[REGRESSION] Kernel panic during suspend on Pascal MX150 with NVIDIA 580.142 and Linux 7.0.0-15
Environment:
  • Distribution: Ubuntu 26.04 LTS
  • Kernel: 7.0.0-15-generic
  • GPU: NVIDIA GeForce MX150 (Pascal)
  • NVIDIA Driver: 580.142
  • Session: X11
  • Laptop: Xiaomi TM1703 (Kaby Lake platform)
Problem Description:
System consistently crashes during suspend.
The crash occurs immediately after entering suspend state and results in a black screen with kernel trace output.
Relevant kernel trace:
kernel BUG at arch/x86/kernel/jump_label.c:73
nvkms_kthread_q_callback [nvidia_modeset]
Observed Behavior:
  • suspend triggers kernel panic
  • system becomes unusable
  • requires hard reboot
  • issue is fully reproducible
Reproduction:
  1. Boot Linux 7.0.0-15
  2. Load NVIDIA 580.142 driver
  3. Execute:
    systemctl suspend
  4. Kernel panic occurs
Additional Testing:
The issue reproduces under:
  • PRIME nvidia mode
  • PRIME on-demand mode
  • s2idle suspend
  • deep suspend
  • nvidia-drm modeset=0
Workarounds Tested:
Successful workaround:
  • booting Linux 6.17.0-29-generic
  • same NVIDIA driver stack
  • suspend no longer causes kernel panic
Additional note:
On this hardware, deep suspend (mem_sleep_default=deep) is required for proper sleep behavior. With s2idle, the system does not enter real suspend correctly.
Regression Information:
Suspend worked correctly on previous Ubuntu LTS installation before upgrading to Ubuntu 26.04 / kernel 7.0 stack.
Suspected Cause:
Possible regression in suspend/resume interaction between:
  • Linux kernel 7.0
  • NVIDIA 580.x proprietary driver
  • Pascal mobile GPUs
Relevant modules involved:
  • nvidia
  • nvidia_modeset
  • nvidia_drm
I get a similar kernel panic (from nvkms_kthread_q_callback [nvidia_modeset]) on OpenSuse Tumbleweed with kernel 6.19.12-1 and nvidia drivers 580.159.03. My GPU is GTX 1650 Mobile (Turing).
