
return 0;
in the device tree .dtsi:
mode0 {
mclk_khz = "25000";
num_lanes = "4";
tegra_sinterface = "serial_c";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1920";
active_h = "1080";
pixel_t = "raw12";
readout_orientation = "90";
line_length = "2688";
inherent_gain = "1";
mclk_multiplier = "6.67";
pix_clk_hz = "160000000";
min_gain_val = "1.0";
max_gain_val = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1.816577";
max_framerate = "300";
min_exp_time = "34";
max_exp_time = "550385";
embedded_metadata_height = "0";
Validation command:
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat='Y12 ' --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=csi_dump.raw --verbose
