Release notes for Bright 8.1-26
== General ==
=Improvements=
- Update mlnx-ofed49 to version 4.9-5.1.0.0
- Update cuda-dcgm to version 2.3.5-1
= Fixed Issues=
- mlnx-ofed: Incorrect values for the LD* environment variables in the Ubuntu openmpi module file
== CMDaemon ==
=Improvements=
- Improved mysql health check no longer requires the mysql password to be included on the command line
=Fixed Issues=
- CMDaemon crash when the Grid Engine exec hosts list contains an unknown to CMDaemon node
- Add full support for multi-value http request parameters, to resolve an issue where the “CMDaemon ready” service is not able to handle a list of services by name
- An issue where Slurm partition extra options may not be preserved in the configuration if scontrol temporary does not work
== Machine Learning ==
=New Features=
- Introduced packages cm-cudnn8.2-cuda11.4
- Introduced packages cm-cudnn8.4-cuda11.4
== cm-wlm-setup ==
=Improvements=
- Deployment of IBM Spectrum LSF Suite is no longer supported. The supported option remains the deployment of LSF Standard Edition
