Suspend fails on 570.124.04 drivers
Lenovo Legion 5 15IAH7H (Intel 12700H, 16 GiB DDR5, RTX 3060) fails to suspend sometimes with the new 570.124.04 drivers. Suspend worked fine with some 550-series driver in the past. Failure rate is very high now (more than 30%).
  • OS: Fedora 41 GNOME Wayland
  • Kernel: 6.13.5-200.fc41.x86_64
  • Driver: 570.124.04 (proprietary kernel modules)
I use the proprietary kernel modules. With the open kernel modules, there are a lot of display artifacts after resuming from suspend when NVIDIA GPU is selected by the mux.
I have to hard reset the machine when suspend fails (happens even when GPU is in D3cold and not being used; i.e., Intel iGPU selected by the mux). The magic Alt+SysRq+{R,E,I,S,U,B} sequence does not work: There is just a black screen with some logs.
I installed the drivers using the .run file. The distro repositories always contain the latest beta version, which has always been unstable on my machine. The NVIDIA CUDA repos for Fedora also contain a beta version many times (and not the stable version), and that has been unstable several times in the past.
aditya@fedora:~$ lspci | rg NVIDIA
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GA106 High Definition Audio Controller (rev a1)
aditya@fedora:~$ systemctl status nvidia-powerd.service
● nvidia-powerd.service - nvidia-powerd service
     Loaded: loaded (/usr/lib/systemd/system/nvidia-powerd.service; enabled; preset: disabled)
    Drop-In: /usr/lib/systemd/system/service.d
             └─10-timeout-abort.conf, 50-keep-warm.conf
     Active: active (running) since Mon 2025-03-10 13:19:32 IST; 45min ago
 Invocation: 9fdd84f51b43487a899aca1da2633c4e
   Main PID: 1277 (nvidia-powerd)
      Tasks: 2 (limit: 18445)
     Memory: 896K (peak: 1.6M)
        CPU: 406ms
     CGroup: /system.slice/nvidia-powerd.service
             └─1277 /usr/bin/nvidia-powerd
aditya@fedora:~$ systemctl status nvidia-suspend.service
○ nvidia-suspend.service - NVIDIA system suspend actions
     Loaded: loaded (/usr/lib/systemd/system/nvidia-suspend.service; enabled; preset: disabled)
     Active: inactive (dead)
aditya@fedora:~$ systemctl status nvidia-resume.service
○ nvidia-resume.service - NVIDIA system resume actions
     Loaded: loaded (/usr/lib/systemd/system/nvidia-resume.service; enabled; preset: disabled)
aditya@fedora:~$ systemctl status nvidia-suspend-then-hibernate.service
○ nvidia-suspend-then-hibernate.service - NVIDIA actions for suspend-then-hibernate
     Loaded: loaded (/usr/lib/systemd/system/nvidia-suspend-then-hibernate.service; enabled; preset: disabled)
aditya@fedora:~$ systemctl status nvidia-hibernate.service
○ nvidia-hibernate.service - NVIDIA system hibernate actions
     Loaded: loaded (/usr/lib/systemd/system/nvidia-hibernate.service; enabled; preset: disabled)
Mar 10 13:19:32 fedora systemd[1]: Started nvidia-powerd.service - nvidia-powerd service.
Mar 10 13:19:32 fedora /usr/bin/nvidia-powerd[1277]: nvidia-powerd version:1.0(build 1)
Mar 10 13:19:32 fedora /usr/bin/nvidia-powerd[1277]: Error requesting D-Bus name (Request to own name refused by policy)
Mar 10 13:19:32 fedora /usr/bin/nvidia-powerd[1277]: Failed to acquire D-Bus name ((null))
Mar 10 13:19:32 fedora /usr/bin/nvidia-powerd[1277]: Error setting up DBus connection
aditya@fedora:~$ cat /etc/modprobe.d/nvidia.conf
options nvidia_drm modeset=1
options nvidia NVreg_UsePageAttributeTable=1
options nvidia NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=/tmp/nvidia
aditya@fedora:~$ cat '/sys/bus/pci/devices/0000:01:00.0/power_state'
D3cold
aditya@fedora:~$ nvidia-smi
Mon Mar 10 14:05:31 2025
| NVIDIA-SMI 570.124.04             Driver Version: 570.124.04     CUDA Version: 12.8     |
|   0  NVIDIA GeForce RTX 3060 ...    Off |   00000000:01:00.0 Off |                  N/A |
| N/A   58C    P0            752W /  140W |      13MiB /   6144MiB |     16%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A            3027      G   /usr/bin/gnome-shell                      2MiB |
(When the GPU is in D3cold, nvidia-smi takes a while to return, and reports weird Pwr:Usage values.)
aditya@fedora:~$ cat /proc/cmdline
rd.luks.uuid=luks-eeeeeeee-eeee-eeee-eeee-eeeeeeeeeeee rhgb quiet root=UUID=eeeeeeee-eeee-eeee-eeee-eeeeeeeeeeee rootflags=subvol=root
Here are some relevant logs (some errors, like “Failed to query display engine channel state” were spammed hundreds/thousands of times in the logs and hence I removed duplicates):
Mar 10 12:29:21 fedora systemd[1]: Reached target sleep.target - Sleep.
Mar 10 12:29:21 fedora systemd[1]: Starting nvidia-suspend.service - NVIDIA system suspend actions...
Mar 10 12:29:21 fedora suspend[111644]: nvidia-suspend.service
Mar 10 12:29:21 fedora logger[111644]: <13>Mar 10 12:29:21 suspend: nvidia-suspend.service
Mar 10 12:29:21 fedora gsd-media-keys[2931]: gvc_mixer_card_get_index: assertion 'GVC_IS_MIXER_CARD (card)' failed
Mar 10 12:29:21 fedora gsd-media-keys[2931]: Unable to get default source
Mar 10 12:29:21 fedora gsd-media-keys[2931]: Unable to get default sink
Mar 10 12:29:21 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:0:0:0x00000011
Mar 10 12:29:21 fedora systemd-journald[895]: Missed 7 kernel messages
Mar 10 12:29:21 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67d:0:0:0x00000011
Mar 10 12:29:21 fedora systemd-journald[895]: Missed 20 kernel messages
Mar 10 12:29:21 fedora systemd-journald[895]: Missed 4 kernel messages
Mar 10 12:29:21 fedora systemd-journald[895]: /dev/kmsg buffer overrun, some messages lost.
Mar 10 12:29:21 fedora systemd-journald[895]: Missed 9 kernel messages
Mar 10 12:29:21 fedora kernel: nvidia-modeset: ERROR: GPU:0: Timed out waiting for core channel idle.
Mar 10 12:29:21 fedora uresourced[1726]: Setting resources on user-1000.slice (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
Mar 10 12:29:21 fedora uresourced[1726]: Setting resources on user@1000.service (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
Mar 10 12:29:21 fedora uresourced[1726]: Setting resources on user.slice (MemoryMin: 0, MemoryLow: 0, CPUWeight: -, IOWeight: -)
Mar 10 12:29:25 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down display engine channel
Mar 10 12:29:25 fedora kernel: nvidia-modeset: ERROR: GPU:0: Failed to tear down Disp
Mar 10 12:29:25 fedora kernel: ------------[ cut here ]------------
Mar 10 12:29:25 fedora kernel: WARNING: CPU: 5 PID: 111645 at nvidia/nv.c:4337 nv_set_system_power_state+0x2f2/0x480 [nvidia]
Mar 10 12:29:25 fedora kernel: Modules linked in: nf_conntrack_netlink veth nvidia_uvm(PO) uinput rfcomm snd_seq_dummy snd_hrtimer xt_conntrack xt_MASQUERADE bridge stp llc xt_set xt_addrtype nft_compat overlay sunrpc nf_conntrack_>
Mar 10 12:29:25 fedora kernel:  intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_hdmi coretemp libarc4 snd_compress ac97_bus snd_pcm_dmaengine kvm_intel snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda>
Mar 10 12:29:25 fedora kernel:  acpi_pad loop nfnetlink zram lz4hc_compress lz4_compress nvidia_drm(PO) nvidia_modeset(PO) nvidia(PO) hid_logitech_hidpp dm_crypt xe gpu_sched drm_suballoc_helper drm_gpuvm drm_exec i915 nvme i2c_alg>
Mar 10 12:29:25 fedora kernel: CPU: 5 UID: 0 PID: 111645 Comm: nvidia-sleep.sh Tainted: P           O       6.13.5-200.fc41.x86_64 #1
Mar 10 12:29:25 fedora kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE
Mar 10 12:29:25 fedora kernel: Hardware name: LENOVO 82RB/LNVNB161216, BIOS J2CN49WW 11/25/2022
Mar 10 12:29:25 fedora kernel: RIP: 0010:nv_set_system_power_state+0x2f2/0x480 [nvidia]
Mar 10 12:29:25 fedora kernel: Code: ad d0 06 00 00 48 85 ed 75 d3 e9 d9 fd ff ff 0f 0b e9 13 fe ff ff 48 8b 3d a3 c4 eb 00 4c 89 f6 e8 e3 91 61 c9 e9 12 ff ff ff <0f> 0b 4c 89 ef e8 b4 30 34 ca 4d 85 f6 74 0d e8 5a bf cb 00 84 c0
Mar 10 12:29:25 fedora kernel: RSP: 0018:ffffa84929adfd90 EFLAGS: 00010206
Mar 10 12:29:25 fedora kernel: RAX: 0000000000000011 RBX: 0000000000000001 RCX: ffffa84929adfd10
Mar 10 12:29:25 fedora kernel: RDX: 0000000000000000 RSI: 0000000000000246 RDI: ffffa84929adfcc0
Mar 10 12:29:25 fedora kernel: RBP: 0000000000000011 R08: 0000000000000000 R09: ffff8a860eaa2f60
Mar 10 12:29:25 fedora kernel: R10: ffffffffc6353490 R11: ffffffffc63534d0 R12: ffff8a85e20d5000
Mar 10 12:29:25 fedora kernel: R13: ffff8a85e20d56a8 R14: ffff8a860eaa0000 R15: ffff8a860eaa0000
Mar 10 12:29:25 fedora kernel: FS:  00007f7c49d94740(0000) GS:ffff8a895f480000(0000) knlGS:0000000000000000
Mar 10 12:29:25 fedora kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mar 10 12:29:25 fedora kernel: CR2: 00007f72c9571f5c CR3: 0000000161822002 CR4: 0000000000f72ef0
Mar 10 12:29:25 fedora kernel: PKRU: 55555554
Mar 10 12:29:25 fedora kernel: Call Trace:
Mar 10 12:29:25 fedora kernel:  <TASK>
Mar 10 12:29:25 fedora kernel:  ? nv_set_system_power_state+0x2f2/0x480 [nvidia]
Mar 10 12:29:25 fedora kernel:  ? __warn.cold+0x93/0xfa
Mar 10 12:29:25 fedora kernel:  ? report_bug+0xff/0x140
Mar 10 12:29:25 fedora kernel:  ? handle_bug+0x58/0x90
Mar 10 12:29:25 fedora kernel:  ? exc_invalid_op+0x17/0x70
Mar 10 12:29:25 fedora kernel:  ? asm_exc_invalid_op+0x1a/0x20
Mar 10 12:29:25 fedora kernel:  nv_procfs_write_suspend+0x105/0x1b0 [nvidia]
Mar 10 12:29:25 fedora kernel:  proc_reg_write+0x57/0xa0
Mar 10 12:29:25 fedora kernel:  vfs_write+0xf5/0x450
Mar 10 12:29:25 fedora kernel:  ksys_write+0x6c/0xe0
Mar 10 12:29:25 fedora kernel:  do_syscall_64+0x82/0x160
Mar 10 12:29:25 fedora kernel:  ? exc_page_fault+0x7e/0x180
Mar 10 12:29:25 fedora kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mar 10 12:29:25 fedora kernel: RIP: 0033:0x7f7c49e7f504
Mar 10 12:29:25 fedora kernel: Code: c7 00 16 00 00 00 b8 ff ff ff ff c3 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 80 3d c5 8b 10 00 00 74 13 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 54 c3 0f 1f 00 55 48 89 e5 48 83 ec 20 48 89
Mar 10 12:29:25 fedora kernel: RSP: 002b:00007ffe9bb4bf78 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
Mar 10 12:29:25 fedora kernel: RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007f7c49e7f504
Mar 10 12:29:25 fedora kernel: RDX: 0000000000000008 RSI: 0000556839212a00 RDI: 0000000000000001
Mar 10 12:29:25 fedora kernel: RBP: 00007ffe9bb4bfa0 R08: 0000000000000410 R09: 0000000000000001
Mar 10 12:29:25 fedora kernel: R10: 0000000000000004 R11: 0000000000000202 R12: 0000000000000008
Mar 10 12:29:25 fedora kernel: R13: 0000556839212a00 R14: 00007f7c49f815c0 R15: 00007f7c49f7ee80
Mar 10 12:29:25 fedora kernel:  </TASK>
Mar 10 12:29:25 fedora kernel: ---[ end trace 0000000000000000 ]---
Mar 10 12:29:25 fedora kernel: WARNING: CPU: 5 PID: 111645 at nvidia/nv.c:4287 nv_restore_user_channels+0x4e/0x1d0 [nvidia]
Mar 10 12:29:25 fedora kernel: CPU: 5 UID: 0 PID: 111645 Comm: nvidia-sleep.sh Tainted: P        W  O       6.13.5-200.fc41.x86_64 #1
Mar 10 12:29:25 fedora kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE
Mar 10 12:29:25 fedora kernel: RIP: 0010:nv_restore_user_channels+0x4e/0x1d0 [nvidia]
Mar 10 12:29:25 fedora kernel: Code: 24 a8 06 00 00 4c 89 ef e8 1f 6e 34 ca f6 43 10 01 74 73 48 89 de 31 ff e8 3f 8f cb 00 41 89 c6 85 c0 0f 84 3a 01 00 00 31 ed <0f> 0b 49 81 c4 e0 07 00 00 4c 89 e7 e8 f1 6d 34 ca be 01 00 00 00
Mar 10 12:29:25 fedora kernel: RSP: 0018:ffffa84929adfd60 EFLAGS: 00010206
Mar 10 12:29:25 fedora kernel: RAX: 0000000000000011 RBX: ffff8a85e20d5000 RCX: ffffa84929adfce0
Mar 10 12:29:25 fedora kernel: RDX: 0000000000000000 RSI: 0000000000000246 RDI: ffffa84929adfc90
Mar 10 12:29:25 fedora kernel: RBP: ffff8a860eaa0000 R08: 0000000000000000 R09: ffff8a860eaa2f60
Mar 10 12:29:25 fedora kernel: R13: ffff8a85e20d56a8 R14: 0000000000000011 R15: ffff8a860eaa0000
Mar 10 12:29:25 fedora kernel:  ? nv_restore_user_channels+0x4e/0x1d0 [nvidia]
Mar 10 12:29:25 fedora kernel:  nv_set_system_power_state+0x344/0x480 [nvidia]
Mar 10 12:29:26 fedora abrt-dump-journal-oops[1441]: abrt-dump-journal-oops: Found oopses: 3
Mar 10 12:29:26 fedora abrt-dump-journal-oops[1441]: abrt-dump-journal-oops: Creating problem directories
Mar 10 12:29:27 fedora abrt-server[111687]: Deleting problem directory oops-2025-03-10-12:29:26-1441-0 (dup of oops-2025-03-09-04:00:27-1444-0)
Mar 10 12:29:27 fedora abrt-notification[111694]: [🡕] System encountered a non-fatal error in nv_set_system_power_state()
Mar 10 12:29:27 fedora abrt-server[111697]: Deleting problem directory oops-2025-03-10-12:29:26-1441-1 (dup of oops-2025-03-09-04:00:27-1444-0)
Mar 10 12:29:28 fedora abrt-notification[111704]: [🡕] System encountered a non-fatal error in nv_set_system_power_state()
Mar 10 12:29:28 fedora abrt-server[111706]: Deleting problem directory oops-2025-03-10-12:29:26-1441-2 (dup of oops-2025-03-09-04:00:27-1444-0)
Mar 10 12:29:29 fedora abrt-notification[111713]: [🡕] System encountered a non-fatal error in nv_set_system_power_state()
Mar 10 12:29:29 fedora abrt-dump-journal-oops[1441]: Reported 3 kernel oopses to Abrt
Mar 10 12:29:30 fedora systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 10 12:29:30 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=>
Mar 10 12:29:51 fedora kernel: lockdown_is_locked_down: 11 callbacks suppressed
Mar 10 12:29:51 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:32:05 fedora kernel: BUG: unable to handle page fault for address: ffffa84900aa0010
Mar 10 12:32:05 fedora kernel: fbcon: Taking over console
Mar 10 12:32:05 fedora kernel: #PF: supervisor read access in kernel mode
Mar 10 12:32:05 fedora kernel: #PF: error_code(0x0000) - not-present page
Mar 10 12:32:05 fedora kernel: PGD 100000067 P4D 100000067 PUD 1002d6067 PMD 10461e067 PTE 0
Mar 10 12:32:05 fedora kernel: Oops: Oops: 0000 [#1] PREEMPT SMP NOPTI
Mar 10 12:32:05 fedora kernel: CPU: 8 UID: 0 PID: 111645 Comm: nvidia-sleep.sh Tainted: P        W  O       6.13.5-200.fc41.x86_64 #1
Mar 10 12:32:05 fedora kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE
Mar 10 12:32:05 fedora kernel: Hardware name: LENOVO 82RB/LNVNB161216, BIOS J2CN49WW 11/25/2022
Mar 10 12:32:05 fedora kernel: RIP: 0010:_nv000117kms+0xbe/0x140 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel: Code: 00 48 8d b5 0c fe ff ff 48 89 df e8 4c 55 06 00 48 89 c2 48 85 c0 75 cc 41 83 c4 01 48 83 c3 10 41 83 fc 04 75 ad 49 8b 7d 00 <48> 8b 47 08 8b 90 78 02 00 00 85 d2 74 45 8d 4a ff 4c 89 f0 48 8d
Mar 10 12:32:05 fedora kernel: RSP: 0018:ffffa84929adf890 EFLAGS: 00010246
Mar 10 12:32:05 fedora kernel: RAX: 0000000000000000 RBX: ffff8a85d80c1238 RCX: 0000000000000006
Mar 10 12:32:05 fedora kernel: RDX: 0000000000000000 RSI: ffff8a85c163ee08 RDI: ffffa84900aa0008
Mar 10 12:32:05 fedora kernel: RBP: ffffa84929adfa90 R08: 0000000000000000 R09: ffffa84929adf89c
Mar 10 12:32:05 fedora kernel: R10: 0000000000080001 R11: 00000000ffffffff R12: 0000000000000004
Mar 10 12:32:05 fedora kernel: R13: ffff8a85d80c10d8 R14: ffffa84929adf8a0 R15: ffff8a85d80c1018
Mar 10 12:32:05 fedora kernel: FS:  00007f7c49d94740(0000) GS:ffff8a895f600000(0000) knlGS:0000000000000000
Mar 10 12:32:05 fedora kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mar 10 12:32:05 fedora kernel: CR2: ffffa84900aa0010 CR3: 0000000161822004 CR4: 0000000000f72ef0
Mar 10 12:32:05 fedora kernel: PKRU: 55555554
Mar 10 12:32:05 fedora kernel: Call Trace:
Mar 10 12:32:05 fedora kernel:  <TASK>
Mar 10 12:32:05 fedora kernel:  ? __die_body.cold+0x19/0x27
Mar 10 12:32:05 fedora kernel:  ? page_fault_oops+0x15c/0x2f0
Mar 10 12:32:05 fedora kernel:  ? search_module_extables+0x19/0x60
Mar 10 12:32:05 fedora kernel:  ? search_bpf_extables+0x5f/0x80
Mar 10 12:32:05 fedora kernel:  ? exc_page_fault+0x170/0x180
Mar 10 12:32:05 fedora kernel:  ? asm_exc_page_fault+0x26/0x30
Mar 10 12:32:05 fedora kernel:  ? _nv000117kms+0xbe/0x140 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  _nv000406kms+0x23/0x170 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  ? _nv002894kms+0x97/0xb0 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  _nv003103kms+0x8d/0xa0 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  _nv000406kms+0x155/0x170 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  _nv003102kms+0x226/0x240 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  ? schedule+0x27/0xf0
Mar 10 12:32:05 fedora kernel:  ? schedule_timeout+0xbf/0x100
Mar 10 12:32:05 fedora kernel:  ? uvm_resume_entry+0x86/0x90 [nvidia_uvm]
Mar 10 12:32:05 fedora kernel:  nvKmsResume+0x7f/0xb0 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  nvkms_resume+0x1f/0x50 [nvidia_modeset]
Mar 10 12:32:05 fedora kernel:  nv_set_system_power_state+0x368/0x480 [nvidia]
Mar 10 12:32:05 fedora kernel:  nv_procfs_write_suspend+0x105/0x1b0 [nvidia]
Mar 10 12:32:05 fedora kernel:  proc_reg_write+0x57/0xa0
Mar 10 12:32:05 fedora kernel:  vfs_write+0xf5/0x450
Mar 10 12:32:05 fedora kernel:  ksys_write+0x6c/0xe0
Mar 10 12:32:05 fedora kernel:  do_syscall_64+0x82/0x160
Mar 10 12:32:05 fedora kernel:  ? exc_page_fault+0x7e/0x180
Mar 10 12:32:05 fedora kernel:  entry_SYSCALL_64_after_hwframe+0x76/0x7e
Mar 10 12:32:05 fedora kernel: RIP: 0033:0x7f7c49e7f504
Mar 10 12:32:05 fedora kernel: Code: c7 00 16 00 00 00 b8 ff ff ff ff c3 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 80 3d c5 8b 10 00 00 74 13 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 54 c3 0f 1f 00 55 48 89 e5 48 83 ec 20 48 89
Mar 10 12:32:05 fedora kernel: RSP: 002b:00007ffe9bb4bf78 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
Mar 10 12:32:05 fedora kernel: RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007f7c49e7f504
Mar 10 12:32:05 fedora kernel: RDX: 0000000000000008 RSI: 0000556839212a00 RDI: 0000000000000001
Mar 10 12:32:05 fedora kernel: RBP: 00007ffe9bb4bfa0 R08: 0000000000000410 R09: 0000000000000001
Mar 10 12:32:05 fedora kernel: R10: 0000000000000004 R11: 0000000000000202 R12: 0000000000000008
Mar 10 12:32:05 fedora kernel: R13: 0000556839212a00 R14: 00007f7c49f815c0 R15: 00007f7c49f7ee80
Mar 10 12:32:05 fedora kernel:  </TASK>
Mar 10 12:32:05 fedora kernel: Modules linked in: nf_conntrack_netlink veth nvidia_uvm(PO) uinput rfcomm snd_seq_dummy snd_hrtimer xt_conntrack xt_MASQUERADE bridge stp llc xt_set xt_addrtype nft_compat overlay sunrpc nf_conntrack_>
Mar 10 12:32:05 fedora kernel:  intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_hdmi coretemp libarc4 snd_compress ac97_bus snd_pcm_dmaengine kvm_intel snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda>
Mar 10 12:32:05 fedora kernel:  acpi_pad loop nfnetlink zram lz4hc_compress lz4_compress nvidia_drm(PO) nvidia_modeset(PO) nvidia(PO) hid_logitech_hidpp dm_crypt xe gpu_sched drm_suballoc_helper drm_gpuvm drm_exec i915 nvme i2c_alg>
Mar 10 12:32:05 fedora kernel: ---[ end trace 0000000000000000 ]---
Mar 10 12:32:05 fedora kernel: note: nvidia-sleep.sh[111645] exited with irqs disabled
Mar 10 12:32:05 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:32:05 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=nvidia-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=fail>
Mar 10 12:32:05 fedora audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-vconsole-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? r>
Mar 10 12:32:05 fedora systemd[1]: nvidia-suspend.service: Main process exited, code=killed, status=9/KILL
Mar 10 12:32:05 fedora systemd[1]: nvidia-suspend.service: Failed with result 'signal'.
Mar 10 12:32:05 fedora systemd[1]: Failed to start nvidia-suspend.service - NVIDIA system suspend actions.
Mar 10 12:32:05 fedora systemd[1]: nvidia-suspend.service: Consumed 2min 43.908s CPU time, 1.3M memory peak.
Mar 10 12:32:05 fedora systemd[1]: Starting systemd-suspend.service - System Suspend...
Mar 10 12:32:05 fedora systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Mar 10 12:32:05 fedora systemd[1]: Stopped systemd-vconsole-setup.service - Virtual Console Setup.
Mar 10 12:32:05 fedora systemd[1]: Stopping systemd-vconsole-setup.service - Virtual Console Setup...
Mar 10 12:32:05 fedora systemd[1]: Starting systemd-vconsole-setup.service - Virtual Console Setup...
Mar 10 12:32:05 fedora systemd[1]: run-credentials-systemd\x2dvconsole\x2dsetup.service.mount: Deactivated successfully.
Mar 10 12:32:05 fedora kernel: Console: switching to colour frame buffer device 320x90
Mar 10 12:32:05 fedora systemd-sleep[111741]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
Mar 10 12:32:05 fedora systemd-sleep[111741]: This is not recommended, and might result in unexpected behavior, particularly
Mar 10 12:32:05 fedora systemd-sleep[111741]: in suspend-then-hibernate operations or setups with encrypted home directories.
Mar 10 12:32:05 fedora systemd-sleep[111741]: Performing sleep operation 'suspend'...
Mar 10 12:32:05 fedora kernel: PM: suspend entry (deep)
Mar 10 12:32:05 fedora kernel: Filesystems sync: 0.008 seconds
Mar 10 12:32:06 fedora systemd[1]: Finished systemd-vconsole-setup.service - Virtual Console Setup.
Mar 10 12:32:06 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-vconsole-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? >
Mar 10 12:32:06 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:32:07 fedora kernel: Freezing user space processes
Mar 10 12:32:07 fedora kernel: Freezing user space processes completed (elapsed 0.002 seconds)
Mar 10 12:32:07 fedora kernel: OOM killer disabled.
Mar 10 12:32:07 fedora kernel: Freezing remaining freezable tasks
Mar 10 12:32:07 fedora kernel: Freezing remaining freezable tasks completed (elapsed 0.007 seconds)
Mar 10 12:32:07 fedora kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 10 12:32:07 fedora kernel: NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Manage>
Mar 10 12:32:07 fedora kernel: nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
Mar 10 12:32:07 fedora kernel: nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
Mar 10 12:32:07 fedora kernel: nvidia 0000:01:00.0: PM: failed to suspend async: error -5
Mar 10 12:32:07 fedora kernel: PM: Some devices failed to suspend, or early wake event detected
Mar 10 12:32:07 fedora kernel: spd5118 19-0050: PM: dpm_run_callback(): spd5118_resume [spd5118] returns -6
Mar 10 12:32:07 fedora kernel: spd5118 19-0050: PM: failed to resume async: error -6
Mar 10 12:32:07 fedora kernel: spd5118 19-0052: PM: dpm_run_callback(): spd5118_resume [spd5118] returns -6
Mar 10 12:32:07 fedora kernel: spd5118 19-0052: PM: failed to resume async: error -6
Mar 10 12:32:07 fedora kernel: i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.36.0
Mar 10 12:32:07 fedora kernel: i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
Mar 10 12:32:07 fedora kernel: nvme nvme0: D3 entry latency set to 10 seconds
Mar 10 12:32:07 fedora kernel: nvme nvme0: 20/0/0 default/read/poll queues
Mar 10 12:32:07 fedora kernel: i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
Mar 10 12:32:07 fedora kernel: i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
Mar 10 12:32:07 fedora kernel: i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
Mar 10 12:32:07 fedora kernel: i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
Mar 10 12:32:07 fedora kernel: PM: resume devices took 1.068 seconds
Mar 10 12:32:07 fedora kernel: OOM killer enabled.
Mar 10 12:32:07 fedora kernel: Restarting tasks ... done.
Mar 10 12:32:07 fedora kernel: random: crng reseeded on system resumption
Mar 10 12:32:07 fedora abrt-dump-journal-oops[1441]: abrt-dump-journal-oops: Found oopses: 1
Mar 10 12:32:07 fedora abrt-dump-journal-oops[1441]: abrt-dump-journal-oops: Creating problem directories
Mar 10 12:32:07 fedora kernel: PM: suspend exit
Mar 10 12:32:07 fedora kernel: PM: suspend entry (s2idle)
Mar 10 12:32:07 fedora kernel: Filesystems sync: 0.008 seconds
Mar 10 12:32:08 fedora kernel: Freezing user space processes
Mar 10 12:32:08 fedora kernel: Freezing user space processes completed (elapsed 0.002 seconds)
Mar 10 12:32:08 fedora kernel: OOM killer disabled.
Mar 10 12:32:08 fedora kernel: Freezing remaining freezable tasks
Mar 10 12:32:08 fedora kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Mar 10 12:32:08 fedora kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mar 10 12:32:08 fedora kernel: NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Manage>
Mar 10 12:32:08 fedora kernel: nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
Mar 10 12:32:08 fedora kernel: nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
Mar 10 12:32:08 fedora kernel: nvidia 0000:01:00.0: PM: failed to suspend async: error -5
Mar 10 12:32:08 fedora kernel: PM: Some devices failed to suspend, or early wake event detected
Mar 10 12:32:08 fedora kernel: spd5118 19-0050: PM: dpm_run_callback(): spd5118_resume [spd5118] returns -6
Mar 10 12:32:08 fedora kernel: spd5118 19-0050: PM: failed to resume async: error -6
Mar 10 12:32:08 fedora kernel: spd5118 19-0052: PM: dpm_run_callback(): spd5118_resume [spd5118] returns -6
Mar 10 12:32:08 fedora kernel: spd5118 19-0052: PM: failed to resume async: error -6
Mar 10 12:32:08 fedora kernel: i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.36.0
Mar 10 12:32:08 fedora kernel: i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
Mar 10 12:32:08 fedora kernel: i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
Mar 10 12:32:08 fedora kernel: i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
Mar 10 12:32:08 fedora kernel: i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
Mar 10 12:32:08 fedora kernel: i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
Mar 10 12:32:08 fedora kernel: PM: resume devices took 1.070 seconds
Mar 10 12:32:08 fedora kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
Mar 10 12:32:08 fedora kernel: OOM killer enabled.
Mar 10 12:32:08 fedora kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Mar 10 12:32:08 fedora kernel: Restarting tasks ... done.
Mar 10 12:32:08 fedora abrt-dump-journal-oops[1441]: Reported 1 kernel oopses to Abrt
Mar 10 12:32:08 fedora kernel: random: crng reseeded on system resumption
Mar 10 12:32:08 fedora abrt-server[111796]: dmesg: read kernel buffer failed: Operation not permitted
Mar 10 12:32:09 fedora systemd-sleep[111741]: Failed to put system to sleep. System resumed again: Input/output error
Mar 10 12:32:09 fedora kernel: PM: suspend exit
Mar 10 12:32:09 fedora abrt-server[111796]: Can't find a meaningful backtrace for hashing in '.'
Mar 10 12:32:09 fedora abrt-server[111796]: Deleting non-reportable oops '.' because DropNotReportableOopses is set to 'yes'
Mar 10 12:32:09 fedora abrt-server[111796]: 'post-create' on '/var/spool/abrt/oops-2025-03-10-12:32:07-1441-0' exited with 1
Mar 10 12:32:09 fedora abrt-server[111796]: Deleting problem directory '/var/spool/abrt/oops-2025-03-10-12:32:07-1441-0'
Mar 10 12:32:09 fedora abrt-server[111796]: Lock file '.lock' was locked by process 111836, but it crashed?
Mar 10 12:32:54 fedora systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
Mar 10 12:32:54 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:33:39 fedora systemd[1]: systemd-suspend.service: State 'stop-sigterm' timed out. Aborting.
Mar 10 12:33:39 fedora systemd[1]: systemd-suspend.service: Killing process 111835 (nvidia-sleep.sh) with signal SIGABRT.
Mar 10 12:33:39 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:34:24 fedora systemd[1]: systemd-suspend.service: State 'stop-watchdog' timed out. Killing.
Mar 10 12:34:24 fedora systemd[1]: systemd-suspend.service: Killing process 111835 (nvidia-sleep.sh) with signal SIGKILL.
Mar 10 12:34:24 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:35:09 fedora systemd[1]: systemd-suspend.service: Processes still around after SIGKILL. Ignoring.
Mar 10 12:35:09 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:35:54 fedora systemd[1]: systemd-suspend.service: State 'final-sigterm' timed out. Aborting.
Mar 10 12:35:54 fedora systemd[1]: systemd-suspend.service: Killing process 111835 (nvidia-sleep.sh) with signal SIGABRT.
Mar 10 12:35:54 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:36:39 fedora systemd[1]: systemd-suspend.service: State 'final-watchdog' timed out. Killing.
Mar 10 12:36:39 fedora systemd[1]: systemd-suspend.service: Killing process 111835 (nvidia-sleep.sh) with signal SIGKILL.
Mar 10 12:36:39 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:37:24 fedora systemd[1]: systemd-suspend.service: Processes still around after final SIGKILL. Entering failed mode.
Mar 10 12:37:24 fedora kernel: Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
Mar 10 12:37:24 fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=fai>
Mar 10 12:37:24 fedora ModemManager[1421]: <msg> [sleep-monitor-systemd] system is resuming
Mar 10 12:37:24 fedora systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
Mar 10 12:37:24 fedora ModemManager[1421]: <msg> [sleep-monitor-systemd] system is about to suspend
Mar 10 12:37:24 fedora systemd[1]: systemd-suspend.service: Unit process 111835 (nvidia-sleep.sh) remains running after unit stopped.
Mar 10 12:37:24 fedora ModemManager[1421]: <wrn> [sleep-monitor-systemd] inhibit failed: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 10 12:37:24 fedora systemd[1]: Failed to start systemd-suspend.service - System Suspend.
Mar 10 12:37:24 fedora systemd[1]: Dependency failed for suspend.target - Suspend.
Mar 10 12:37:24 fedora systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
Mar 10 12:37:24 fedora systemd[1]: Stopped target sleep.target - Sleep.
Mar 10 12:37:24 fedora systemd[1]: Starting nvidia-resume.service - NVIDIA system resume actions...
Mar 10 12:37:24 fedora systemd-logind[1292]: Operation 'suspend' finished.
Mar 10 12:37:24 fedora systemd-resolved[1235]: Closing all remaining TCP connections.
Mar 10 12:37:24 fedora systemd-resolved[1235]: Resetting learnt feature levels on all servers.
Mar 10 12:37:24 fedora NetworkManager[1568]: <info>  [1741590444.8595] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mar 10 12:37:24 fedora NetworkManager[1568]: <info>  [1741590444.8597] device (enp52s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Mar 10 12:37:24 fedora systemd-logind[1292]: Suspending...
Mar 10 12:37:24 fedora systemd[1]: Reached target sleep.target - Sleep.
Mar 10 12:37:24 fedora gsd-media-keys[2931]: Unable to inhibit suspend: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 10 12:37:24 fedora upowerd[1304]: Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 10 12:37:24 fedora suspend[111851]: nvidia-resume.service
Mar 10 12:37:24 fedora gsd-power[2940]: Unable to inhibit suspend: GDBus.Error:org.freedesktop.login1.OperationInProgress: The operation inhibition has been requested for is already running
Mar 10 12:37:24 fedora logger[111851]: <13>Mar 10 12:37:24 suspend: nvidia-resume.service
Mar 10 12:37:24 fedora gnome-shell[2798]: [atomic] Failed to disable device '/dev/dri/card1': drmModeAtomicCommit: Permission denied
Mar 10 12:37:24 fedora systemd[1]: Starting nvidia-suspend.service - NVIDIA system suspend actions...
Mar 10 12:37:24 fedora kernel: Generic FE-GE Realtek PHY r8169-0-3400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-3400:00, irq=MAC)
Mar 10 12:37:24 fedora suspend[111864]: nvidia-suspend.service
Mar 10 12:37:24 fedora logger[111864]: <13>Mar 10 12:37:24 suspend: nvidia-suspend.service
I fixed this by doing this hibernate - Ubuntu 25.04 suspend/resume broken on ASUS Vivobook K6501ZM - Ask Ubuntu
