== General ==
= New Features
- Support for SLES15sp4
= Improvements
- Update lua to 5.4.4 (CVE-2022-28805)
- Update openssl to version 1.1.1q
- Update cuda-dcgm to version 2.4.6.1
- Update mlnx-ofed49 to version 4.9-5.1.0.0
- Updated mlnx-ofed56 to version 5.6-2.0.9.0
- Added cuda11.7 packages
== CMDaemon ==
= New Features
- Added CMDaemon advanced configuration options for customizing global nginx.conf values
= Improvements
- Remove the user home directories asynchronously, which resolves an issue with the delete process appearing hung when the user’s home directory contains many files
- Performance improvements in CMDaemon to decrease the start-up time of the head node CMDaemon on clusters with many pending WLM jobs
- Reduce the verbosity of the ‘result for obsolete tracker’ messages, so that they are no longer included by default in the CMDaemon log file
- CMDaemon will now produce a warning when a new image is added without an underlying directory structure
- Improved logic when invalidating the nscd hosts cache on the compute nodes, to avoid cases where an outdated cache interferes with hostnames lookup
- CMDaemon certificates are now generated with a start date of 1 calendar day before the issue date, instead of the Unix epoch
- An issue where cm-manipulate-advanced-config.py is missing a python import, resulting in a crash when executed
- Ensure that the Kubernetes NetworkPolicy feature works when the kube-proxy masqueradeAll flag is disabled
- An issue where monitoring data for labeled entities is not preserved after the entity has been dropped and automatically re-added
= Fixed Issues
- In some cases, an issue with re-establishing the edge nodes sessions to the director after a restart of CMDaemon
- An issue with CMDaemon events delivery to edge nodes, which can result in outdated information about committed entities
- Fix an issue with setting up Kubernetes where if the passive head node is the active leader according to Etcd, then Kubernetes will not always be able to initialize properly
- In rare occasions CMDaemon can hang while stopping due to a blocking SSL read operation
- An issue where PBS queue options set in CMDaemon may not be set in the PBS server configuration
- Send the rsyslog log to both head nodes for on-prem compute nodes
- Fix an issue with generating a valid Kubernetes kubeconfig for users with special characters in their login name. Performance improvements of the user manager
- Fix rare crash in CMDaemon while cloning an image
- An issue where CMDaemon may not (re)generate the Slurm logrotate files in some cases, such as when the files are modified or deleted outside of CMDaemon
- Fix possible crash in the provisioning status code
- Fix a potential buffer overflow
- An issue where CMDaemon can crash if the Bright View monitoring tree call does not pass a context
- Add full support for multi-value http request parameters, to resolve an issue where the “CMDaemon ready” service is not able to handle a list of services by name
- In some cases, terminating spot instances with CMDaemon may fail if the spot request has been canceled outside of CMDaemon
- In some cases, an issue with upgrading from Bright 8.x to 9.1 due to an invalid SQL statement
- An issue where CMDaemon may occasionally hang on SSL_read while stopping
- An issue where the default gateway may not be set on a cluster with an aliased external network interface
== Bright View ==
= Fixed Issues
- An issue where SLURM/GRES file templates are not read-only in Bright View and can be modified
== Node Installer ==
= Improvements
- Allow the node-installer to continue with configuring IPMI after encountering a failure to set username and password when the user already exists
= Fixed Issues
- An issue in the ilo_power.pl script, which can break the remote power management for nodes that use an ilo0 interface for the power control
== User Portal ==
= Fixed Issues
- An issue where the user portal can show only 1 core for a compute node, regardless of the actual number of cores
== cm-create-image ==
= Fixed Issues
- An issue where images created with cm-create-image do not preserve the xattrs of the base tar image
- An issue where node-installer images created using the cm-create-image tool do not have an updated rsyslog.conf file
== cm-kubernetes ==
= Improvements
- Make the PersistentVolumeClaims privilege part of the default list of privileges for the users when Kubernetes is set up
== cm-kubernetes-setup ==
= Improvements
- Enable by default the selection of newer Kubernetes versions in the cm-kubernetes-setup screens
- An issue with Kubernetes on Edge deployments, where the stage “waiting for Root Service Account” is performed too early and may not complete successfully in some cases
- Fix an issue where Kubernetes version >= 1.21 is not deployed with masqueradeAll=false for kube-proxy, preventing NetworkPolicies from working
- In the Kubernetes module files, remove the MANPATH definitions which are no longer used
- In some cases, an issue with setting the Kubernetes labels for control-plane, master, and worker
= Fixed Issues
- Ensure cm-kubernetes-setup --default-cni-bin-dir flag updates all relevant roles
== cm-setup ==
= Fixed Issues
- Make cm-*-setup configuration file permissions more restrictive
== cm-uge ==
= Improvements
- Update the default settings in cm-uge to allow running OpenMPI jobs without involving ssh
== cm-wlm-setup ==
= Improvements
- Automatically remove the WLM settings from the Auto Scaler configuration when the WLM is disabled
= Fixed Issues
- An issue with making the pbs.service file available on the compute nodes with offloaded PBSPro server role, which prevents the PBSPro server from starting during the setup
== cmsh ==
= New Features
- Allow the --start and --end arguments in rangequery command to be specified as date/time stamps
= Improvements
- Warn that using rshell to image as non-root user might not work (As there is no ldap inside the image)
- Added --filter option to the environment command, to allow for showing only the entities that match the specified regex
= Fixed Issues
- An issue where the --user option of the cmsh “rshell” command does not take effect
- An issue where the monitoringdrop command does not drop the measurables when multiple measurables are specified on the command line
- An issue where the cmsh device switchport update may not save on commit
- An issue where the XSD validation is not always loaded in cmsh when configuring a disk setup for the compute nodes
== hwloc ==
= Improvements
- Update cm-hwloc2 to 2.7.1
== ml ==
= New Features
- Introduced packages cm-cudnn8.2-cuda11.4
- Introduced packages cm-cudnn8.4-cuda11.4
== openpbs22.05 ==
= Improvements
- Add OpenPBS 22.05 integration
== pythoncm ==
= Improvements
- pythoncm now includes periodic checks during the provisioning wait, to ensure that tools such as cm-wlm-setup do not time out while the nodes are being provisioned
== slurm ==
= Improvements
- Add slurmrestd service file to the Slurm packages
= Fixed Issues
- Rebuild the Ubuntu Slurm packages with cm-pmix3
== slurm22.05 ==
= Improvements
- Update to 22.05.3
- Add Slurm 22.05 support
