Regarding Vector Reduction To find sum of all components of a vector
As clear from subject, I have a vector and want to implement reduction to find its components sum. I followed CUDA SDK examples but being a novice I want to simplify the example. The example seems to be optimized. To do so, I randomly referred to a tutorial on reduction and took the code as under:
float *a_h, *a_d, *b_h, *b_d;
float *result;
//compute dot product between a_h and b_h inside CUDA.
//initialize a_h and b_h
a_h = (float *)malloc(4 * sizeof(float) );			//a_h and b_h are 1*4 vectors. 4 elements only -- for testing
b_h = (float *)malloc(4 * sizeof(float) );
cudaMalloc((void **) &a_d, 4 * sizeof(float));
cudaMalloc((void **) &b_d, 4 * sizeof(float));
Lets say a_h = <0,1,2,3> = b_h
//copy stuff
cudaMemcpy(a_d, a_h, sizeof(float)*4, cudaMemcpyHostToDevice);
cudaMemcpy(b_d, b_h, sizeof(float)*4, cudaMemcpyHostToDevice);
//Do component wise multiplication
dotProduct<<<nBlocks , nBlockSize >>>(a_d, b_d, 4);  //nBlocks = 1 and nBlockSize = 4 (...threads)
Now after dotProduct(…)
I get expected result as <0,1,4,9>
For this vector I wish to perform reduction to get final sum as 14.
This is my reduction function.
__global__ void reductionOnDevice(float *pVector, unsigned int N, unsigned int BlockStride)
	  unsigned int i = blockIdx.x * blockDim.x  + threadIdx.x;
	  unsigned int Stride = 2 * BlockStride;
	  unsigned int j = blockDim.x;
	  while(j>0)
		  if(Stride * i < N)
			  pVector[Stride*i] += pVector[Stride*i + (Stride * 2)];
		  Stride *= 2;
		  j /= 2;
		  __syncthreads();
	  }//end while
}//end of reductionOnDevice()
Following is called inside main() just after I get result from dotProduct().
//call reduction function in CUDA to compute final sum
  while(nBlocks > 0)
	reductionOnDevice<<<nBlocks, blockSize/2 >>>(c_d, N , Stride);
	Stride *= blockSize;
	N /= 2;
	nBlocks /= blockSize;
After this I do:
cudaMemcpy(c_h, c_d, sizeof(float)*4, cudaMemcpyDeviceToHost);
// check results
  printf("\n");
  for (i=0; i<4; i++)
	  printf("c_h[%d]=%f\n", i , c_h[i]);
Now the result I am getting is <0 , 1,4,9> . => No change.
Do you know where the problem lies?Thank you.
You should probably re-post this in the Programming and Development forum…this one doesn’t get many people viewing it except when their compiler is broken :)
